I am using TK1 setup with two MIPI-CSI2 OV5640 cameras using Evaluation Board and Mezzanine Board. My main goal is to be able to capture images from both cameras simultaneously.
I’ve tested the setup with several different configurations in terms of resolution, formats etc. using both Gstreamer and OpenCV, however, crashes always occur whenever the pipeline stops and tries to release the cameras. The images are captured and saved correctly. Below you can find log produced after I interrupted, for example, the following command:
gst-launch v4l2src device=/dev/video0 ! 'video/x-raw-yuv,width=640,height=480' ! ffmpegcolorspace ! ximagesink v4l2src device=/dev/video1 ! 'video/x-raw-yuv,width=640,height=480' ! ffmpegcolorspace ! ximagesink
Error log:
Interrupt: Stopping pipeline ...
(gst-launch-0.10:890): GLib-CRITICAL **: Source ID 46 was not found when attempting to remove it
Execution ended after 2755087500 ns.
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
[ 94.371314] Unable to handle kernel NULL pointer dereference at virtual address 00000008
[ 94.380537] pgd = ec4a4000
[ 94.383895] [00000008] *pgd=abe8b003, *pmd=ad3fc003, *pte=00000000
[ 94.391983] Internal error: Oops: 207 [#1] PREEMPT SMP ARM
[ 94.397472] Modules linked in: ar0261_v4l2 soc_camera_platform adv7280 tc358743 ap1302 ar0330_v4l2 imx135_v4l2 tegra_camera ov5640 videobuf2_dma_contig joydev apalis_tk1_k20_can apalis_tk1_k20_adc gpio_apalis_tk1_k20 apalis_tk1_k20_ts bluetooth atmel_mxt_ts apalis_tk1_k20
[ 94.421796] CPU: 0 PID: 890 Comm: gst-launch-0.10 Tainted: G W 3.10.40-2.8.5+gccecdb3d6b3b #1
[ 94.431183] task: eb401580 ti: ebef6000 task.ti: ebef6000
[ 94.436588] PC is at kthread_stop+0x80/0x17c
[ 94.440869] LR is at tegra_camera_stop_streaming+0x34/0x6c [tegra_camera]
[ 94.447657] pc : [<c007c30c>] lr : [<bf094710>] psr: 60000013
[ 94.447657] sp : ebef7d88 ip : ecc07a40 fp : c0524ae0
[ 94.459122] r10: ed08f810 r9 : ed08f810 r8 : ed6a0a10
[ 94.464346] r7 : 00000001 r6 : 00000000 r5 : 00000008 r4 : 00000000
[ 94.470868] r3 : 00000000 r2 : c0b85684 r1 : 00000001 r0 : 00000000
[ 94.477391] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 94.484521] Control: 30c5387d Table: ac4a4000 DAC: fffffffd
[ 95.229689] [<c007c30c>] (kthread_stop+0x80/0x17c) from [<bf094710>] (tegra_camera_stop_streaming+0x34/0x6c [tegra_camera])
[ 95.240828] [<bf094710>] (tegra_camera_stop_streaming+0x34/0x6c [tegra_camera]) from [<c0532c6c>] (__vb2_queue_cancel+0x30/0x90)
[ 95.252390] [<c0532c6c>] (__vb2_queue_cancel+0x30/0x90) from [<c0533c00>] (vb2_streamoff+0x84/0xb4)
[ 95.261438] [<c0533c00>] (vb2_streamoff+0x84/0xb4) from [<c0536ba8>] (soc_camera_streamoff+0xb8/0xd0)
[ 95.270661] [<c0536ba8>] (soc_camera_streamoff+0xb8/0xd0) from [<c0528308>] (__video_do_ioctl+0x20c/0x29c)
[ 95.280314] [<c0528308>] (__video_do_ioctl+0x20c/0x29c) from [<c0527fd0>] (video_usercopy+0x288/0x3a0)
[ 95.289625] [<c0527fd0>] (video_usercopy+0x288/0x3a0) from [<c0523704>] (v4l2_ioctl+0x68/0x11c)
[ 95.298331] [<c0523704>] (v4l2_ioctl+0x68/0x11c) from [<c0145020>] (vfs_ioctl+0x30/0x44)
[ 95.306424] [<c0145020>] (vfs_ioctl+0x30/0x44) from [<c01456d0>] (do_vfs_ioctl+0x80/0x538)
[ 95.314690] [<c01456d0>] (do_vfs_ioctl+0x80/0x538) from [<c0145c54>] (SyS_ioctl+0xcc/0x168)
[ 95.323045] [<c0145c54>] (SyS_ioctl+0xcc/0x168) from [<c000e5e0>] (ret_fast_syscall+0x0/0x30)
[ 95.331570] Code: e3130002 0a000000 eb1b2df1 e2845008 (e1953f9f)
[ 95.344274] ---[ end trace f099d7e496e440dc ]---
Same problem occurs whenever filesinks are used or an OpenCV application gets to the moment the cameras are released.
