We have Virtual Cluster project. We will design the SBC as a PMIC for battery connection. What is the max current consumption of Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth IT at full load ?
Maximum power consumption of Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth IT at full load (full stress, iperf3 eth, iperf3 wifi and glmark) is around 18Watt.
We are planning to use FS8424 SBC for battery connection and supplying the Apalis Module. We use VPRE pin of SBC to supply Apalis. DU you advice to use this SBC ? We consider PGOOD of SBC to connect to Apalis Module GPIO. Thanks.
Unfortunately I’m not familiar with FS8424.
