I have created production image and pushed to docker hub. I can run the application from the terminal using the following command.
/usr/bin/docker-compose -p torizon up -d --remove-orphans
I had copied my docker-compose.yml file to /var/sota/storage/docker-compose. Still I am not able to run the application on start up.
I am including both docker-compose.yml and tgicp.service that I had created to run the application on start up.
tgicp.service (276 Bytes)
Pramod
docker-compose.yml (798 Bytes)
Hi Pramod,
To ensure your application runs at startup, please verify the following steps:
Correct Placement of docker-compose.yml
: Ensure that your docker-compose.yml
file is correctly placed in the /var/sota/storage/docker-compose/
directory.
Permissions: Check the permissions of the docker-compose.yml
file to ensure it is readable by the system. You can set the appropriate permissions using:
sudo chmod 644 /var/sota/storage/docker-compose/docker-compose.yml
Systemd Services: Verify that the docker-compose
systemd service is enabled and running. You can check the status with:
systemctl status docker-compose
If it is not active, you can enable and start it with:
sudo systemctl enable docker-compose
sudo systemctl start docker-compose
Docker Service: Ensure that the Docker service itself is running, as it is required for the docker-compose
service to function. Check the status with:
If it is not active, enable and start it with:
Logs: Check the logs for any errors that might indicate why the container is not starting. You can view the logs with:
journalctl -u docker-compose
By following these steps, you should be able to diagnose and resolve the issue preventing your application from running at startup.
Toradex AI Assistant
Hi Pramod
You can just set the container to restart=always
Then you can start the container the same as before and it should restart automatically on start up.
You don’t need an additional service for this.
docker-compose.yaml (838 Bytes)
You can check this page for more details.
Hi Allan,
Thanks for the update, I will make the necessary changes and will check if that works for me.
Pramod
Hi Alan,
The changes you asked to do was working fine. But after few days it stopped working.
docker-compose.txt (1.1 KB)
Attached here is my docker compose file. When I checked the logs of device with docker-compose logs -f I found the following error.
torizon-pyside2-1 | Failed to create wl_display (No such file or directory)
torizon-pyside2-1 | qt.qpa.plugin: Could not load the Qt platform plugin “wayland” in “” even though it was found.
torizon-pyside2-1 | This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
What could be the reason of this behavior?
Pramod
