I’ve been trying to create a Next.js ApolloX template.
When I try to debug the container, the first steps are ok, but then I get the following error
Executing task: sshpass -p <password> ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no torizon@192.168.137.68 LOCAL_REGISTRY=192.168.137.1 TAG=arm64 GPU= docker-compose up -d electron2del-debug
Warning: Permanently added '192.168.137.68' (ED25519) to the list of known hosts.
time="2023-02-26T17:05:25Z" level=warning msg="The \"DOCKER_LOGIN\" variable is not set. Defaulting to a blank string."
weston Pulling
weston Error
Error response from daemon: Get "https://registry-1.docker.io/v2/": x509: certificate has expired or is not yet valid: current time 2023-02-26T17:05:27Z is before 2023-05-05T00:00:00Z
The time “2023-02-26T17:05:25Z” seems suspicious to me, because today id “2023-06-26”, so four months later than this time.
Where does it come from?
Hi @jeremias.tx
I work with WSL, and restarting docker (sudo systemctl restart docker both on WSL and on the SoM) doesn’t fix the issue.
I confirm that the time is four months before than the real timestamp.
Today it’s
You’re on a Windows machine then yes? In that case did you only restart docker in WSL or did you restart Docker Desktop on Windows itself? Every thread I find regarding this time mismatch issue seems to suggest that restarting Docker Desktop should fix the issue, for example this thread: https://github.com/docker/for-win/issues/4526
That said I’m not sure if there’s a way to prevent the issue from happening altogether. You’ve been using Docker on this machine for a while yes? Was it only recently the time got mismatched? Did you do or change something recently that might have caused this?