Another type of error I’ve encountered so far is when I leave the two cameras for a longer period of time (tens of seconds) to keep capturing images continuously. Following logs were captured using an OpenCV application:
[ 80.686599] vi vi.0: CSI_A syncpt timeout, syncpt = 1420, err = -11
[ 80.692980] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000011
[ 80.697681] TEGRA_CSI_CSI_CILA_STATUS 0x00050050
[ 80.702294] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 80.706994] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000001
[ 80.711690] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 80.716385] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 80.721082] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 80.726559] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 80.732033] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 80.736816] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 80.741600] vi vi.0: Error capturing frame. Stopping capture
[ 81.677566] vi vi.0: CSI_A syncpt timeout, syncpt = 1422, err = -11
[ 81.683839] TEGRA_CSI_CSI_CIL_A_STATUS 0x00000011
[ 81.688558] TEGRA_CSI_CSI_CILA_STATUS 0x00050050
[ 81.693175] TEGRA_CSI_CSI_CIL_B_STATUS 0x00000000
[ 81.697875] TEGRA_CSI_CSI_CIL_C_STATUS 0x00000001
[ 81.702619] TEGRA_CSI_CSI_CIL_D_STATUS 0x00000000
[ 81.707320] TEGRA_CSI_CSI_CIL_E_STATUS 0x00000000
[ 81.712020] TEGRA_CSI_CSI_PIXEL_PARSER_A_STATUS 0x00000000
[ 81.717498] TEGRA_CSI_CSI_PIXEL_PARSER_B_STATUS 0x00000000
[ 81.722976] TEGRA_VI_CSI_0_ERROR_STATUS 0x00000000
[ 81.727761] TEGRA_VI_CSI_1_ERROR_STATUS 0x00000000
[ 81.732548] vi vi.0: Error capturing frame. Stopping capture
After this point, the cameras stop capturing images and when I try to close the application the same error as before occurs:
[ 116.707840] Unable to handle kernel NULL pointer dereference at virtual address 00000008
[ 116.715938] pgd = c0003000
[ 116.718652] [00000008] *pgd=80000080004003, *pmd=00000000
[ 116.724104] Internal error: Oops: 207 [#1] PREEMPT SMP ARM
[ 116.729576] Modules linked in: ar0261_v4l2 soc_camera_platform adv7280 tc358743 ap1302 ar0330_v4l2 imx135_v4l2 tegra_camera ov5640 videobuf2_dma_contig joydev gpio_apalis_tk1_k20 apalis_tk1_k20_adc apalis_tk1_k20_can apalis_tk1_k20_ts bluetooth atmel_mxt_ts apalis_tk1_k20
[ 116.753758] CPU: 3 PID: 879 Comm: fps-dual-cam Tainted: G W 3.10.40-2.8.5+gccecdb3d6b3b #1
[ 116.762870] task: ed786580 ti: ebef6000 task.ti: ebef6000
[ 116.768259] PC is at kthread_stop+0x80/0x17c
[ 116.772520] LR is at tegra_camera_stop_streaming+0x34/0x6c [tegra_camera]
[ 116.779291] pc : [<c007c30c>] lr : [<bf094710>] psr: 60000113
[ 116.779291] sp : ebef7dc8 ip : 00000000 fp : ec1c4b48
[ 116.790743] r10: eb43d0b0 r9 : eb43d0b0 r8 : 00000008
[ 116.795954] r7 : ec1c4b40 r6 : 00000000 r5 : 00000008 r4 : 00000000
[ 116.802464] r3 : 00000000 r2 : c0b85684 r1 : 00000001 r0 : 00000000
[ 116.808976] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 116.816094] Control: 30c5387d Table: abc54000 DAC: 55555555
[ 117.470360] [<c007c30c>] (kthread_stop+0x80/0x17c) from [<bf094710>] (tegra_camera_stop_streaming+0x34/0x6c [tegra_camera])
[ 117.481474] [<bf094710>] (tegra_camera_stop_streaming+0x34/0x6c [tegra_camera]) from [<c0532c6c>] (__vb2_queue_cancel+0x30/0x90)
[ 117.493017] [<c0532c6c>] (__vb2_queue_cancel+0x30/0x90) from [<c0535560>] (vb2_queue_release+0x1c/0x2c)
[ 117.502393] [<c0535560>] (vb2_queue_release+0x1c/0x2c) from [<c0537364>] (soc_camera_close+0x74/0xe0)
[ 117.511594] [<c0537364>] (soc_camera_close+0x74/0xe0) from [<c052359c>] (v4l2_release+0x38/0x70)
[ 117.520362] [<c052359c>] (v4l2_release+0x38/0x70) from [<c01359a8>] (__fput+0xf0/0x1fc)
[ 117.528352] [<c01359a8>] (__fput+0xf0/0x1fc) from [<c0078a78>] (task_work_run+0xbc/0xd8)
[ 117.536426] [<c0078a78>] (task_work_run+0xbc/0xd8) from [<c005c8a4>] (do_exit+0x3d8/0x888)
[ 117.544674] [<c005c8a4>] (do_exit+0x3d8/0x888) from [<c005dc3c>] (do_group_exit+0x60/0xbc)
[ 117.552923] [<c005dc3c>] (do_group_exit+0x60/0xbc) from [<c006b5e0>] (get_signal_to_deliver+0x4d8/0x514)
[ 117.562386] [<c006b5e0>] (get_signal_to_deliver+0x4d8/0x514) from [<c001186c>] (do_work_pending+0xf8/0x3e8)
[ 117.572108] [<c001186c>] (do_work_pending+0xf8/0x3e8) from [<c000e620>] (work_pending+0xc/0x20)
[ 117.580787] Code: e3130002 0a000000 eb1b2df1 e2845008 (e1953f9f)
[ 117.586897] ---[ end trace 3750526362d5fe76 ]---
[ 117.599685] Fixing recursive fault but reboot is needed!
The cameras work fine when I use only one of them at the time and in that case I can successfully stop the pipeline/application. Although, even with single camera use I have also sometimes encountered “vi vi.0: CSI_A syncpt timeout” error after which the camera would stop working but at least kernel wouldn’t crash.
