I am not getting any compiler or linker error but these two lines are not doing anything when starting debugging and I am not able to use the CAN Interface.
When I set up the CAN Interface and Bitrate over SSH prior, I can send CAN Messages.
I am guessing this is due to missing root privileges in the Docker container:
In order to run a container with a certain user you typically need to set this in the Dockerfile. There’s a property called USER you can set like so:
USER root
Whatever the user set here will be the user used when the container is ran. More information about this property can be found here: Dockerfile reference | Docker Documentation
Thank you for your help. Unfortunately this did not help. I put “USER root” at different points in the Dockerfile but the outcome was still the same.
I am still guessing this may work by changing the $SSHUSERNAME Variable in the Dockerfile.debug file.
It prompts me to input a password but the default password doesnt work.
This is the console log when I try to change it to “root”:
* Executing task: ssh -i /home/xlukem/cppapollotest/.conf/id_rsa -p 2230 -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no torizon@192.168.178.104 rm -rf ~/app
Warning: Permanently added '[192.168.178.104]:2230' (ECDSA) to the list of known hosts.
torizon@192.168.178.104's password:
thanks for trying the ApolloX!
We updated our templates to be possible to run the application in debug mode with other user than the default torizon user.
For now it is not possible to update projects created with previous versions of the templates. Then create a new cppConsole project and copy only the code from your old project into this new one. We are working in a mechanism to do this template update from created projects automatically. Thank you for understanding.
With the new project you should have the following properties in the .vscode/settings.json file:
Thank you very much for your help and fast reply!
I set up a new project, changed the parameters and can now use root privileges inside of my Docker container and the libsocketcan library accordingly.
