Hallo,
Today i had a look at the Multicontainer Project Template in ApolloX. And i was surprised that the workspace file uses absolute path.
"folders": [
"path": "."
"path": "/home/USER/repos/ApolloX_Multi/ApolloXMulti/Frontend"
"path": "/home/USER/repos/ApolloX_Multi/ApolloXMulti/Backend"
This makes collaborating quite difficult. I hob it will be changed soon so we can move forward with our project.
Simon
Hi @SimonBaur ,
I’ve passed your concern to the extension team and it will be analyzed. If there is any updates on this we’ll post here.
Lucas Akira
Hi @SimonBaur
A quick update: the R&D team is executing some tests with the modification to use relative paths.
Soon enough we will have more information about it.
And thanks for bringing up this topic
Hallo @henrique.tx
Thank you for passing the issue along
Simon
Hi @SimonBaur !
The Torizon IDE version 2.4.0 and newer should have this issue fixed. Could you please test on your side?
