Thank you. Yes, I has already reset the uboot enviroment with this commands.
This is the boot log:
U-Boot SPL 2016.11-2.8.6+g83a53c1c0c (Apr 01 2019 - 14:51:57)
Trying to boot from RAM
U-Boot 2016.11-2.8.6+g83a53c1c0c (Apr 01 2019 - 14:51:57 +0000)
SoC: tegra30
Reset cause: POR
DRAM: 1 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In: serial
Out: vidconsole
Err: vidconsole
Model: Toradex Apalis T30 1GB IT V1.1B, Serial# 06315264
Net: No ethernet found.
Booting from internal eMMC chip...
reading tegra30-apalis-eval.dtb
** Unable to read file tegra30-apalis-eval.dtb **
reading zImage
4246872 bytes read in 120 ms (33.8 MiB/s)
Starting kernel ...
[ 0.000000] Linux version 3.1.10-2.8.6+g37b9f033652b (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP PREEMPT Mon Apr 1 14:54:27 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Toradex Apalis T30
[ 0.000000] Found fbmem: 00c00000@bf400000
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer: bf400000 - bfffffff
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: be700000 - beffffff
[ 0.000000] 2nd Framebuffer: bf000000 - bfffffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] fuse_speedo_calib: ATE prog ver 4.0
[ 0.000000] ****************************************************
[ 0.000000] * tegra3_speedo: CPU speedo value 324 out of range *
[ 0.000000] Tegra3: CPU Speedo ID 1, Soc Speedo ID 2
[ 0.000000] Tegra Revision: A03 SKU: 0xb0 CPU Process: 0 Core Process: 0
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] Lowering sbus maximum rate from 378000000 to 334000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 520000000
[ 0.000000] Lowering mpe maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 2d maximum rate from 600000000 to 520000000
[ 0.000000] Lowering epp maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 3d maximum rate from 600000000 to 520000000
[ 0.000000] Lowering 3d2 maximum rate from 600000000 to 520000000
[ 0.000000] Lowering se maximum rate from 625000000 to 520000000
[ 0.000000] Lowering host1x maximum rate from 300000000 to 267000000
[ 0.000000] Lowering cbus maximum rate from 700000000 to 520000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering ndflash maximum rate from 240000000 to 200000000
[ 0.000000] Lowering sbc1 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc2 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc3 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc4 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc5 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering sbc6 maximum rate from 160000000 to 100000000
[ 0.000000] Lowering dsia maximum rate from 500000000 to 432500000
[ 0.000000] Lowering dsib maximum rate from 500000000 to 432500000
[ 0.000000] Lowering cpu_g maximum rate from 1700000000 to 1300000000
[ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1300mV, scaling enabled
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 8 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x7e080001, Cache size: 1048576 B
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c12f6000 s10336 r8192 d14240 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 253211
[ 0.000000] Kernel command line: core_edp_mv=1300 usb_high_speed=1 user_debug=30 ip=off root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait igb_mac=00:14:2d:60:5d:00 consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 vmalloc=128M mem=1012M@2048M fbmem=12M@3060M video=tegrafb0:640x480-16@60 fbcon=map:1
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 998MB = 998MB total
[ 0.000000] Memory: 1001600k/1001600k available, 34688k reserved, 235520K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xf0800000 - 0xf8000000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc081603c (8249 kB)
[ 0.000000] .init : 0xc0817000 - 0xc086b860 ( 339 kB)
[ 0.000000] .data : 0xc086c000 - 0xc08f9b44 ( 567 kB)
[ 0.000000] .bss : 0xc08f9b68 - 0xc0972858 ( 484 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:800
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003397] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256)
[ 0.090128] pid_max: default: 32768 minimum: 301
[ 0.090501] Mount-cache hash table entries: 512
[ 0.091769] Initializing cgroup subsys blkio
[ 0.091914] CPU: Testing write buffer coherency: ok
[ 0.092013] ftrace: allocating 23310 entries in 69 pages
[ 0.123583] Brought up 4 CPUs
[ 0.123631] SMP: Total of 4 processors activated (4787.40 BogoMIPS).
