The test failed after the first couple hours. The behavior was different than before. This was a full OS freeze/lockup. No mouse or keyboard response. I’ve attached the putty log file.
Toradex Windows CE 7.0 2.2b4 for Tegra Built Sep 11 2018 16:07:01
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
L2 cache enabled
MainMemoryEndAddress adjusted from 0x9F000000 to 0x9FE00000
Main Phys Mem: 0x80000000:0x9FDFFFFF
Carveout Phys: 0x9FE00000:0x9FFFFFFF
Cold boot selected
SMP: Active CPUs = 4
Extended Mem : 0xA0000000:0xBFFFFFFF
Chip Id: 0x30 (Handheld SOC) Major: 0x1 Minor: 0x3 SKU: 0xb0
ATE prog ver 4.0
Speedo: CPU: 401 (Corner: 3), Core: 219
NVRM Initialized shmoo database
PllClocks(Mhz): X=1300, M=800, C=600, P=408, A=24.576
SysClocks(Mhz): CPU=1300, AVP=240, SysBus=240, Mem=400, EMem=800
GraphicClocks(Mhz): Host=106, 3D=133, 2D=133, Epp=133, Mpe=133, Vde=408
Loading ResourceManager...
Done Loading ResourceManager (0 ms)
Loading FlashFileSystem(NAND)...
Failed(0) Loading FlashFileSystem(NAND) (0 ms)
Loading FlashFileSystem(eMMC)...
Done Loading FlashFileSystem(eMMC) (0 ms)
Loading MultimediaManager...
Done Loading MultimediaManager (0 ms)
Loading Audio...
Loading Serial3...
Loading Serial2...
Loading Serial1...
Done Loading Serial3 (1 ms)
Done Loading Serial2 (0 ms)
Failed(0) Loading Serial1 (1 ms)
Done Loading Audio (332 ms)
Loading SDIO...
Loading SDIO2...
Loading SDIOLoading PCIe...Loading SDIO(SDIO3)...(SDIO1)...NvDdkSdioSetClockFrequency: Requested: 100 KHz, Actual: 100 KHz
PCIE: port 0: link down, aborting
PCIE: port 1: link up in 0 us
PCIE: port 2: link up in 0 us
Done
Bus:Device:Function: VendorID,DeviceID
0:0:0: 0x10de,0xe1c Virtual P2P to 1
0:1:0: 0x10de,0xe1d Virtual P2P to 2
0:2:0: 0x10de,0xe1d Virtual P2P to 7
2:0:0: 0x10b5,0x8605 Virtual P2P to 3
3:1:0: 0x10b5,0x8605 Virtual P2P to 4
3:2:0: 0x10b5,0x8605 Virtual P2P to 5
3:3:0: 0x10b5,0x8605 Virtual P2P to 6
7:0:0: 0x8086,0x157b
Loading I21x Ethernet...Done
Loading USBOTG(Port1)...
Loading USBHost(Port3)...
Loading USBHost(Port2)...
Done Loading USBOTG(Port1) (7 ms)
Loading DisplayDriver...
Set LCD to 1024x600 (68Hz)
Set HDMI to 640x480 (60Hz)
Done Loading DisplayDriver (76 ms)
VBUS=1, ID=1
ChangeMode(0, 3)
OTG(0): Loading USBFN...
Loading USBFunction(Port1)...
Done Loading USBHost(Port3) (216 ms)
Set HDMI to 1024x768 (60Hz)
Loading Keyboard/MouseDriver...
Done Loading Keyboard/MouseDriver
Done Loading USBFunction(Port1) (154 ms)
OTG(0) Done Loading USBFN
Done Loading USBHost(Port2) (391 ms)
Done(1009)
Done(1008)
Done Loading SDIO (1011 ms)
Done Loading SDIO2 (1011 ms)
NvDdkSdioSetClockFrequency: Requested: 25000 KHz, Actual: 24727 KHz
SDIO8787 driver built on Dec 20 2016 at time: 20:23:49
Remove Keys for Comm\SDIO87871\Parms
12:00:02:09-[MRVL moal_adapter.cpp ( 545) moal_validate_reg_pa()] Roaming AbsoluteRssi 80, RoamRssi 74
TBUPDD: 1 Got port handle 0x4020067Registering SD8787 Wireless Driver...
TBUPDD: 2 ReadFile() Port - 0x0 error=6
Invalid time on External RTC, please set a valid time
TBUPDD: 2 Got port handle 0x53400c7
SD8787: 4-Bit mode at 25000000 Hz
NvShimUSBEventHandlerThread: Semaphore Timed Out
Dumb Charger detected
USB Shim Charger Type Detected = 16 [1-SE0, 2-SJ, 4-SK, 8-SE1, 16-Dummy]
Loading NETUI...
Done NETUI
12:00:03:614-[MRVL E moal_main.cpp (1097) get_module_handle ()] Invalid moal id trying to get module handle. Returning status= MLAN_STATUS_EMPTY
12:00:03:625-[MRVL E moal_tx.cpp ( 530) send_packet ()] Cannot get Packet module context. Returning status= MLAN_STATUS_EMPTY
12:00:03:834-[MRVL E moal_main.cpp (1629) moal_pnp_resume_fsm ()] Resume FSM Exit !
