The boot process on some of our Apalis TK1 modules stuck at some point (see attached log). This issue occurs sporadically.
Thanks in advance!
Setup:
Apalis TK1 V1.2A on Ixora Carrier Board (V1.2A) with BSP 3.0.4
Log:
U-Boot 2019.07-3.0.4+g26d926eda0 (Dec 23 2021 - 02:59:10 +0000)
SoC: tegra124
Reset cause: POR
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0400: 2, sdhci@700b0600: 0
In: serial
Out: serial
Err: serial
Model: Toradex Apalis TK1 2GB V1.2A, Serial# 07010519
Net: No ethernet found.
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1243 bytes read in 28 ms (43 KiB/s)
## Executing script at 90000000
69615 bytes read in 40 ms (1.7 MiB/s)
25454712 bytes read in 1003 ms (24.2 MiB/s)
## Flattened Device Tree blob at 87000000
Booting using the fdt blob at 0x87000000
Using Device Tree in place at 87000000, end 87013fee
Starting kernel ...
[ 0.000000] Linux version 5.4.61 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Thu Dec 23 01:57:24 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Apalis TK1 on Apalis Evaluation Board
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 64 MiB at 0xfbc00000
[ 0.000000] percpu: Embedded 20 pages/cpu s50956 r8192 d22772 u81920
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522496
[ 0.000000] Kernel command line: lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 pcie_aspm=off isolcpus=2,3 pex_perst=0 root=PA1
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1952272K/2096128K available (10240K kernel code, 885K rwdata, 3104K rodata, 45056K init, 286K bss, 78320K reserved, 65536K cma-reserved, 1244160K highmem)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] /interrupt-controller@60004000: 160 interrupts forwarded to /interrupt-controller@50041000
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4cc with crng_init=0
[ 0.000000] Tegra clk 127: register failed with -17
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000030] clocksource: timer_us: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000046] Switching to timer-based delay loop, resolution 1000ns
[ 0.000699] clocksource: tegra_suspend_timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.001268] arch_timer: cp15 timer(s) running at 12.00MHz (virt).
[ 0.001287] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2c47f4ee7, max_idle_ns: 440795202497 ns
[ 0.001307] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 4398046511096ns
[ 0.001321] Switching to timer-based delay loop, resolution 83ns
[ 0.001964] Console: colour dummy device 80x30
[ 0.002458] printk: console [tty1] enabled
[ 0.002500] Calibrating delay loop (skipped), value calculated using timer frequency.. 24.00 BogoMIPS (lpj=120000)
[ 0.002535] pid_max: default: 32768 minimum: 301
[ 0.002887] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002920] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003927] CPU: Testing write buffer coherency: ok
[ 0.003983] CPU0: Spectre v2: using ICIALLU workaround
[ 0.004290] /cpus/cpu@0 missing clock-frequency property
[ 0.004330] /cpus/cpu@1 missing clock-frequency property
[ 0.004370] /cpus/cpu@2 missing clock-frequency property
[ 0.004410] /cpus/cpu@3 missing clock-frequency property
[ 0.004433] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005133] Setting up static identity map for 0x80100000 - 0x801000ac
[ 0.005283] rcu: Hierarchical SRCU implementation.
[ 0.008506] Tegra Revision: A01 SKU: 135 CPU Process: 1 SoC Process: 1
[ 0.009598] smp: Bringing up secondary CPUs ...
[ 0.010798] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.010806] CPU1: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[ 0.012399] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.012407] CPU2: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[ 0.022393] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.022401] CPU3: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[ 0.031279] smp: Brought up 1 node, 4 CPUs
[ 0.031302] SMP: Total of 4 processors activated (96.00 BogoMIPS).
[ 0.031323] CPU: All CPU(s) started in SVC mode.
[ 0.032086] devtmpfs: initialized
[ 0.052028] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.052458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.052499] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.053855] pinctrl core: initialized pinctrl subsystem
[ 0.055155] NET: Registered protocol family 16
[ 0.056982] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.058527] cpuidle: using governor menu
[ 0.075097] No ATAGs?