[ 0.124785] devtmpfs: initialized
[ 0.130466] print_constraints: dummy:
[ 0.130875] NET: Registered protocol family 16
[ 0.132186] host1x bus init
[ 0.132412] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[ 0.406054] apalis_t30_edp_init: CPU regulator 6000 mA
[ 0.406146] Selecting UARTA as the debug console
[ 0.406191] The debug console clock name is uarta_dbg
[ 0.406556] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 0.971798] console [ttyS0] enabled
[ 1.002523] Registering the device TPS62360
[ 1.007290] Clear bootloader IO dpd settings
[ 1.092669] tegra: invalid EMC DFS table: entry for max rate 800000 kHz is not found
[ 1.103285] tegra_iovmm_register: added iovmm-smmu
[ 1.119604] bio: create slab <bio-0> at 0
[ 1.124465] i2c-core: driver [tps6591x] using legacy suspend method
[ 1.130781] i2c-core: driver [tps6591x] using legacy resume method
[ 1.137464] SCSI subsystem initialized
[ 1.144222] usbcore: registered new interface driver usbfs
[ 1.149850] usbcore: registered new interface driver hub
[ 1.155326] usbcore: registered new device driver usb
[ 1.160546] tegra-otg tegra-otg: otg transceiver registered
[ 1.168409] stmpe 4-0041: stmpe811 detected, chip id: 0x811
[ 1.176396] tps6591x 4-002d: VERNUM is 02
[ 1.185608] print_constraints: tps6591x_VDD_1: 1350 mV normal standby
[ 1.196087] print_constraints: tps6591x_VDD_2: 1050 mV normal standby
[ 1.205983] print_constraints: tps6591x_VDDCTRL: 800 <--> 1300 mV at 1012 mV normal standby
[ 1.215586] print_constraints: tps6591x_VIO: 1800 mV normal standby
[ 1.224176] print_constraints: tps6591x_LDO_1: 1800 mV normal standby
[ 1.230682] set_supply: tps6591x_LDO_1: supplied by tps6591x_VIO
[ 1.238900] print_constraints: tps6591x_LDO_2: 1200 mV normal standby
[ 1.245408] set_supply: tps6591x_LDO_2: supplied by tps6591x_VIO
[ 1.252338] print_constraints: tps6591x_LDO_3: 1200 mV normal standby
[ 1.260036] print_constraints: tps6591x_LDO_4: 1000 <--> 1400 mV at 1200 mV normal standby
[ 1.269176] print_constraints: tps6591x_LDO_5: 2800 mV normal standby
[ 1.276512] print_constraints: tps6591x_LDO_6: 1000 <--> 1100 mV at 1000 mV normal standby
[ 1.284852] set_supply: tps6591x_LDO_6: supplied by tps6591x_VIO
[ 1.293494] print_constraints: tps6591x_LDO_7: 1200 mV normal standby
[ 1.299986] set_supply: tps6591x_LDO_7: supplied by tps6591x_VIO
[ 1.308157] print_constraints: tps6591x_LDO_8: 1000 mV normal standby
[ 1.314667] set_supply: tps6591x_LDO_8: supplied by tps6591x_VIO
[ 1.326911] print_constraints: tps62360: 900 <--> 1400 mV at 1200 mV normal standby
[ 1.334906] pps_core: LinuxPPS API ver. 1 registered
[ 1.339896] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.349111] PTP clock support registered
[ 1.353405] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.360448] Bluetooth: Core ver 2.16
[ 1.364101] NET: Registered protocol family 31
[ 1.368566] Bluetooth: HCI device and connection manager initialized
[ 1.374963] Bluetooth: HCI socket layer initialized
[ 1.379863] Bluetooth: L2CAP socket layer initialized
[ 1.384988] Bluetooth: SCO socket layer initialized
[ 1.391251] print_constraints: fixed_reg_en_hdmi: 1800 mV normal
[ 1.397675] print_constraints: fixed_reg_v3_3: 3300 mV normal
[ 1.404004] print_constraints: gpio_reg_sdmmc3_vdd_sel: 1800 <--> 3300 mV at 1800 mV normal standby
[ 1.413125] set_supply: gpio_reg_sdmmc3_vdd_sel: supplied by fixed_reg_v3_3
[ 1.421008] tegra: failed to map regulator to power detect cell pwrdet_sdmmc3(-19)
[ 1.428703] tegra: failed regulators mapping - io power detection is left always on
[ 1.436412] Switching to clocksource timer_us
[ 1.453668] nvmap_page_pool_init: nvmap uc page pool size=31300 pages
[ 1.493016] nvmap_page_pool_init: nvmap pool = uc, highmem=31300, pool_size=31300,totalram=250400, freeram=218287, totalhigh=58880, freehigh=27515
[ 1.647344] nvmap_page_pool_init: nvmap wc page pool size=31300 pages
[ 1.693860] nvmap_page_pool_init: nvmap pool = wc, highmem=27456, pool_size=31300,totalram=250400, freeram=186928, totalhigh=58880, freehigh=0
[ 1.849607] nvmap_page_pool_init: nvmap iwb page pool size=31300 pages
[ 1.945657] nvmap_page_pool_init: nvmap pool = iwb, highmem=0, pool_size=31300,totalram=250400, freeram=155556, totalhigh=58880, freehigh=0
[ 2.119328] tegra-nvmap tegra-nvmap: created carveout iram (255KiB)
[ 2.140130] NET: Registered protocol family 2
[ 2.144806] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.152597] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.162558] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 2.171024] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.177660] TCP reno registered
[ 2.180823] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.186819] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.193633] NET: Registered protocol family 1
[ 2.198468] RPC: Registered named UNIX socket transport module.
