ApolloX - docker-compose build error in Node.js project
I installed ApolloX on my Ubuntu 22.04 machine (Virtualbox Guest OS) and I followed the documentation here.
I created the project from template TypeScript / Node.js
When I try to debug the project, the task build-container-torizon-debug-arm64 fails with the following error:
*  Executing task: sshpass -p mypassword ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no torizon@192.168.1.99 LOCAL_REGISTRY=10.0.2.15 TAG=arm64 GPU= docker-compose down --remove-orphans
Warning: Permanently added '192.168.1.99' (ED25519) to the list of known hosts.
time="2022-12-22T10:10:08Z" level=warning msg="The \"DOCKER_LOGIN\" variable is not set. Defaulting to a blank string."
Container torizon-weston-1  Stopping
Container torizon-kiosk-1  Stopping
Container torizon-nextjs-verdin-1  Stopping
Container torizon-nextjs-verdin-1  Stopped
Container torizon-nextjs-verdin-1  Removing
Container torizon-nextjs-verdin-1  Removed
Container torizon-weston-1  Stopped
Container torizon-weston-1  Removing
Container torizon-weston-1  Removed
Container torizon-kiosk-1  Stopped
Container torizon-kiosk-1  Removing
Container torizon-kiosk-1  Removed
Network torizon_default  Removing
Network torizon_default  Removed
*  Executing task: docker-compose build --build-arg SSHUSERNAME=torizon --build-arg IMAGE_ARCH=arm64 --build-arg SSH_DEBUG_PORT=2229 apollox-nextjs-debug
execvp(3) failed.: Permission denied
*  The terminal process "docker-compose 'build', '--build-arg', 'SSHUSERNAME=torizon', '--build-arg', 'IMAGE_ARCH=arm64', '--build-arg', 'SSH_DEBUG_PORT=2229', 'apollox-nextjs-debug'" failed to launch (exit code: 1).
From the command line I can connect to the module in SSH
Hey @vix
can you run docker without sudo? Try on a new terminal:
docker run --rm -it hello-world
The extension expects that your default user is in the Docker group and that it is possible to run docker without sudo. Please follow this Docker Engine post-installation steps | Docker Documentation . We will add a note about this on the documentation (it’s missing).
I had installed here the VBox to try the same environment and I was able to debug the application successfully. But I had to allow the ports 8090 and 5002 on the windows firewall (for inbound and outbound):
These are used on the device to get the Docker image from the local registry (inside the VM) (I’m using bridge network on my VM).
Let me know if this works on your side.
I confirm that I can run docker without sudo.
Moreover I created the two rules to allow ports 8090 and 5002 on the windows firewall for my Host Windows 10 machine (Guest VM is Ubuntu 22.04), but I have the same error.
It comes to my mind that I can connect to the Verdin in ssh; the username is torizon but the password is a custom one (I had to change at the first connection).
Is this the same for your test environment?
Hi @vix ,
sorry for the delay. Yeah, the password change is mandatory on the first login. Could you also try to run on your VM:
docker-compose --version
Looks like there is something wrong with local docker-compose
Here is what I get with docker-compose --version
docker-compose version 1.29.2, build unknown
I found another issue related to different releases of docker-compose, discussed here. Not sure if this helps.
Hi @vix
sorry for the delay. We have decided not to use docker-compose anymore ( that is now called Compose standalone Install the Compose standalone | Docker Documentation ), since it is no longer the way recommended by Docker. The standard now is the Compos plugin ( Install the Compose plugin | Docker Documentation ). We had changed it also in the templates this last week.
Could you create a new project from a fresh template after install the Compose plugin to test? Maybe that solves the issue, let me know …
Hi @matheus.castello
after I created a new project, now the step copy-docker-compose fails with this error
sshpass -p  scp -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /home/ubuntu/newproject/docker-compose.yml torizon@192.168.1.99:~/
Hi @vix !
We can see that your sshpass command has no actual password after the -p option.
Adding "torizon_psswd": "xablau" to the project’s settings.json might help you (please replace xablau with your actual password).
I am just not sure that this is the “right” way of solving it.
