We are running some tests on our imx8-mini and when we run
cat /proc/asound/cards
we see the cards and we can also test them with speaker-test. Until then everything works.
The problem is that we use docker to run weston image and cog/chromium browser, and when we do that no Audio output is working. Did you have similar problems with this?
Do we need to mount any volumes on Docker image ?
Or do we need to install additional applications in the image itself?