[ 2.204454] RPC: Registered udp transport module.
[ 2.209176] RPC: Registered tcp transport module.
[ 2.213916] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.223208] host1x host1x: initialized
[ 2.227095] PMU: registered new PMU device of type 0
[ 2.232637] Tegra auto-hotplug initialized: disabled
[ 2.237634] cpu-tegra: init EDP limit: 1150 MHz
[ 2.243008] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[ 2.249521] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[ 2.255766] tegra_pcie_enable_regulators: unable to get pexio regulator
[ 2.262427] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[ 2.471692] PCIE: port 0: link down, retrying
[ 2.676640] PCIE: port 0: link down, retrying
[ 2.881322] PCIE: port 0: link down, retrying
[ 2.885682] PCIE: port 0: link down, ignoring
[ 3.090353] PCIE: port 1: link down, retrying
[ 3.295033] PCIE: port 1: link down, retrying
[ 3.499705] PCIE: port 1: link down, retrying
[ 3.504080] PCIE: port 1: link down, ignoring
[ 3.508676] PCI: bus0: Fast back to back transfers disabled
[ 3.530879] PCI: bus1: Fast back to back transfers disabled
[ 3.536735] pci 0000:00:00.0: BAR 8: assigned [mem 0x10000000-0x100fffff]
[ 3.543549] pci 0000:00:00.0: BAR 7: assigned [io 0x10000000-0x10000fff]
[ 3.550344] pci 0000:01:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff]
[ 3.557156] pci 0000:01:00.0: BAR 0: set to [mem 0x10000000-0x1001ffff] (PCI address [0x10000000-0x1001ffff])
[ 3.567090] pci 0000:01:00.0: BAR 3: assigned [mem 0x10020000-0x10023fff]
[ 3.573898] pci 0000:01:00.0: BAR 3: set to [mem 0x10020000-0x10023fff] (PCI address [0x10020000-0x10023fff])
[ 3.583829] pci 0000:01:00.0: BAR 2: assigned [io 0x10000000-0x1000001f]
[ 3.590626] pci 0000:01:00.0: BAR 2: set to [io 0x10000000-0x1000001f] (PCI address [0x10000000-0x1000001f])
[ 3.600557] pci 0000:00:00.0: PCI bridge to [bus 01-01]
[ 3.605796] pci 0000:00:00.0: bridge window [io 0x10000000-0x10000fff]
[ 3.612598] pci 0000:00:00.0: bridge window [mem 0x10000000-0x100fffff]
[ 3.635392] highmem bounce pool size: 64 pages
[ 3.640490] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 3.647569] fuse init (API version 7.17)
[ 3.651803] msgmni has been set to 1496
[ 3.656668] io scheduler noop registered (default)
[ 3.663357] mpe mpe: initialized
[ 3.668877] gr3d gr3d: initialized
[ 3.674496] gr2d gr2d: initialized
[ 3.678406] isp isp: initialized
[ 3.682243] tegradc tegradc.0: probed
[ 3.686017] tegradc tegradc.0: use cmd options for tegrafb0: 640x480-16@60
[ 3.692931] tegradc tegradc.0: switching framebuffer to 640x480
[ 3.698855] tegradc tegradc.0: Calculated sync href=0 vref=1
[ 3.704532] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[ 3.716281] tegradc tegradc.0: probed[ 3.733273] tegradc tegradc.1: probed
[ 3.737184] tegradc tegradc.1: use default mode for tegrafb1: 640x480-16@60
[ 3.744174] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 3.755496] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 3.766828] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution
[ 3.778155] tegradc tegradc.1: switching framebuffer to 640x480
[ 3.784090] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[ 3.796397] tegradc tegradc.1: hdmi: can't set audio to 44100 at 23750000 pix_clock
[ 3.804206] tegradc tegradc.1: switching framebuffer to 640x480
[ 3.804217] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1
[ 3.859811] Console: switching to colour frame buffer device 80x30
[ 3.900460] tegradc tegradc.1: probed
[ 3.942346] tegra_uart.3: ttyHS3 at MMIO 0x70006300 (irq = 122) is a TEGRA_UART
[ 4.060884] Registered UART port ttyHS3
[ 4.066891] tegra_uart.1: ttyHS1 at MMIO 0x70006040 (irq = 69) is a TEGRA_UART
[ 4.220868] Registered UART port ttyHS1
[ 4.226958] tegra_uart.2: ttyHS2 at MMIO 0x70006200 (irq = 78) is a TEGRA_UART