You can of course try :slight_smile:
Hey @vix
sorry for the delay. As @henrique.tx said adding torizon_psswd might do the trick. But that must have been a side effect of one of our break changes that changed the device storage mechanism. Could you please uninstall and reinstall the extension. If the previously registered devices are still listed, I also ask that you to remove and register them again. Once a device is set as default settings.json data is automatically set.
Sorry for the inconvenience.
Hi @vix ,
Did the suggested method from Matheus work for you?
Let us know.
Kevin
Hi @kevin.tx
sorry but I had to switch to an urget project in the past few days.
I hope I can work on this next week.
Hi @henrique.tx , @matheus.castello and @kevin.tx
I can share an update on this topic.
After having uninstalled and reinstalled ApolloX, I remove and registered again my Verdin device.
I see that, while regikstering, the settings.json is automatically filled with host_ip, torizon_ip, torizon_login, torizon_passw, …
Now it’s the task pull-container-torizon-debug-arm64 that fails
Executing task: sshpass -p mypassword ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no torizon@10.1.3.66 LOCAL_REGISTRY=10.0.2.15 TAG=arm64 docker-compose pull node-to-del-debug
Warning: Permanently added '10.1.3.66' (ED25519) to the list of known hosts.
time="2023-02-15T11:56:21Z" level=warning msg="The \"DOCKER_LOGIN\" variable is not set. Defaulting to a blank string."
node-to-del-debug Pulling
node-to-del-debug Warning
WARNING: Some service image(s) must be built from source by running:
    docker compose build %s node-to-del-debug
Error response from daemon: Get "https://10.0.2.15:5002/v2/": dial tcp 10.0.2.15:5002: connect: connection refused
I can say that
  • 10.0.2.15 is the ip of my host
  • 10.1.3.66 is the ip of Verdin.
  • node-to-del is the name of node.js project I’ve been working on
I think I have one interesting information on why this fails.
I see the error
that refers to https protocol.
But if I enter http://10.0.2.15:5002/v2/ (without the secure s) into my browser, I get an answer.
If I enter https I get no answer.
Is it necessary that ApolloX configures the local registry to allow unsecure connections too?
Or is it necessary some other settings to have https working on local registry?
Hey @vix
good catch, yeah, it should add the insecure registries (the development machine IP) on the target dev board /etc/docker/daemon.json, during the device discover and registry.
Could you please report to us the content of this file /etc/docker/daemon.json from your dev board?
Thanks in advance,
Today the IPs are different, because my PC has several ethernet interfaces, as shown here
    docker compose build %s node-backend-debug
Error response from daemon: Get "http://10.10.10.79:5002/v2/": dial tcp 10.10.10.79:5002: connect: connection refused
The content of /etc/docker/daemon.json is
   "insecure-registries" : ["10.10.10.79:5002"]
But the problem I can see is that 10.10.10.79 is one of the IPs of my development machine, but the corresponding ethernet adapter is NOT connected to Verdin.
Today Verdin is connected through DHCP-assigned IP (that today is 10.1.2.50) with mask 255.255.0.0
For this reason I did the folowing changes:
  • in setings.json of the node.js project on my development machine I changed “host_ip”: “10.10.10.79” to “host_ip”: “10.1.2.50”
  • on the Verdin I changed the content of /etc/docker/daemon.json to
   "insecure-registries" : ["10.1.2.50:5002"]
Now the error is a little bit different
Error response from daemon: Get "https://10.1.2.50:5002/v2/": http: server gave HTTP response to HTTPS client
 *  The terminal process "sshpass '-p', 'cemb', 'ssh', '-o', 'UserKnownHostsFile=/dev/null', '-o', 'StrictHostKeyChecking=no', 'torizon@10.1.3.66', 'LOCAL_REGISTRY=10.1.2.50 TAG=arm64 docker-compose pull node-backend-debug'" terminated with exit code: 18.
I hope that this helps
ok, I see that you changed the address to 10.1.2.50:5002 in the /etc/docker/daemon.json, but to make effect you need to also run:
sudo systemctl restart docker
This should work, let me know.
It works.
What is the conclusion of this topic?
Is it necessary some change in ApolloX or should I always do some manual chnage to the files?
Hey @vix,
this can be improved, I will take it to the team, and we’ll think about solutions. We should add some mechanism to check these points before starting to build and deploy, and possible automatically update the data on the target device and settings.json.
I will let you know when we have something published, thanks.