[ 0.075220] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.075261] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.086777] platform 50000000.host1x: Adding to iommu group 0
[ 0.086879] platform 54200000.dc: Adding to iommu group 1
[ 0.086955] platform 54240000.dc: Adding to iommu group 1
[ 0.087051] platform 54340000.vic: Adding to iommu group 2
[ 0.087143] platform 57000000.gpu: Adding to iommu group 3
[ 0.119290] regulator-1v05-avdd-hdmi-pll GPIO handle specifies active low - ignored
[ 0.122147] VCC_USBO1: supplied by 5V_SW
[ 0.122648] VCC_USBH(2A|2C|2D|3|4): supplied by 5V_SW
[ 0.124032] iommu: Default domain type: Translated
[ 0.124242] vgaarb: loaded
[ 0.125074] SCSI subsystem initialized
[ 0.125797] usbcore: registered new interface driver usbfs
[ 0.125889] usbcore: registered new interface driver hub
[ 0.126024] usbcore: registered new device driver usb
[ 0.126278] videodev: Linux video capture interface: v2.00
[ 0.126376] pps_core: LinuxPPS API ver. 1 registered
[ 0.126397] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.126461] PTP clock support registered
[ 0.128044] Advanced Linux Sound Architecture Driver Initialized.
[ 0.128833] Bluetooth: Core ver 2.22
[ 0.128912] NET: Registered protocol family 31
[ 0.128931] Bluetooth: HCI device and connection manager initialized
[ 0.128959] Bluetooth: HCI socket layer initialized
[ 0.128983] Bluetooth: L2CAP socket layer initialized
[ 0.129021] Bluetooth: SCO socket layer initialized
[ 0.129984] clocksource: Switched to clocksource arch_sys_counter
[ 0.701202] NET: Registered protocol family 2
[ 0.702130] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.702212] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.702322] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.702512] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.703048] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.703108] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.703404] NET: Registered protocol family 1
[ 0.704186] RPC: Registered named UNIX socket transport module.
[ 0.704209] RPC: Registered udp transport module.
[ 0.704228] RPC: Registered tcp transport module.
[ 0.704247] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.704271] PCI: CLS 0 bytes, default 64
[ 1.339383] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 1.341390] Initialise system trusted keyrings
[ 1.341644] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ 1.343317] NFS: Registering the id_resolver key type
[ 1.343355] Key type id_resolver registered
[ 1.343374] Key type id_legacy registered
[ 1.378213] Key type asymmetric registered
[ 1.378237] Asymmetric key parser 'x509' registered
[ 1.378389] bounce: pool size: 64 pages
[ 1.378467] io scheduler mq-deadline registered
[ 1.378488] io scheduler kyber registered
[ 1.379269] tegra-xusb-padctl 7009f000.padctl: failed to get regulators: -517
[ 1.380654] tegra-pcie 1003000.pcie: 2x1, 1x1 configuration
[ 1.386677] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.388121] tegra-pmc 7000e400.pmc: emergency thermal reset enabled
[ 1.388967] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.390979] printk: console [ttyS0] disabled
[ 1.391067] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 78, base_baud = 25500000) is a Tegra
[ 2.175834] printk: console [ttyS0] enabled
[ 2.181312] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 79, base_baud = 0) is a TEGRA_UART