[ 4.380875] Registered UART port ttyHS2
[ 4.387255] Initialized tegra uart driver
[ 4.398711] loop: module loaded
[ 4.404978] create_regulator: tps6591x_LDO_6: Failed to create debugfs directory
[ 4.417939] tegra-sata tegra-sata.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[ 4.431958] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pio slum part apst
[ 4.445725] scsi0 : tegra-sata
[ 4.451630] ata1: SATA max UDMA/133 irq 55
[ 4.458948] Intel(R) Gigabit Ethernet Network Driver - version 5.2.17
[ 4.467906] Copyright (c) 2007-2015 Intel Corporation.
[ 4.573002] igb 0000:01:00.0: added PHC on eth0
[ 4.579953] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 4.589298] igb 0000:01:00.0: eth0: (PCIe:2.5GT/s:Width x1)
[ 4.594927] igb 0000:01:00.0: eth0: MAC: 00:14:2d:60:5d:00
[ 4.605306] igb 0000:01:00.0: eth0: PBA No: Unknown
[ 4.612646] igb 0000:01:00.0: LRO is disabled
[ 4.619257] igb 0000:01:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[ 4.631297] CAN device driver interface
[ 4.649443] mcp251x spi1.0: probed
[ 4.666772] mcp251x spi3.1: probed
[ 4.672332] PPP generic driver version 2.4.2
[ 4.678928] PPP Deflate Compression module registered
[ 4.686143] PPP BSD Compression module registered
[ 4.693858] PPP MPPE Compression module registered
[ 4.700685] NET: Registered protocol family 24
[ 4.709800] tun: Universal TUN/TAP device driver, 1.6
[ 4.718345] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.728537] usbcore: registered new interface driver asix
[ 4.737498] usbcore: registered new interface driver cdc_ether
[ 4.746778] usbcore: registered new interface driver cdc_subset
[ 4.755943] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.765937] tegra USB phy - inst[1] platform info:
[ 4.773917] port_otg: no
[ 4.779486] has_hostpc: yes
[ 4.785296] phy_interface: USB_PHY_INTF_UTMI
[ 4.792601] op_mode: TEGRA_USB_OPMODE_HOST
[ 4.799640] vbus_gpio: 233
[ 4.805372] ata1: SATA link down (SStatus 0 SControl 300)
[ 4.813891] vbus_gpio_inverted: 0
[ 4.820302] vbus_reg: NULL
[ 4.826027] hot_plug: enabled
[ 4.831820] remote_wakeup: enabled
[ 4.843083] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[ 4.852301] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[ 4.890981] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[ 4.911086] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.00
[ 4.920378] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.930491] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.944100] usb usb1: Product: Tegra EHCI Host Controller
[ 4.952869] usb usb1: Manufacturer: Linux 3.1.10-2.8.6+g37b9f033652b ehci_hcd
[ 4.963425] usb usb1: SerialNumber: tegra-ehci.1
[ 4.972613] hub 1-0:1.0: USB hub found
[ 4.979892] hub 1-0:1.0: 1 port detected
[ 4.987962] tegra USB phy - inst[2] platform info:
[ 4.996112] port_otg: no
[ 5.001906] has_hostpc: yes
[ 5.001923] phy_interface: USB_PHY_INTF_UTMI
[ 5.001939] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.001954] vbus_gpio: -1
[ 5.001967] vbus_gpio_inverted: 0
[ 5.001979] vbus_reg: NULL
[ 5.001990] hot_plug: enabled
[ 5.002002] remote_wakeup: enabled
[ 5.003455] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[ 5.003546] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[ 5.030941] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[ 5.050912] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.00
[ 5.051076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.051105] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.051130] usb usb2: Product: Tegra EHCI Host Controller
[ 5.051153] usb usb2: Manufacturer: Linux 3.1.10-2.8.6+g37b9f033652b ehci_hcd
[ 5.051176] usb usb2: SerialNumber: tegra-ehci.2
[ 5.052201] hub 2-0:1.0: USB hub found
[ 5.052250] hub 2-0:1.0: 1 port detected
[ 5.053239] Initializing USB Mass Storage driver...
