Good afternoon.
We have two Apalis TK1
- Apalis TK1 + ixora running stock bsp distribution
- Apalis TK1 + ixora running a custom BSP 2.8b1
When i’m running the one with the stock distribution and run xinput_calibrator i see that it finds a device and tries to calibrate it (even if i don’t have the screen connected via 4 wire). With the one with the custom BSP it does not find a device that can be calibrated
The custom BSP was made doing an openembedded image (via toradex instructions) and then i downloaded the kernel for the apalis and compiled it by myself (enabling some options). Then i copied the resulting uimage to the openembedded image and flashed the Apalis
When i boot both Apalis i see in the boot logs something about apalis-tk1-k20-ts in the one with the stock distribution but not on the one with the custom one. I’ve made sure to check if the driver was checked when doing make nconfig and it was (it’s selected with an M)
What am i doing wrong? Why is xinput_calibrator not detecting the touch resistive driver? I used the dtb that openembedded created but i did not compile one from the kernel. Could it be related to this? Do i have to also compile the dtb and then copy it into the openembeded image?
Thanks in advance