12:00:03:890-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:904-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:919-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:934-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:959-[MRVL E moal_oid5.cpp (2926) query_802_11_capabil()] query_802_11_capability length:112
12:00:20:774-[MRVL E moal_connect.cpp (4300) moal_attempt_connect()] Adding security IE
Setting Power Save Level to None
12:00:20:801-[MRVL E moal_connect.cpp (1289) moal_set_data_rate_p()] Setting data rate user config failed, usr_datarate_index: 0xFF
12:00:20:811-[MRVL E moal_connect.cpp (2221) start_obss_scan_time()] OBSS Scan not enabled
Warning: you are requesting IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMTYPE, which has been deprecated. Use IOCTL_HAL_GET_DEVICE_INFO::SPI_GETPLATFORMNAME instead.
Toradex Bootloader 2.2b4 for Tegra Built Sep 13 2018 10:46:32
Press [SPACE] to enter Bootloader Menu
Apalis T30 1GB IT 1.1B Serial: 2936275
RAM: 1024 MB, CarveOut: 2 MB
Locating kernel image in flash...Done(603)
Decompressing IMAGE(26343026, 51236568) from FLASH(0) to RAM(80016000)...Done(468ms)
Jumping to image at 0x80016000...
L2 cache enabled
Cold boot selected
ATE prog ver 4.0
Loading Audio...
Loading Serial3...
Loading Serial2...
Loading Serial1...
Done Loading Serial3 (0 ms)
Done Loading Serial2 (1 ms)
Failed(0) Loading Serial1 (0 ms)
Loading SDIO...
Loading SDIO2...
Done
Done Loading USBOTG(Port1) (6 ms)
VBUS=1, ID=1
ChangeMode(0, 3)
Done Loading DisplayDriver (82 ms)
Done Loading USBHost(Port3) (228 ms)
Done Loading USBFunction(Port1) (151 ms)
Done Loading USBHost(Port2) (396 ms)
Done(1008)
Done(1007)
Done Loading SDIO (1010 ms)
Done Loading SDIO2 (1010 ms)
TBUPDD: 1 Got port handle 0x532005b
12:00:02:16-[MRVL moal_adapter.cpp ( 545) moal_validate_reg_pa()] Roaming AbsoluteRssi 80, RoamRssi 74
TBUPDD: 2 ReadFile() Port - 0x0 error=6Registering SD8787 Wireless Driver...
TBUPDD: 2 Got port handle 0x531010b
Loading NETUI...
Done NETUI
12:00:03:629-[MRVL E moal_main.cpp (1097) get_module_handle ()] Invalid moal id trying to get module handle. Returning status= MLAN_STATUS_EMPTY
12:00:03:640-[MRVL E moal_tx.cpp ( 530) send_packet ()] Cannot get Packet module context. Returning status= MLAN_STATUS_EMPTY
12:00:03:849-[MRVL E moal_main.cpp (1629) moal_pnp_resume_fsm ()] Resume FSM Exit !
12:00:03:907-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:920-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:935-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:950-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:991-[MRVL E moal_oid5.cpp (2926) query_802_11_capabil()] query_802_11_capability length:112
12:00:20:805-[MRVL E moal_connect.cpp (4300) moal_attempt_connect()] Adding security IE
12:00:20:833-[MRVL E moal_connect.cpp (1289) moal_set_data_rate_p()] Setting data rate user config failed, usr_datarate_index: 0xFF
12:00:20:843-[MRVL E moal_connect.cpp (2221) start_obss_scan_time()] OBSS Scan not enabled
Decompressing IMAGE(26343026, 51236568) from FLASH(0) to RAM(80016000)...Done(467ms)
L2 cache enabled
Cold boot selected
ATE prog ver 4.0
Loading Audio...
Loading Serial3...
Loading Serial2...
Loading Serial1...
Done Loading Audio (334 ms)
Loading SDIO...
Loading SDIO2...
Done
VBUS=1, ID=1
Done Loading DisplayDriver (79 ms)
ChangeMode(0, 3)
Done Loading USBHost(Port3) (225 ms)
Done(1009)
Done(1007)
Done Loading SDIO (1013 ms)
Done Loading SDIO2 (1012 ms)
TBUPDD: 1 Got port handle 0x577006bSDIO8787 driver built on Dec 20 2016 at time: 20:23:49
12:00:02:14-[MRVL moal_adapter.cpp ( 545) moal_validate_reg_pa()] Roaming AbsoluteRssi 80, RoamRssi 74
TBUPDD: 2 Got port handle 0x4900117
Loading NETUI...
Done NETUI
12:00:03:624-[MRVL E moal_main.cpp (1097) get_module_handle ()] Invalid moal id trying to get module handle. Returning status= MLAN_STATUS_EMPTY
12:00:03:635-[MRVL E moal_tx.cpp ( 530) send_packet ()] Cannot get Packet module context. Returning status= MLAN_STATUS_EMPTY
12:00:03:844-[MRVL E moal_main.cpp (1629) moal_pnp_resume_fsm ()] Resume FSM Exit !
12:00:03:901-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:915-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:929-[MRVL E moal_oid.cpp (3847) validate_info_buffer()] Info buffer smaller than min size [ 0 < 300 ] in valiation routine! Returning NDIS_STATUS_BUFFER_OVERFLOW
12:00:03:945-[MRVL E moal_oid.cpp (3188) query_gen_supported_()] Unable to validate the size of the supported OID List!. Returning status= NDIS_STATUS_BUFFER_OVERFLOW12:00:03:971-[MRVL E moal_oid5.cpp (2926) query_802_11_capabil()] query_802_11_capability length:112