[ 5.053495] usbcore: registered new interface driver usb-storage
[ 5.053515] USB Mass Storage support registered.
[ 5.053732] usbcore: registered new interface driver libusual
[ 5.054005] usbcore: registered new interface driver usbserial
[ 5.054100] USB Serial support registered for generic
[ 5.054236] usbcore: registered new interface driver usbserial_generic
[ 5.054256] usbserial: USB Serial Driver core
[ 5.054345] USB Serial support registered for pl2303
[ 5.054498] usbcore: registered new interface driver pl2303
[ 5.054517] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 5.054539] Nvidia Tegra High-Speed USB SOC Device Controller driver (Apr 30, 2012)
[ 5.054708] tegra USB phy - inst[0] platform info:
[ 5.054726] port_otg: yes
[ 5.054739] has_hostpc: yes
[ 5.054752] phy_interface: USB_PHY_INTF_UTMI
[ 5.054767] op_mode: TEGRA_USB_OPMODE_DEVICE
[ 5.054781] vbus_pmu_irq: 0
[ 5.054794] vbus_gpio: -1
[ 5.054805] charging: disabled
[ 5.054817] remote_wakeup: disabled
[ 5.057821] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[ 5.057969] tegra-otg tegra-otg: SUSPEND --> HOST
[ 5.058321] tegra USB phy - inst[0] platform info:
[ 5.058341] port_otg: yes
[ 5.058353] has_hostpc: yes
[ 5.058366] phy_interface: USB_PHY_INTF_UTMI
[ 5.058382] op_mode: TEGRA_USB_OPMODE_HOST
[ 5.058396] vbus_gpio: 157
[ 5.058408] vbus_gpio_inverted: 0
[ 5.058421] vbus_reg: NULL
[ 5.058433] hot_plug: enabled
[ 5.058445] remote_wakeup: enabled
[ 5.059880] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[ 5.059972] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[ 5.080980] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[ 5.100906] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.00
[ 5.101075] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.101106] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.101131] usb usb3: Product: Tegra EHCI Host Controller
[ 5.101154] usb usb3: Manufacturer: Linux 3.1.10-2.8.6+g37b9f033652b ehci_hcd
[ 5.101177] usb usb3: SerialNumber: tegra-ehci.0
[ 5.102231] hub 3-0:1.0: USB hub found
[ 5.102280] hub 3-0:1.0: 1 port detected
[ 5.440421] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.440452] android_usb gadget: Number of LUNs=1
[ 5.440489] lun0: LUN: removable file: (no medium)
[ 5.441367] android_usb gadget: android_usb ready
[ 5.441396] tegra-udc: bind to driver android_usb
[ 5.570736] input: stmpe-ts as /devices/virtual/input/input0
[ 5.583408] using rtc device, m41t00, for alarms
[ 5.588090] rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
[ 5.602030] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc1
[ 5.612475] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[ 5.625655] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 5.638631] tps6591x 4-002d:
[ 5.638643] getting alarm time::
[ 5.652368] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 5.662726] rtc_tps6591x rtc_tps6591x.0: rtc core: registered rtc_tps6591x as rtc2
[ 5.686274] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0
[ 5.821007] i2c /dev entries driver
[ 5.829964] lirc_dev: IR Remote Control driver registered, major 242
[ 5.840367] IR NEC protocol handler initialized
[ 5.848711] IR RC5(x) protocol handler initialized
[ 5.857215] IR RC6 protocol handler initialized
[ 5.865458] IR JVC protocol handler initialized
[ 5.873620] IR Sony protocol handler initialized
[ 5.881878] IR RC5 (streamzap) protocol handler initialized
[ 5.891075] IR MCE Keyboard/mouse protocol handler initialized
[ 5.900566] IR LIRC bridge handler initialized
[ 5.908682] Linux video capture interface: v2.00
[ 5.917696] usbcore: registered new interface driver uvcvideo
