When I try to update the TK1 with run setethupdate
on my local developer machine the second stage flash image file apalis-tk1/flash_eth.img
is not loaded for some reason. (I use the same tftp server setup as described in the wiki.)
Apalis TK1 # setenv 10.0.1.19
Apalis TK1 # setenv serverip 10.0.1.19
Apalis TK1 # setenv autoload false; if env exists ethaddr; then; else setenv ethaddr 00:14:2d:00:00:00; fi; pci enum; dhcp;
BOOTP broadcast 1
DHCP client bound to address 10.0.2.40 (1 ms)
Apalis TK1 # run setethupdate
Using e1000#0 device
TFTP from server 10.0.1.19; our IP address is 10.0.2.40
Filename 'flash_eth.img'.
Load address: 0x81000000
Loading: ################################################## 444 Bytes
26.4 KiB/s
done
Bytes transferred = 444 (1bc hex)
## Executing script at 81000000
Filename 'apalis-tk1/flash_eth.img'.
Loading: T T
Abort
All files are present in the tftp directory and other single files like e.g. the MBR from the <tftp-root>/apalis-tk1
directory can be loaded (command from update_1
in flash_eth.scr
Apalis TK1 # tftpboot ${loadaddr} apalis-tk1/mbr.bin && mmc dev 0 0 && mmc write ${loadaddr} 0x0 0x1
Filename 'apalis-tk1/mbr.bin'.
Loading: ################################################## 512 Bytes
44.9 KiB/s
done
Bytes transferred = 512 (200 hex)
switch to partitions #0, OK
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
Apalis TK1 #
If I use a tftp client ( sudo apt-get install tftp
) on the same local machine I can get both flash_eth.img
files without any problems (means the tftp server should not be the problem):
tftp> get 10.0.1.19:flash_eth.img
Received 450 bytes in 0.0 seconds
tftp> get 10.0.1.19:apalis-tk1/flash_eth.img
Received 2507 bytes in 0.1 seconds
tftp> get 10.0.1.19:apalis-tk1/mbr.bin
Received 512 bytes in 0.3 seconds
What could be the reason for that?
I suspect either some misconfiguration or otherwise network issue. Does the link LED light up during that second TFT transfer?
Here how my preparation looks like:
[user@host Apalis-TK1_LXDE-Image_2.7.3]$ ./update.sh -o /var/lib/tftpboot/
Apalis TK1 rootfs detected
Image file apalis-tk1.img has been successfully generated!
Creating MBR file and do the partitioning
0+0 records in
0+0 records out
0 bytes copied, 8.9586e-05 s, 0.0 kB/s
Model: (file)
Disk /home/zim/Toradex/Linux/Releases/2.7b3/Apalis-TK1_LXDE-Image_2.7.3/apalis-tk1_bin/mbr.bin: 30760960s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 8192s 40959s 32768s primary lba
2 40960s 30719999s 30679040s primary
Creating VFAT partition image with the kernel
mkfs.fat 4.1 (2017-01-24)
mkfs.fat: warning - lowercase labels might not work properly with DOS or Windows
Creating rootfs partition image
735+0 records in
735+0 records out
770703360 bytes (771 MB, 735 MiB) copied, 0.278934 s, 2.8 GB/s
mke2fs 1.43.3 (04-Sep-2016)
Discarding device blocks: done
Creating filesystem with 188160 4k blocks and 47040 inodes
Filesystem UUID: 34466114-6be6-4f9e-b0b9-0d5f7cc9b630
Superblock backups stored on blocks:
32768, 98304, 163840
Allocating group tables: done
Writing inode tables: done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
tune2fs 1.43.3 (04-Sep-2016)
Setting maximal mount count to -1
Setting interval between checks to 0 seconds
Successfully copied data to target folder.
To flash the Apalis/Colibri T20/T30/TK1 module a running U-Boot is required. Boot
the module to the U-Boot prompt and
insert the SD card, USB flash drive or when using TFTP connect Ethernet only
and enter:
'run setupdate'
then to update all components enter:
'run update'
Alternatively, to update U-Boot enter:
'run update_uboot'
to update a component stored in UBI enter:
'run prepare_ubi' (for Colibri T20)
followed by one of:
'run update_kernel'
'run update_fdt' (for device tree enabled kernels)
'run update_rootfs'
If you don't have a working U-Boot anymore, connect your PC to the module's USB
client port, bring the module into the recovery mode and start the update.sh
script with the -d option. This will copy U-Boot into the module's RAM and
execute it.
And on the target:
U-Boot 2016.11-2.7.3+gf0e4149 (Jun 30 2017 - 23:28:22 +0200)
TEGRA124
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Apalis TK1 2GB V1.1A, Serial# 02864654
Net: No ethernet found.
Hit any key to stop autoboot: 1 0
Apalis TK1 # run setupdate
MMC: no card present
** Bad device mmc 1 **
** Bad device mmc 2 **
starting USB...
