I recently switched to using the Toradex Easy Installer to change firmware for my TK1 on my Apalis Evaluation Board V1.1A because the Toradex documentation now says this is the proper method. Today, I wanted to go back to running a test with an older version. I used the Toradex Easy Installer to install LXDE 2.7b5, however I am getting the following failure:
TEGRA124
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Apalis TK1 2GB V1.1A, Serial# 02937792
Net: No ethernet found.
Booting from internal eMMC chip…
reading tegra124-apalis-eval.dtb
50161 bytes read in 16 ms (3 MiB/s)
reading zImage
** Unable to read file zImage **
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1…
starting USB…
USB0: USB EHCI 1.10
USB1: USB EHCI 1.10
USB2: USB EHCI 1.10
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning bus 2 for devices… 1 USB Device(s) found
USB device 0: unknown device
e1000: no NVM
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 192.168.1.145 (6004 ms)
*** Warning: no boot file name; using ‘C0A80191.img’
etc…
I also now get this same failure if I just try to upgrade using the old method with and SD card and running “set update” “run update”.
The only thing I seem to be able to do now is upgrade to the very latest 2.8b2.97…
How can I go back to an older version now that I have started to use the Easy Installer?
