AutoRun shortcut not executing
I have a Colibri VF61 running CE 6.0 and somehow the shortcut in the \FlashDisk\AutoRun\ folder no longer is run on bootup. Once the system is up and running, I can run the shortcut manually with no problems. The shortcut runs a .bat file also on the FlashDisk but in a “User” folder. Is there a way to check if Launcher.exe is being run?
What version of image do you use? Does the application run if you run the shortcut manually?
I’m running v 1.3 beta 4, and yes, the application runs fine if I manually run the shortcut from the AutoStart folder.
Can you try putting exe inside auto run. Does it run then?