USB0: USB EHCI 1.10
USB1: USB EHCI 1.10
USB2: USB EHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 3 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
** Bad device usb 0 **
e1000: no NVM
TFTP from server 192.168.10.1; our IP address is 192.168.10.2
Loading: *################################################## 444 Bytes
0 Bytes/s
done
Loading: *################################################## 2.4 KiB
0 Bytes/s
done
Bytes transferred = 2479 (9af hex)
enter "run update" to update the entire module
I have the Apalis Eval Board and the host machine both connected to a switch…
Yes it does light up during the attempt for the second TFT transfer.
The RESET MOCI# led on the Apalis Eval board is lighting up all the time but I think that should not have an impact. (The u-boot version on the SOM seems to be a patched one already.)
The permissions should be ok as well in the tftp root
ll /srv/tftp/
total 24
drwxrwxr-x 3 tftp nogroup 4096 Sep 20 16:05 ./
drwxr-xr-x 3 root root 4096 Sep 20 16:04 ../
drwxrwxr-x 2 tftp nogroup 4096 Sep 20 16:05 apalis-tk1/
-rwxrwxr-x 1 tftp nogroup 710 Sep 20 16:08 flash_blk.img*
-rwxrwxr-x 1 tftp nogroup 444 Sep 20 16:08 flash_eth.img*
-rwxrwxr-x 1 tftp nogroup 307 Sep 20 16:08 flash_mmc.img*
and sub directory
ll /srv/tftp/apalis-tk1/
total 912228
drwxrwxr-x 2 tftp nogroup 4096 Sep 20 16:05 ./
drwxrwxr-x 3 tftp nogroup 4096 Sep 20 16:05 ../
-rwxrwxr-x 1 tftp nogroup 594944 Sep 20 16:08 apalis-tk1.img*
-rwxrwxr-x 1 tftp nogroup 16777216 Sep 20 16:08 boot.vfat*
-rwxrwxr-x 1 tftp nogroup 2723 Sep 20 16:08 flash_blk.img*
-rwxrwxr-x 1 tftp nogroup 2479 Sep 20 16:08 flash_eth.img*
-rwxrwxr-x 1 tftp nogroup 512 Sep 20 16:08 mbr.bin*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-100*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-101*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-102*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-103*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-104*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-105*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-106*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-107*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-108*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-109*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-110*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-111*
-rwxrwxr-x 1 tftp nogroup 67108864 Sep 20 16:08 root.ext3-112*
-rwxrwxr-x 1 tftp nogroup 38797312 Sep 20 16:08 root.ext3-113*
-rwxrwxr-x 1 tftp nogroup 49826 Sep 20 16:08 tegra124-apalis-eval.dtb*
-rwxrwxr-x 1 tftp nogroup 5450280 Sep 20 16:08 uImage*
-rwxrwxr-x 1 tftp nogroup 218 Sep 20 16:08 versions.txt*
Me, too. A HP 1820-8G one using a separate VLAN for target to workstation communication.
Strange that it does not transfer the file then. Have you looked at what is going on with a network analyser e.g. wireshark or the like?
Yeah, right. Then you are already using -next stuff I guess as this was a recent change we did also in conjunction with the new V1.2A hardware revision in order to avoid multiple transitions on RESET_MOCI# during system boot. The only thing it would affect on our regular evaluation board is the USB hub. It should not have any effect on gigabit Ethernet operation at all.
I changed the network setup (host machine which runs a dhcp server and is directly connected to Apalis Eval Board) and tried it again with the same result:
e1000: no NVM
0 Bytes/s
done
Loading: T T T T T T T T T T
Retry count exceeded; starting again
Apalis TK1 #
I tried to update another old V1.0B TK1 SOM with old u-boot on it. With again the same result. It must be some kind of tftp server issue. However I check the traffic with wireshark as well now.
The capture shows TFTP Read Requests from the SOM and the host sends the TFTP packet over and over again to the SOM run_setethupdate.pcap…
How about if you manually directly try to download resp. file?
TEGRA124
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Apalis TK1 # setenv ipaddr 192.168.10.2
Apalis TK1 # setenv serverip 192.168.10.1
Apalis TK1 # pci enum
Apalis TK1 # tftpboot ${loadaddr} ${board_name}/flash_eth.img
e1000: no NVM
Loading: ################################################## 2.4 KiB
0 Bytes/s
done
Apalis TK1 #
Does not work either:
Apalis TK1 # tftpboot ${loadaddr} "${board_name}/flash_eth.img" && source ${loadaddr}
TFTP from server 10.0.1.19; our IP address is 10.0.2.84
The file resides in the correct tftp output directory
ll /srv/tftp/apalis-tk1/ | grep flash_eth.img
and the tftp server is serving from this directory:
ps ax | grep tftp
1339 ? Ss 0:00 /usr/sbin/in.tftpd --listen --user tftp --address :69 --secure /srv/tftp
24424 ? S 0:00 /usr/sbin/in.tftpd --listen --user tftp --address :69 --secure /srv/tftp
24428 pts/0 S+ 0:00 grep --color=auto tftp
I could not figure out what is misconfigured yet… even if I restart the tftp server (to get rid of the doubled entries in the ps ax | grep tftp
output) and if I use another root tftp output directory it does not work.