[ 2.190616] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 80, base_baud = 0) is a TEGRA_UART
[ 2.199899] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 81, base_baud = 0) is a TEGRA_UART
[ 2.228421] tegra-hdmi 54280000.hdmi: failed to get PLL regulator
[ 2.251823] loop: module loaded
[ 2.255962] tegra-ahci 70027000.sata: 70027000.sata supply ahci not found, using dummy regulator
[ 2.264882] tegra-ahci 70027000.sata: 70027000.sata supply phy not found, using dummy regulator
[ 2.278604] libphy: Fixed MDIO Bus: probed
[ 2.283303] CAN device driver interface
[ 2.287197] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[ 2.294211] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.299947] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.307436] usbcore: registered new interface driver pegasus
[ 2.313253] usbcore: registered new interface driver asix
[ 2.318714] usbcore: registered new interface driver ax88179_178a
[ 2.324886] usbcore: registered new interface driver cdc_ether
[ 2.330822] usbcore: registered new interface driver smsc75xx
[ 2.336642] usbcore: registered new interface driver smsc95xx
[ 2.342471] usbcore: registered new interface driver net1080
[ 2.348190] usbcore: registered new interface driver cdc_subset
[ 2.354187] usbcore: registered new interface driver zaurus
[ 2.359846] usbcore: registered new interface driver cdc_ncm
[ 2.366623] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.373196] ehci-pci: EHCI PCI platform driver
[ 2.377707] tegra-ehci: Tegra EHCI driver
[ 2.386062] tegra-ehci 7d000000.usb: EHCI Host Controller
[ 2.391517] tegra-ehci 7d000000.usb: new USB bus registered, assigned bus number 1
[ 2.399360] tegra-ehci 7d000000.usb: irq 101, io mem 0x7d000000
[ 2.430014] tegra-ehci 7d000000.usb: USB 2.0 started, EHCI 1.10
[ 2.436961] hub 1-0:1.0: USB hub found
[ 2.440798] hub 1-0:1.0: 1 port detected
[ 2.447424] tegra-ehci 7d004000.usb: EHCI Host Controller
[ 2.452877] tegra-ehci 7d004000.usb: new USB bus registered, assigned bus number 2
[ 2.460709] tegra-ehci 7d004000.usb: irq 102, io mem 0x7d004000
[ 2.490005] tegra-ehci 7d004000.usb: USB 2.0 started, EHCI 1.10
[ 2.496861] hub 2-0:1.0: USB hub found
[ 2.500693] hub 2-0:1.0: 1 port detected
[ 2.507311] tegra-ehci 7d008000.usb: EHCI Host Controller
[ 2.512765] tegra-ehci 7d008000.usb: new USB bus registered, assigned bus number 3
[ 2.520620] tegra-ehci 7d008000.usb: irq 103, io mem 0x7d008000
[ 2.550039] tegra-ehci 7d008000.usb: USB 2.0 started, EHCI 1.10
[ 2.556964] hub 3-0:1.0: USB hub found
[ 2.560788] hub 3-0:1.0: 1 port detected
[ 2.565505] usbcore: registered new interface driver cdc_acm
[ 2.571188] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.579262] usbcore: registered new interface driver cdc_wdm
[ 2.585062] usbcore: registered new interface driver usb-storage
[ 2.594967] tegra_rtc 7000e000.rtc: registered as rtc2
[ 2.600145] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 2.606692] i2c /dev entries driver
[ 2.612204] rtc-ds1307 0-0068: oscillator failed, set time!
[ 2.618006] rtc-ds1307 0-0068: registered as rtc0
[ 2.625741] as3722 3-0040: AS3722 with revision 0x1 found
[ 2.638935] +V1.35_VDDIO_DDR(sd3): Bringing 0uV into 1350000-1350000uV
[ 2.646107] +V1.05: Bringing 0uV into 1050000-1050000uV
[ 2.656786] +V1.05_RTC: Bringing 1100000uV into 1000000-1000000uV
[ 2.664256] AVDD_LVDS0_PLL: Bringing 0uV into 1800000-1800000uV
[ 2.671765] VDDIO_SDMMC3: bypassed regulator has no supply!
