I attached some logs, which I could find.
OK, thanks.
xrandr returns: Cant open display :0.0
Then most possibly the X server did not start properly.
Sorry, I am not familiar how to get output of journalctl to a log file. As stated in first post, I am using IXORA V1.1A.
That could e.g. be achieved by piping its output to a file as follows:
journalctl -b 0 > journal.log
If you cannot observe same problem as I have (with not loading LXDE on non-mainline image), after run opkg update, opkg install gcc-symlinks and reseting, than obviously Iam doing something wrong, maybe setting/not setting enviromental variables to defaults by env default -a command via serial port.
I don’t quite see how that should have any much influence on the matter at hand but it definitely can’t hurt to be running with default U-Boot environment.
I believe I actually spotted the issue your are having in the Xorg.0.log:
[2941752.875] (EE) Failed to load /usr/lib/xorg/modules/drivers/nvidia_drv.so: libnvidia-rmapi-tegra.so.21.5: cannot open shared object file: No such file or directory
But why exactly you are seeing this I do not know. To further analyse this could you run the following for me and post its output?
root@apalis-tk1:~# ldd /usr/lib/xorg/modules/drivers/nvidia_drv.so
libnvidia-rmapi-tegra.so.21.5 => /usr/lib/arm-linux-gnueabihf/tegra/libnvidia-rmapi-tegra.so.21.5 (0xb69f5000)
libm.so.6 => /lib/libm.so.6 (0xb6978000)
libc.so.6 => /lib/libc.so.6 (0xb683c000)
libdl.so.2 => /lib/libdl.so.2 (0xb6829000)
librt.so.1 => /lib/librt.so.1 (0xb6812000)
/lib/ld-linux-armhf.so.3 (0xb6ef6000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb67ea000)
And maybe this one:
root@apalis-tk1:~# ldd /usr/lib/arm-linux-gnueabihf/tegra/libnvidia-rmapi-tegra.so.21.5
libc.so.6 => /lib/libc.so.6 (0xb6e68000)
libdl.so.2 => /lib/libdl.so.2 (0xb6e55000)
/lib/ld-linux-armhf.so.3 (0xb6fc0000)