[ 5.927183] USB Video Class driver (1.1.1)
[ 5.935487] trpc_sema_init: registered misc dev 10:55
[ 5.944653] trpc_node_register: Adding 'local' to node list
[ 5.956118] nvavp nvavp: allocated IOVM at ff00000 for AVP os
[ 5.986842] tegra_wdt tegra_wdt.0: tegra_wdt_probe done
[ 5.996244] tegra_wdt tegra_wdt.1: tegra_wdt_probe done
[ 6.005460] tegra_wdt tegra_wdt.2: tegra_wdt_probe done
[ 6.014321] Bluetooth: HCI UART driver ver 2.2
[ 6.022252] Bluetooth: HCI H4 protocol initialized
[ 6.030404] Bluetooth: HCILL protocol initialized
[ 6.038489] Bluetooth: BlueSleep Mode Driver Ver 1.1
[ 6.047749] cpuidle: using governor ladder
[ 6.056031] cpuidle: using governor menu
[ 6.063108] sdhci: Secure Digital Host Controller Interface driver
[ 6.072427] sdhci: Copyright(c) Pierre Ossman
[ 6.079752] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.088503] sdhci_tegra_init+ #####
[ 6.095357] sdhci-tegra sdhci-tegra.3: Error: tegra3 io dpd not supported for sdhci-tegra.3
[ 6.111198] mmc0: Invalid maximum block size, assuming 512 bytes
[ 6.120656] mmc0: no vmmc regulator found
[ 6.133004] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[ 6.147456] Failed gpio lp0 enable for irq=395, error=-22
[ 6.156579] sdhci-tegra sdhci-tegra.2: SD card wake-up event registrationfailed with oor: -22
[ 6.178186] mmc1: Invalid maximum block size, assuming 512 bytes
[ 6.190061] mmc1: no vmmc regulator found
[ 6.210011] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[ 6.229302] Failed gpio lp0 enable for irq=453, error=-22
[ 6.240935] sdhci-tegra sdhci-tegra.0: SD card wake-up event registrationfailed with eroor: -22
[ 6.257949] sdhci-tegra sdhci-tegra.0: vddio_sdmmc regulator not found: -19.Assuming vddio_sdmmc is notrequired.
[ 6.262868] [mmc]:mmc_decode_cid:123 cid.prv 0x10
[ 6.275029] [mmc]:mmc_read_ext_csd:297 ext_csd.sectors 0x72c000 prod_name Q2J54A BOOT_MULTI 0x80
[ 6.279628] mmc0: new high speed DDR MMC card at address 0001
[ 6.280621] mmcblk0: mmc0:0001 Q2J54A 3.58 GiB
[ 6.281198] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB
[ 6.281716] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB
[ 6.283571] mmcblk0: p1 p2
[ 6.284076] mmcblk0: p2 size 15175680 extends beyond EOD, truncated
[ 6.361525] sdhci-tegra sdhci-tegra.0: vddio_sd_slot regulator not found: -19. Assuming vddio_sd_slot is not required.
[ 6.364775] mmcblk0boot1: unknown partition table
[ 6.390452] sdhci-tegra sdhci-tegra.0: Error: tegra3 io dpd not supported for sdhci-tegra.0
[ 6.393569] mmcblk0boot0: unknown partition table
[ 6.417049] [mmc]:mmc_rescan_try_freq:2119 mmc0: eMMC completed
[ 6.421874] mmc2: Invalid maximum block size, assuming 512 bytes
[ 6.421904] mmc2: no vmmc regulator found
[ 6.425158] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[ 6.425213] sdhci_tegra_init- #####
[ 6.452530] tegra-se tegra-se: tegra_se_probe: complete
[ 6.458219] usbcore: registered new interface driver usbhid
[ 6.466488] usbhid: USB HID core driver
[ 6.475017] stmpe-adc stmpe-adc.1: Initialized
[ 7.031408] usbcore: registered new interface driver snd-usb-audio
[ 7.061821] sgtl5000 4-000a: Failed to get supply 'VDDD': -19
[ 7.068908] print_constraints: 4-000a: 850 <--> 1600 mV at 1200 mV normal
[ 7.077124] sgtl5000 4-000a: Using internal LDO instead of VDDD
[ 7.092967] sgtl5000 4-000a: sgtl5000 revision 17
[ 7.106204] asoc: sgtl5000 <-> tegra30-i2s.2 mapping ok
[ 7.112927] asoc: dit-hifi <-> tegra30-spdif mapping ok
[ 7.120093] ALSA device list:
[ 7.124243] #0: apalis_t30-sgtl5000
[ 7.129039] #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[ 7.135491] oprofile: hardware counters not available
[ 7.141685] oprofile: using timer interrupt.
