I’ve been tried write in ploarity file :
root@tegra-ubuntu:~# cd /sys/class/pwm/pwmchip0/
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo 0 > export
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo 1000000 > pwm0/period
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo 500000 > pwm0/duty_cycle
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo 1 > pwm0/enable
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo "normal" > pwm0/polarity
-bash: echo: write error: Function not implemented
I disable pwm and the result is the same:
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo 0 > pwm0/enable
root@tegra-ubuntu:/sys/class/pwm/pwmchip0# echo "inversed" > pwm0/polarity
Can i do this in apalis tk1 ??
