Colibri IMX8QXP 2GB V1.0D
Col Eva board V3.2B
Linux BSP 5.7.0
Hi, we have built .netcore based app as an app container on Toradex core, other containers used are therndgroup/kiosk-mode-browser-vivante-cog:2 and torizon/weston-vivante:2.5.1. It works just fine at the 5.2 torizon-core but recently we upgrade the torizon-core to 5.7 so that we can use the secure offline update features.
After the torizon-core upgrading, the weston and cog containers autostart as normal, but the app container doesn’t autostart by docker-compose system service. I can SSH into the module and use docker run --privileged [image ID] to start the app container, but the GUI doesn’t show up in the cog browser.
Please check the attached docker-compose file for container configuration detail. I’d like to know what configuration modification I need to fix this issue. Thanks! docker-compose-production.yml (3.1 KB)
ERROR: for cxldnabit_web “host” network_mode is incompatible with port_bindings
ERROR: for cxldnabit “host” network_mode is incompatible with port_bindings
File “/usr/bin/docker-compose”, line 12, in
sys.exit(main())
File “/usr/lib/python3.8/site-packages/compose/cli/main.py”, line 81, in main
command_func()
File “/usr/lib/python3.8/site-packages/compose/cli/main.py”, line 203, in perform_command
handler(command, command_options)
File “/usr/lib/python3.8/site-packages/compose/metrics/decorator.py”, line 18, in wrapper
result = fn(*args, **kwargs)
File “/usr/lib/python3.8/site-packages/compose/cli/main.py”, line 1186, in up
to_attach = up(False)
File “/usr/lib/python3.8/site-packages/compose/cli/main.py”, line 1166, in up
return self.project.up(
File “/usr/lib/python3.8/site-packages/compose/project.py”, line 697, in up
results, errors = parallel.parallel_execute(
File “/usr/lib/python3.8/site-packages/compose/parallel.py”, line 108, in parallel_execute
raise error_to_reraise
File “/usr/lib/python3.8/site-packages/compose/parallel.py”, line 206, in producer
result = func(obj)
File “/usr/lib/python3.8/site-packages/compose/project.py”, line 679, in do
return service.execute_convergence_plan(
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 559, in execute_convergence_plan
return self._execute_convergence_create(
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 473, in _execute_convergence_create
containers, errors = parallel_execute(
result = func(obj)
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 478, in
lambda service_name: create_and_start(self, service_name.number),
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 457, in create_and_start
container = service.create_container(number=n, quiet=True)
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 330, in create_container
container_options = self._get_container_create_options(
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 939, in _get_container_create_options
container_options[‘host_config’] = self._get_container_host_config(
File “/usr/lib/python3.8/site-packages/compose/service.py”, line 1014, in _get_container_host_config
return self.client.create_host_config(
File “/usr/lib/python3.8/site-packages/docker/api/container.py”, line 596, in create_host_config
return HostConfig(*args, **kwargs)
File “/usr/lib/python3.8/site-packages/docker/types/containers.py”, line 336, in init
raise host_config_incompatible_error(
docker.errors.InvalidArgument: “host” network_mode is incompatible with port_bindings
@jeremias.tx After some search, I figured out that with the newer docker version I need to remove the “port:” section in order to use “network mode: host”. After doing that, the app container starts as desired. Thanks!.