[ 2.677345] VDDIO_SDMMC3: failed to get the current voltage(-517)
[ 2.683484] as3722-regulator as3722-regulator: regulator 13 register failed -517
[ 2.695378] as3722-rtc as3722-rtc: registered as rtc1
[ 2.700474] as3722-rtc as3722-rtc: RTC interrupt 381
[ 2.708692] usbcore: registered new interface driver uvcvideo
[ 2.714471] USB Video Class driver (1.1.1)
[ 2.718571] gspca_main: v2.14.0 registered
[ 2.724024] tegra-wdt 60005000.timer: initialized (heartbeat = 120 sec, nowayout = 0)
[ 2.733151] sdhci: Secure Digital Host Controller Interface driver
[ 2.739335] sdhci: Copyright(c) Pierre Ossman
[ 2.743838] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.749903] sdhci-tegra 700b0000.sdhci: Got CD GPIO
[ 2.754863] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.760024] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.765167] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.770326] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.783787] sdhci-tegra 700b0400.sdhci: Got CD GPIO
[ 2.788724] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.793890] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.799031] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.804188] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.817658] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.822836] mmc0: Missing autocal timeout 3v3-pad drvs
[ 2.827978] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.833137] mmc0: Missing autocal timeout 1v8-pad drvs
[ 2.847829] usbcore: registered new interface driver usbhid
[ 2.853438] usbhid: USB HID core driver
[ 2.863985] tegra30-i2s 70301200.i2s: DMA channels sourced from device 70300000.ahub
[ 2.873571] tegra-snd-sgtl5000 sound: snd_soc_register_card failed (-517)
[ 2.880941] NET: Registered protocol family 10
[ 2.886723] Segment Routing with IPv6
[ 2.890635] mip6: Mobile IPv6
[ 2.893610] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.901168] NET: Registered protocol family 17
[ 2.905637] NET: Registered protocol family 15
[ 2.910162] can: controller area network core (rev 20170425 abi 9)
[ 2.916531] NET: Registered protocol family 29
[ 2.921028] can: raw protocol (rev 20170425)
[ 2.925316] can: broadcast manager protocol (rev 20170425 t)
[ 2.931020] can: netlink gateway (rev 20190810) max_hops=1
[ 2.936662] Bluetooth: RFCOMM socket layer initialized
[ 2.941856] Bluetooth: RFCOMM ver 1.11
[ 2.945625] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.950993] Bluetooth: BNEP socket layer initialized
[ 2.955976] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.961930] Bluetooth: HIDP socket layer initialized
[ 2.967134] Key type dns_resolver registered
[ 2.972266] Registering SWP/SWPB emulation handler
[ 2.977341] Loading compiled-in X.509 certificates
[ 3.014842] +V3.3: supplied by +V3.3_MXM
[ 3.019653] tegra-xusb-padctl 7009f000.padctl: failed to get regulators: -517
[ 3.027422] tegra-pcie 1003000.pcie: 2x1, 1x1 configuration
[ 3.034133] tegra-hdmi 54280000.hdmi: failed to get PLL regulator
[ 3.040884] tegra-ahci 70027000.sata: 70027000.sata supply ahci not found, using dummy regulator
[ 3.049776] tegra-ahci 70027000.sata: 70027000.sata supply phy not found, using dummy regulator
[ 3.059064] as3722-regulator as3722-regulator: DMA mask not set
[ 3.067330] as3722-sd2: supplied by +V3.3
[ 3.071870] as3722-sd3: supplied by +V3.3
[ 3.076267] as3722-sd4: supplied by +V3.3
[ 3.080663] as3722-sd5: supplied by +V3.3
[ 3.086187] as3722-ldo0: supplied by +V1.35_VDDIO_DDR(sd2)
[ 3.092358] as3722-ldo1: supplied by +V3.3
[ 3.096851] as3722-ldo2: supplied by +V1.8
[ 3.102060] as3722-ldo3: supplied by +V3.3
[ 3.107119] as3722-ldo4: supplied by +V3.3
[ 3.111698] as3722-ldo5: supplied by +V1.8
[ 3.116182] as3722-ldo6: supplied by +V3.3
[ 3.120687] as3722-ldo7: supplied by +V1.8
[ 3.125370] as3722-ldo9: supplied by +V3.3
[ 3.129707] +V3.3_ETH(ldo9): Bringing 0uV into 3300000-3300000uV
[ 3.137235] as3722-ldo10: supplied by +V3.3
[ 3.142243] +V3.3_ETH(ldo10): Bringing 0uV into 3300000-3300000uV
[ 3.149102] as3722-ldo11: supplied by +V3.3
[ 3.153598] +V1.8_VPP_FUSE: Bringing 0uV into 1800000-1800000uV
[ 3.163359] sdhci-tegra 700b0000.sdhci: Got CD GPIO
[ 3.168311] mmc0: Missing autocal timeout 3v3-pad drvs
[ 3.173511] mmc0: Missing autocal timeout 3v3-pad drvs
[ 3.178654] mmc0: Missing autocal timeout 1v8-pad drvs
[ 3.183812] mmc0: Missing autocal timeout 1v8-pad drvs
[ 3.197562] mmc0: Invalid maximum block size, assuming 512 bytes
[ 3.374314] mmc0: Internal clock never stabilised.