[ 7.147143] GACT probability NOT on
[ 7.151708] Mirror/redirect action on
[ 7.156405] u32 classifier
[ 7.160123] Actions configured
[ 7.164520] Netfilter messages via NETLINK v0.30.
[ 7.170261] nf_conntrack version 0.5.0 (15650 buckets, 62600 max)
[ 7.177640] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 7.185637] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 7.192629] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.199091] arp_tables: (C) 2002 David S. Miller
[ 7.204785] TCP cubic registered
[ 7.209104] NET: Registered protocol family 10
[ 7.215322] Mobile IPv6
[ 7.218774] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 7.225651] NET: Registered protocol family 17
[ 7.231105] NET: Registered protocol family 15
[ 7.236478] can: controller area network core (rev 20090105 abi 8)
[ 7.243673] NET: Registered protocol family 29
[ 7.249085] can: raw protocol (rev 20090105)
[ 7.254354] can: broadcast manager protocol (rev 20090105 t)
[ 7.261100] Bluetooth: RFCOMM TTY layer initialized
[ 7.266972] Bluetooth: RFCOMM socket layer initialized
[ 7.273083] Bluetooth: RFCOMM ver 1.11
[ 7.277766] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.284032] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 7.290989] 8021q: 802.1Q VLAN Support v1.8
[ 7.296153] Registering the dns_resolver key type
[ 7.301872] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 7.311676] Registering SWP/SWPB emulation handler
[ 7.326548] Disabling clocks left on by bootloader:
[ 7.332484] audio_2x
[ 7.335943] audio4_2x
[ 7.339429] audio3_2x
[ 7.342893] audio2_2x
[ 7.346319] audio1_2x
[ 7.349727] audio0_2x
[ 7.353112] audio
[ 7.356112] audio4
[ 7.359160] audio3
[ 7.362208] audio2
[ 7.365211] audio1
[ 7.368178] audio0
[ 7.371156] dsi2-fixed
[ 7.374429] dsi1-fixed
[ 7.377673] uarta
[ 7.380452] i2c2-fast
[ 7.383586] nor
[ 7.386168] bsev
[ 7.388809] bsea
[ 7.391432] fuse_burn
[ 7.394461] cclk_lp
[ 7.397266] pll_x_out0
[ 7.400279] pll_p_out2
[ 7.403277] pll_c_out1
[ 7.406235] pll_m_out1
[ 7.409274] CPU rate: 1150 MHz
[ 7.412834] tegra_fuse_program_init: no vdd_fuse. fuse write disabled
[ 7.419732] DVFS: Got RTC device name:rtc0
[ 7.424671] tegra_dvfs: vdd_cpu: stats above 1237 mV will be squashed
[ 7.433533] tegra3_dvfs: minimum cap.emc rate 800000000 requires 1300 mV
[ 7.440152] tegra dvfs: tegra sysfs cap interface is initialized
[ 7.447587] tegra_actmon.emc: Completed initialization (0)
[ 7.453853] tegra_actmon.avp: Completed initialization (0)
[ 7.461116] registered taskstats version 1
[ 7.466073] regulator_init_complete: gpio_reg_sdmmc3_vdd_sel: disabling
[ 7.473863] input: gpio-keys as /devices/platform/gpio-keys.0/input/input1
[ 7.482118] rtc-ds1307 0-0068: setting system clock to 2000-01-01 00:01:12 UTC (946684872)
[ 7.496285] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[ 7.503969] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[ 7.708748] kjournald starting. Commit interval 5 seconds
[ 7.708841] EXT3-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 7.709200] EXT3-fs (mmcblk0p2): 1 orphan inode deleted
[ 7.709207] EXT3-fs (mmcblk0p2): recovery complete
[ 7.747681] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
[ 7.755863] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[ 7.764932] devtmpfs: mounted
[ 7.919329] systemd[1]: System time before build time, advancing clock.
[ 8.341606] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 8.375485] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2017.12!
[ 8.402644] systemd[1]: Set hostname to <apalis-t30>.
[ 8.415270] systemd[1]: Initializing machine ID from D-Bus machine ID.
[ 8.426371] systemd[1]: Installed transient /etc/machine-id file.
