jon2023
November 27, 2023, 4:19pm
1
Hi there,
Hardware:
Colibri iMX6DL
with Viola Carrier Board Rev 1.2
TorizonCore 5.7.2
I’ve run through some of the weston examples, i.e. the weston-eventdemo etc. from github
and most of them run within a weston container/window with a title bar, min/max/close button with sizeable borders.
I’ve then run the Analonia wizard and create a basic “Hello Analonia” .NET application with Dockerfile/Dockerfile.debug, docker-compose.yml files and can run the “full” screen application on the colibri board.
Would it be possible to run the Analonia docker within a weston container/window?
If so, what would be the first steps.
Cheers Jon
leon.tx
November 27, 2023, 5:46pm
2
Hello there!
If I understood correctly, you want to specifically run with the title bar, min/max/close button etc?
You can do that by passing --developer with command in your docker-compose.yml like
weston:
image: torizon/weston${GPU}:3
command: --developer
This brings up the weston shell instead of a blank canvas (which is where your fullscreen Avalonia application is running, by the way!).
jon2023
November 27, 2023, 6:11pm
3
Hi there leon,
My docker-compose.yml (generated by the Avalonia .NET wizard) looks more like this…
version: “3.9”
services:
avalonia13-debug:
build:
context: .
dockerfile: Dockerfile.debug
image: ${LOCAL_REGISTRY}:5002/avalonia13:${TAG}
environment:
- XDG_RUNTIME_DIR=/run/display
# Required to get udev events from host udevd via netlink
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
Not sure how to update it to “link” (if that’s the correct) the “weston” image with the current image link in the docker-compose.yml above.
services:
avalonia13-debug: <— !!!
build:
context: .
image: ${LOCAL_REGISTRY}:5002/avalonia13:${TAG} <— !!!
Many Thanks Jon
leon.tx
November 27, 2023, 6:37pm
4
Hi again
Just some background info: you’re using the Torizon IDE Extension and created a new Avalonia project, correct?
leon.tx
November 27, 2023, 6:43pm
5
By the way: the target for the new IDE extension is Torizon OS 6.x.y as defined here Visual Studio Code IDE Extension | Toradex Developer Center .
If feasible, please consider updating to Torizon OS 6.x.y following this documentation: Upgrading from TorizonCore 5.x to Torizon OS 6.x | Toradex Developer Center .
jon2023
November 27, 2023, 9:57pm
6
Hi leon,
Yeah, using the new Torizon IDE Extension…
… its pretty easy to use, and gives a good starting point
Cheers Jon
jon2023
November 27, 2023, 9:59pm
7
Hi leon,
Thanks for the message. I think upgrading to Torizon OS 6.x.y would be a good thing to do.
I’ll take a look at the steps and see how it goes
Cheers Jon
jon2023
November 28, 2023, 10:18am
8
Good Morning leon,
While my colleague looks at the upgrade path on a second board which we have, I’m looking into the docker-compose.yml changes for running the Avalonia application in a weston window/container as a PoC, but not sure how it should be updated. Are there any examples I take a look at?
Cheers Jon
Hi @jon2023 !
All the templates we have on Torizon IDE will give you a containerized application.
jon2023
November 28, 2023, 7:10pm
10
Hi henrique,
We’ve created a new Avalonia application using the Wizard…
Which creates all the project files, Dockerfile, Dockerfile.debug, docker-compose.yml etc. etc.
When we debug the application from VisualStudioCode, it runs on the device and the UI is displayed “Full” screen on the LCD display…
And checking the docker container…
$ docker ps
We would like to see the Avalonia application (if that’s possible) to run inside a window with a title bar, min, max & close buttons…
Is it possible to make some minor updates to the docker-compose.yml file to achieve this, or is it not as simple as that?
docker-compose.yml
version: "3.9"
services:
avalonia13-debug:
build:
context: .
environment:
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
- type: bind
source: /dev/input
target: /dev/input
- type: bind
source: /dev/input/event0
target: /dev/input/event0
- type: bind
source: /dev/input/event1
target: /dev/input/event1
- type: bind
source: /dev/input/touchscreen0
target: /dev/input/touchscreen0
- type: bind
source: /run/udev/data
target: /run/udev/data
- type: bind
source: /etc/xdg/weston
target: /etc/xdg/weston
- type: bind
source: /etc/xdg/weston-dev
target: /etc/xdg/weston-dev
- type: bind
source: /etc/xdg/weston/weston.ini
target: /etc/xdg/weston/weston.ini
- type: bind
source: /etc/xdg/weston-dev/weston.ini
target: /etc/xdg/weston-dev/weston.ini
devices:
- "/dev/input:/dev/input"
- "/dev/input/event0:/dev/input/event0"
- "/dev/input/event1:/dev/input/event1"
- "/dev/input/touchscreen0:/dev/input/touchscreen0"
- "/dev/gpiochip0"
- "/dev/gpiochip1"
- "/dev/gpiochip4"
- "/dev/spidev3.0"
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 4:1 rmw"
# ... for /dev/input devices
- "c 13:* rmw"
# ... for /dev/dri devices
- "c 226:* rmw"
- "c 199:* rmw"
# ... for /dev/fb0
- "c 29:* rmw"
# ... for /dev/input/touchscreen0 devices
- "c 6:* rmw"
avalonia13:
build:
context: .
image: ${DOCKER_LOGIN}/avalonia13:${TAG}
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 226:* rmw"
- "c 199:* rmw"
# ... for /dev/fb0
- "c 29:* rmw"
Cheers Jon
leon.tx
November 29, 2023, 1:59pm
11
Hi again Jon!