[ 3.379119] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 3.385584] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 3.392047] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3.398494] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3.404999] mmc0: sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 3.411519] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 3.417969] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000401
[ 3.424432] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 3.430951] mmc0: sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 3.437411] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 3.443875] mmc0: sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 3.450340] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 3.456803] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 3.463424] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 3.469884] mmc0: sdhci: Host ctl2: 0x00000000
[ 3.474356] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 3.481519] mmc0: sdhci: ============================================
[ 3.610813] input: tegra-hda HDMI/DP,pcm=3 as /devices/soc0/70030000.hda/sound/card0/input0
[ 3.640051] mmc0: Internal clock never stabilised.
[ 3.644866] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 3.651376] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 3.657839] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3.664341] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3.670846] mmc0: sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 3.677294] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 3.683767] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000401
[ 3.690270] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 3.696720] mmc0: sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 3.703192] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 3.709655] mmc0: sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 3.716147] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 3.722620] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 3.729083] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 3.735571] mmc0: sdhci: Host ctl2: 0x00000000
[ 3.740051] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 3.747203] mmc0: sdhci: ============================================
[ 3.766804] mmc0: SDHCI controller on 700b0000.sdhci [700b0000.sdhci] using ADMA 64-bit
[ 3.775437] sdhci-tegra 700b0400.sdhci: Got CD GPIO
[ 3.780401] mmc1: Missing autocal timeout 3v3-pad drvs
[ 3.785545] mmc1: Missing autocal timeout 3v3-pad drvs
[ 3.790703] mmc1: Missing autocal timeout 1v8-pad drvs
[ 3.795844] mmc1: Missing autocal timeout 1v8-pad drvs
[ 3.808115] mmc1: Invalid maximum block size, assuming 512 bytes
[ 3.830057] random: fast init done
[ 3.850637] mmc1: SDHCI controller on 700b0400.sdhci [700b0400.sdhci] using ADMA 64-bit
[ 3.859221] mmc2: Missing autocal timeout 3v3-pad drvs
[ 3.864408] mmc2: Missing autocal timeout 3v3-pad drvs
[ 3.869550] mmc2: Missing autocal timeout 1v8-pad drvs
[ 3.874707] mmc2: Missing autocal timeout 1v8-pad drvs
[ 3.886831] mmc2: Invalid maximum block size, assuming 512 bytes
[ 3.919833] mmc2: SDHCI controller on 700b0600.sdhci [700b0600.sdhci] using ADMA 64-bit
[ 3.929612] sgtl5000 3-000a: sgtl5000 revision 0x11
[ 3.947218] tegra-snd-sgtl5000 sound: sgtl5000 <-> 70301200.i2s mapping ok
[ 3.962192] tegra-pcie 1003000.pcie: 2x1, 1x1 configuration
[ 3.970803] tegra-pcie 1003000.pcie: probing port 0, using 2 lanes
[ 3.983474] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 4.025299] mmc2: new HS200 MMC card at address 0001
[ 4.041428] mmcblk2: mmc2:0001 S0J56X 14.8 GiB
[ 4.047126] mmcblk2boot0: mmc2:0001 S0J56X partition 1 31.5 MiB
[ 4.071239] mmcblk2boot1: mmc2:0001 S0J56X partition 2 31.5 MiB
[ 4.077492] mmcblk2rpmb: mmc2:0001 S0J56X partition 3 4.00 MiB, chardev (247:0)
[ 4.129162] mmcblk2: p1 p2 p3
