AssertionError: Found more than one *torizoncore-builder* container
Just fired up torizoncore-builder after about a month and get this error trying to build a new image:
$ torizoncore-builder build
Building image as per configuration file 'tcbuild.yaml'...
=>> Handling input section
Fetching URL 'https://artifacts.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/release/10/apalis-imx6/torizon-upstream/torizon-core-docker/oedeploy/torizon-core-docker-apalis-imx6-Tezi_5.4.0+build.10.tar' into '/tmp/torizon-core-docker-apalis-imx6-Tezi_5.4.0+build.10.tar'
Download Complete!
Downloaded file name: '/tmp/torizon-core-docker-apalis-imx6-Tezi_5.4.0+build.10.tar'
No integrity check performed because checksum was not specified.
Unpacking Toradex Easy Installer image.
Copying Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision aac19948c59d43bb53d21f83274d58141ccc9cab414889c08582ca2f33b76a3f from local repository...
1091 metadata, 12751 content objects imported; 412.6 MB content written
Unpacked OSTree from Toradex Easy Installer image:
  Commit checksum: aac19948c59d43bb53d21f83274d58141ccc9cab414889c08582ca2f33b76a3f
  TorizonCore Version: 5.4.0+build.10
=>> Handling customization section
=> Setting splash screen
splash screen merged to initramfs
=> Handling device-tree subsection
=> Selecting custom device-tree 'device-trees/dts-arm32/imx6q-apalis-tarform-BIU-v01.dts'
'imx6q-apalis-tarform-BIU-v01.dts' compiles successfully.
warning: removing currently applied device tree overlays
Device tree imx6q-apalis-tarform-BIU-v01.dtb successfully applied.
=> Setting kernel arguments
'custom-kargs_overlay.dts' compiles successfully.
Overlay custom-kargs_overlay.dtbo successfully applied.
Kernel custom arguments successfully configured with "video=HDMI-A-1:800x800R@60e".
=>> Handling output section
Applying changes from STORAGE/splash.
Applying changes from STORAGE/dt.
Applying changes from WORKDIR/releaseCandidate.
Applying changes from WORKDIR/007.
Commit 50f3e96bf5039fed178c243ad501133cebf53d9d667c6122bd0245c8125e21c3 has been generated for changes and is ready to be deployed.
Deploying commit ref: founders-dev-branch
Pulling OSTree with ref founders-dev-branch from local archive repository...
  Commit checksum: 50f3e96bf5039fed178c243ad501133cebf53d9d667c6122bd0245c8125e21c3
  TorizonCore Version: 5.4.0+build.10-tcbuilder.20220603143912
  Default kernel arguments: quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
1099 metadata, 12912 content objects imported; 467.8 MB content written
Pulling done.
Deploying OSTree with checksum 50f3e96bf5039fed178c243ad501133cebf53d9d667c6122bd0245c8125e21c3
Deploying done.
Copy files not under OSTree control from original deployment.
Packing rootfs...
Packing rootfs done.
Updating TorizonCore image in place.
Bundling images to directory bundle_20220603143926_850171.tmp
Removing output directory 'v2-BIU-rc2' due to build errors
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
  File "/builder/torizoncore-builder", line 213, in <module>
    mainargs.func(mainargs)
  File "/builder/tcbuilder/cli/build.py", line 469, in do_build
    build(args.config_fname, args.storage_directory,
  File "/builder/tcbuilder/cli/build.py", line 455, in build
    raise exc
  File "/builder/tcbuilder/cli/build.py", line 444, in build
    handle_output_section(
  File "/builder/tcbuilder/cli/build.py", line 300, in handle_output_section
    handle_bundle_output(
  File "/builder/tcbuilder/cli/build.py", line 348, in handle_bundle_output
    "host_workdir": common.get_host_workdir()[0],
  File "/builder/tcbuilder/backend/common.py", line 456, in get_host_workdir
    container_id = get_own_container_id(docker_client)
  File "/builder/tcbuilder/backend/common.py", line 440, in get_own_container_id
    assert container_id is None, \
I only see 1 container running:
Greetings @ed-bear,
I’m not running into this issue on my side. Are you using the latest setup script from: GitHub - toradex/tcb-env-setup: TorizonCore Builder Environment Setup Script
Before you use TorizonCore Builder?
updating the setup script seems to have fixed it.
Glad to hear the issue was resolved!