Looking at your IP addresses it seems you are not using a class C network which is probably the default in U-Boot:
Apalis TK1 # echo $netmask
255.255.255.0
Have you updated your netmask accordingly?
I updated it. Makes no difference. (Shouldn’t the load of the first file fail then as well?)
Yeah, you are right. So it rather seems to have to do with the file being served from the root TFTP folder vs. from an additional sub folder, not?
Right, I try to get it flashed somehow… I let you know about any changes in status.
(I can flas another file from the subfolder without any problems. That’s also not the root cause.)
Because the only file from the sub directory which cannot be loaded is apalis-tk1/flash_eth.img
I rebuild it from its source file with sudo ./mk-u-boot-scripts.sh
before deploying the image files into the tftp output directory with ./update.sh -m 2 -o /srv/tftp
(non-Mainliine version of v2.7b3). However the file cannot be loaded.
I uninstalled the TFTP server, its settings, the output directory and made a clean new install and setup. However the file apalis-tk1/flash_eth.img
can still not be loaded. For further root cause analysis I copy pasted the commands from fwd_eth.scr
and from flash_eth.scr
into u-boot to figure out which of the other files can be loaded with the commands and which not.
tftpboot ${loadaddr} "flash_blk.img" && source ${loadaddr}
load passed
tftpboot ${loadaddr} "flash_mmc.img" && source ${loadaddr}
load passed
tftpboot ${loadaddr} "flash_eth.img" && source ${loadaddr}
load passed (just the first file, not the second one)
(apalis-tk1/flash_eth.img) load failed
run update_fdt
(apalis-tk1/tegra124-apalis-eval.dtb) load failed
run update_kernel
(apalis-tk1/uImage) load failed
run update_uboot
(apalis-tk1/apalis-tk1.img) load failed
run update_1
(apalis-tk1/mbr.bin) load passed
run update_2
(apalis-tk1/boot.vfat) load failed
The file permissions of the files are the same, the one thing which is different is the size of the files:
ll /srv/tftp/
drwxrwxr-x 2 root nogroup 4096 Sep 28 11:15 apalis-tk1/
-rwxrwxr-x 1 root nogroup 710 Sep 28 11:22 flash_blk.img*
-rwxrwxr-x 1 root nogroup 444 Sep 28 11:22 flash_eth.img*
-rwxrwxr-x 1 root nogroup 307 Sep 28 11:22 flash_mmc.img*
-rwxrwxr-x 1 root nogroup 594944 Sep 28 11:22 apalis-tk1.img*
-rwxrwxr-x 1 root nogroup 16777216 Sep 28 11:22 boot.vfat*
-rwxrwxr-x 1 root nogroup 2723 Sep 28 11:22 flash_blk.img*
-rwxrwxr-x 1 root nogroup 2479 Sep 28 11:22 flash_eth.img*
-rwxrwxr-x 1 root nogroup 512 Sep 28 11:22 mbr.bin*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-100*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-101*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-102*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-103*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-104*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-105*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-106*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-107*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-108*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-109*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-110*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-111*
-rwxrwxr-x 1 root nogroup 67108864 Sep 28 11:22 root.ext3-112*
-rwxrwxr-x 1 root nogroup 38797312 Sep 28 11:22 root.ext3-113*
-rwxrwxr-x 1 root nogroup 49826 Sep 28 11:22 tegra124-apalis-eval.dtb*
-rwxrwxr-x 1 root nogroup 5450280 Sep 28 11:22 uImage*
-rwxrwxr-x 1 root nogroup 218 Sep 28 11:22 versions.txt*
When I flashed flash_blk.img
and flash_mmc.img
I got some warnings due to some invalid load command. However I am just interested in if the can be flashed at all:
Apalis TK1 # tftpboot ${loadaddr} "flash_blk.img" && source ${loadaddr}
Filename 'flash_blk.img'.
Loading: ################################################## 710 Bytes
62.5 KiB/s
done
Bytes transferred = 710 (2c6 hex)
Card did not respond to voltage select!
Apalis TK1 # tftpboot ${loadaddr} "flash_mmc.img" && source ${loadaddr}
Filename 'flash_mmc.img'.
Loading: ################################################## 307 Bytes
1000 Bytes/s
done
Bytes transferred = 307 (133 hex)
The root cause of this issue was that the “maximum transmission unit” (MTU) of the hosts network interface was set to a high value. Decreasing the value to 1500 solves the problem (e.g. sudo ifconfig eth0 mtu 1500
Yes, I just wanted to suggest you checking that. Wireshark should also have indicated that I assume. Unfortunately I am not quite sure about the exact status of IP fragmentation support and such in U-Boot.
When I flashed flash_blk.img and flash_mmc.img I got some warnings due to some invalid load command.
Yes, they are only intended to be run from a block device or SD/MMC card resp.