[ 5.363509] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 5.375500] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 5.381823] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 5.388010] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 5.394908] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 5.402242] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.408162] pci 0000:00:02.0: [10de:0e13] type 01 class 0x060400
[ 5.414207] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits
[ 5.423889] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits
[ 5.433600] pci 0000:00:02.0: enabling Extended Tags
[ 5.438574] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x88 may corrupt adjacent RW1C bits
[ 5.448344] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x3e may corrupt adjacent RW1C bits
[ 5.458130] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x52 may corrupt adjacent RW1C bits
[ 5.467933] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.474574] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4c may corrupt adjacent RW1C bits
[ 5.488747] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x3e may corrupt adjacent RW1C bits
[ 5.498520] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits
[ 5.508199] pci_bus 0000:00: 1-byte config write to 0000:00:02.0 offset 0xc may corrupt adjacent RW1C bits
[ 5.517872] PCI: bus0: Fast back to back transfers disabled
[ 5.523470] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 5.531500] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x3e may corrupt adjacent RW1C bits
[ 5.541483] pci 0000:01:00.0: [8086:157b] type 00 class 0x020000
[ 5.547551] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 5.553872] pci 0000:01:00.0: reg 0x18: [io 0x0000-0x001f]
[ 5.559465] pci 0000:01:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 5.565960] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.576747] PCI: bus1: Fast back to back transfers disabled
[ 5.582349] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 5.588990] pci 0000:00:02.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 5.595804] pci 0000:00:02.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 5.601929] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x1301ffff]
[ 5.608730] pci 0000:01:00.0: BAR 3: assigned [mem 0x13020000-0x13023fff]
[ 5.615549] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 5.621674] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 5.626646] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 5.632779] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 5.639603] pci 0000:00:02.0: nv_msi_ht_cap_quirk didn't locate host bridge
[ 5.646710] pcieport 0000:00:02.0: enabling device (0140 -> 0143)
[ 5.653005] pcieport 0000:00:02.0: PME: Signaling with IRQ 25
[ 5.659495] pcieport 0000:00:02.0: AER: enabled with IRQ 25
[ 5.665707] igb 0000:01:00.0: enabling device (0140 -> 0142)
[ 5.702721] pps pps0: new PPS source ptp0
[ 5.707315] igb 0000:01:00.0: added PHC on eth0
[ 5.711909] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.718791] igb 0000:01:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:14:2d:6a:f8:d7
[ 5.725948] igb 0000:01:00.0: eth0: PBA No: FFFFFF-0FF
[ 5.731109] igb 0000:01:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 5.749872] +V1.05_AVDD_HDMI_PLL: supplied by +V1.05
[ 5.755067] +V3.3_AVDD_HDMI: supplied by +V1.05
[ 5.763260] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.769885] [drm] No driver support for vblank timestamp query.
[ 5.775967] [drm] Cannot find any crtc or sizes
[ 5.780829] [drm] Initialized tegra 0.0.0 20120330 for drm on minor 0
[ 5.787789] tegra-ahci 70027000.sata: 70027000.sata supply ahci not found, using dummy regulator
[ 5.796778] tegra-ahci 70027000.sata: 70027000.sata supply phy not found, using dummy regulator
[ 5.805756] tegra-ahci 70027000.sata: 70027000.sata supply target not found, using dummy regulator
[ 5.815756] [drm] Cannot find any crtc or sizes
