I am trying to do external kernel development, i.e. I cloned the kernel sources and try to build them using a toolchain generated with openembedded.
To generate the toolchain I did:
cd ~/oe-core/
. export
bitbake -k angstrom-lxde-image -c populate_sdk
cd ../deploy/sdk/
./angstrom-glibc-x86_64-armv7at2hf-neon-v2016.12-toolchain.sh -S -d ${HOME}/oe-core/sdk
To build the kernel I did in another terminal session:
cd ~/oe-core/colibri-t30-kernel-sources/
. ~/oe-core/sdk/environment-setup-armv7at2hf-neon-angstrom-linux-gnueabi
make colibri_t30_defconfig
make -j3 uImage 2>&1 | tee build.log
This results in:
Makefile:657: "WARNING: Appending $KCFLAGS (--sysroot=/home/lars.moellendorf/oe-core/sdk/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi) from environment to kernel $CFLAGS"
CHK include/linux/version.h
HOSTCC scripts/basic/fixdep
CHK include/generated/utsrelease.h
make[1]: 'include/generated/mach-types.h' is up to date.
HOSTCC scripts/kallsyms
HOSTCC scripts/genksyms/genksyms.o
CC scripts/mod/empty.o
HOSTCC scripts/mod/mk_elfconfig
MKELF scripts/mod/elfconfig.h
HOSTCC scripts/mod/file2alias.o
HOSTCC scripts/pnmtologo
HOSTCC scripts/genksyms/lex.lex.o
HOSTCC scripts/conmakehash
HOSTCC scripts/bin2c
HOSTCC scripts/recordmcount
HOSTCC scripts/genksyms/parse.tab.o
HOSTLD scripts/genksyms/genksyms
HOSTCC scripts/mod/modpost.o
HOSTCC scripts/mod/sumversion.o
HOSTLD scripts/mod/modpost
CC kernel/bounds.s
GEN include/generated/bounds.h
CC arch/arm/kernel/asm-offsets.s
GEN include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CC init/main.o
HOSTCC usr/gen_init_cpio
CC arch/arm/vfp/vfpmodule.o
GEN usr/initramfs_data.cpio
AS usr/initramfs_data.o
LD usr/built-in.o
arm-angstrom-linux-gnueabi-ld: -Wl,-O1: unknown option
arm-angstrom-linux-gnueabi-ld: use the --help option for usage information
make[1]: *** [scripts/Makefile.build:373: usr/built-in.o] Error 1
make: *** [Makefile:945: usr] Error 2
make: *** Waiting for unfinished jobs....
AS arch/arm/vfp/entry.o
AS arch/arm/vfp/vfphw.o
CC arch/arm/vfp/vfpsingle.o
CC init/do_mounts.o
make[1]: *** [scripts/Makefile.build:305: init/main.o] Error 1
make[1]: *** Waiting for unfinished jobs....
CC arch/arm/vfp/vfpdouble.o
make: *** [Makefile:945: init] Error 2
LD arch/arm/vfp/vfp.o
make[1]: *** [scripts/Makefile.build:427: arch/arm/vfp/vfp.o] Error 1
make: *** [Makefile:945: arch/arm/vfp] Error 2
Here some more information:
echo $ARCH
arm
echo $CC
arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard --sysroot=/home/lars.moellendorf/oe-core/sdk/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
echo $LD
arm-angstrom-linux-gnueabi-ld --sysroot=/home/lars.moellendorf/oe-core/sdk/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi
What might be the problem here?