You’re using the framebuffer template, which won’t use a compositor (like Weston) so it doesn’t have the title bars etc.
You can achieve this effect by using the other Avalonia template (the one with no “framebuffer” in the title) and just edit the generated docker-compose.yml according to this Avalonia application running in Weston type Window - #4 by leon.tx .
It’s a bit odd why you’re getting these Weston mentions from the AvaloniaFB template. The docker-compose.yml you should get is this one: vscode-torizon-templates/dotnetAvaloniaFrameBuffer/docker-compose.yml at bookworm · torizon/vscode-torizon-templates · GitHub .
Cheers,
Hi @jon2023 !
Out of curiosity, could you please shre why would you like to have such decoration around your application’s UI?
Usually (if not always ) embedded applications are fullscreen to forbid users to change its visual and also make a more efficient usage of the display area.
jon2023
November 29, 2023, 3:09pm
13
Hi henrique,
We current have a Avalonia application running on a portrait LCD display (240x320).
But we need to mount the LCD display in Landscape where the current origin is at the bottom-left hand corner
We are looking at different options to rotate the display.
Options
Rotate the UI in software - Which is working, but not ideal at design time
If possible, host the Avalonia application inside a weston window and set the weston.ini (weston-dev.ini) to support the rotate setting.
Open to any other ideas which we can try out
Cheers Jon
Hi @jon2023 !
I would say that the easier way is to configure Weston to rotate the display for you. We have this article that explains how to do so: High performance, low power Embedded Computing Systems | Toradex Developer Center
But keep in mine the tip from @leon.tx :
leon.tx:
But I still didn’t understand why you would want the min/max/close buttons plus the decoration around your application
jon2023
November 29, 2023, 10:34pm
15
Hi there leon, not sure what you mean by “just edit…” edit the docker-compose.yml file to include what exactly?
We trying to resolve two problematic issues, the orientation & touch support and looking to eliminate if its a configuration issue, i.e. is the weston.ini correctly working to apply the rotate setting and is the touch device tree overlay applied and working. The (weston) “window” examples show these are work ok, but the Avalonia (wizard) example (with TorizonCore v5.7.1) show issues.
Showing that the (weston) “window” is working for both the orientation and touch is a useful diagnostic step in eliminating the setup/config.
It seems that the suggestion to upgrade to Torizon OS 6.x.y might help with both of these issues which are currently looking into.
Cheers Jon
leon.tx
November 30, 2023, 12:35pm
16
Hi Jon,
quite literally to open up the generated docker-compose.yml file (after setting up a project) and paste the command: --developer line under the weston: service, like so
weston:
Again, you’re not gonna get a weston service with the Frambuffer example, because it just draws things on screen without a compositor (which is weston). The --developer flag makes the title bars etc appear on the screen just as you want.
Let us know how it goes!
jon2023
December 1, 2023, 1:26pm
17
Hi there,
The generated docker-compose.yml file (from the Analonia wizard) don’t seem to have the “weston:…” section (under the services: node)…
Or is there something I’m missing?
version: "3.9"
services:
avalonia13-debug: <---
build:
context: .
environment:
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
- type: bind
source: /dev/input
target: /dev/input
- type: bind
- type: bind
- type: bind
- type: bind
- type: bind
- type: bind
devices:
- "/dev/gpiochip0"
- "/dev/gpiochip1"
- "/dev/gpiochip4"
- "/dev/spidev3.0"
cap_add:
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 4:1 rmw"
- "c 13:* rmw"
- "c 226:* rmw"
- "c 199:* rmw"
# ... for /dev/fb0
- "c 29:* rmw"
- "c 6:* rmw"
avalonia13: <---
build:
context: .
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 226:* rmw"
- "c 199:* rmw"
# ... for /dev/fb0
- "c 29:* rmw"
Hi @jon2023 !
I just created a project from the “.Net 6 C# Avalonia GTK MVVM” Torizon IDE template and the docker-compose.yml isn’t similar to yours.
Here it is:
version: "3.9"
services:
apagar-debug:
build:
context: .
image: ${LOCAL_REGISTRY}:5002/apagar:${TAG}
ports:
- 2223:2223
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
depends_on: [
weston
apagar:
build:
context: .
image: ${DOCKER_LOGIN}/apagar:${TAG}
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
# ... for tty0
- "c 4:0 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
depends_on: [
weston
# TODO: we are using bullseye here because an issue with xwayland on bookworm
weston:
image: torizon/weston${GPU}:2
environment:
- ACCEPT_FSL_EULA=1
network_mode: host
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /dev
target: /dev
- type: bind
source: /run/udev
target: /run/udev
cap_add:
# ... for tty0
- "c 4:0 rmw"
# ... for tty1
- "c 4:1 rmw"
# ... for tty7
- "c 4:7 rmw"
- "c 13:* rmw"
- "c 199:* rmw"
- "c 226:* rmw"
As you can see, there is a weston container, which isn’t present in your docker-compose.yml.
So I would guess you are not following @leon.tx ’s advice.