[ 9.001083] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 9.031402] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 9.061357] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 9.081761] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 9.111999] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 9.142781] systemd[1]: system.slice: Failed to set invocation ID on control group /system.slice, ignoring: Operation not supported
[ 9.162688] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 9.197760] systemd[1]: sys-fs-fuse-connections.mount: Failed to set invocation ID on control group /system.slice/sys-fs-fuse-connections.mount, ignoring: Operation not supported
[ 9.228415] systemd[1]: Mounting FUSE Control File System...
[ 9.261965] systemd[1]: system-getty.slice: Failed to set invocation ID on control group /system.slice/system-getty.slice, ignoring: Operation not supported
[ 9.284646] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 9.311991] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 9.352003] systemd[1]: system-serial\x2dgetty.slice: Failed to set invocation ID on control group /system.slice/system-serial\x2dgetty.slice, ignoring: Operation not supported
[ 9.380779] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 9.411812] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 9.441778] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 9.471361] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 9.504175] systemd[1]: tmp.mount: Failed to set invocation ID on control group /system.slice/tmp.mount, ignoring: Operation not supported
[ 9.527959] systemd[1]: Mounting Temporary Directory (/tmp)...
[ 9.552722] systemd[1]: systemd-sysctl.service: Failed to set invocation ID on control group /system.slice/systemd-sysctl.service, ignoring: Operation not supported
[ 9.584448] systemd[1]: Starting Apply Kernel Variables...
[ 9.612563] systemd[1]: systemd-journald.service: Failed to set invocation ID on control group /system.slice/systemd-journald.service, ignoring: Operation not supported
[ 9.646211] systemd[1]: Starting Journal Service...
[ 9.672206] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Request[ 9.692693] systemd-journald[121]: Failed to register hostname fd in event loop, ignoring: Operation not permitted
[ 9.721132] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 9.741942] systemd[1]: systemd-fsck-root.service: Failed to set invocation ID on control group /system.slice/systemd-fsck-root.service, ignoring: Operation not supported
[ 9.764068] systemd[1]: Starting File System Check on Root Device...
[ 9.792332] systemd[1]: sys-kernel-debug.mount: Failed to set invocation ID on control group /system.slice/sys-kernel-debug.mount, ignoring: Operation not supported
[ 9.815132] systemd[1]: Mounting Kernel Debug File System...
[ 9.824671] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initct[ 9.837356] systemd[1]: user.slice: Failed to set invocation ID on control group /user.slice, ignoring: Operation not supported
[ 9.855313] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice Us[ 9.866432] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 9.879015] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel D[ 9.890354] systemd[1]: Mounted FUSE Control File System.
ebug File System.
[ OK 9.900263] systemd[1]: Mounted Temporary Directory (/tmp).
m] Mounted FUSE Control File System.
[ systemd[1]: Started Journal Service.
[0;32m OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Journal Service.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started File System Check on Root Device.
Starting Remount Root and Kernel File Systems...
[ 10.182961] EXT3-fs (mmcblk0p2): using internal journal
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ 10.528227] systemd-journald[121]: Received request to flush runtime journal from PID 1
Starting udev Kernel Device Manager...
[ 10.554494] systemd-journald[121]: File /var/log/journal/15a25ed6da9c4baa84a8ba57eca89a63/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Commit a transient machine-id on disk...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[FAILED] Failed to start Commit a transient machine-id on disk.
See 'systemctl status systemd-machine-id-commit.service' for details.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Found device /dev/ttyS0.
[ OK ] Reached target Sound Card.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ness of backlight:pwm-backlight...
Starting Create Volatile Files and Directories...
[ 11.391021] tegra-i2c tegra-i2c.0: I2c error status 0x00000008
[ 11.398699] tegra-i2c tegra-i2c.0: no acknowledge from address 0x4a
[ 11.406730] tegra-i2c tegra-i2c.0: Packet status 0x00010009
[ 11.416213] atmel_mxt_ts 0-004a: __mxt_read_reg: i2c transfer failed (-121)
[ 11.428305] tegra-i2c tegra-i2c.0: I2c error status 0x0000000a
[ 11.436105] tegra-i2c tegra-i2c.0: no acknowledge from address 0x24
[ 11.444326] tegra-i2c tegra-i2c.0: Packet status 0x00010009
[ 11.451863] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-121)
[ 11.466117] atmel_mxt_ts 0-004a: Trying alternate bootloader address
[ OK ] Started Load/Save Screen Backlight …htness of backl[ 11.478114] tegra-i2c tegra-i2c.0: I2c error status 0x0000000a
[ 11.488562] tegra-i2c tegra-i2c.0: no acknowledge from address 0x26
[ 11.496662] tegra-i2c tegra-i2c.0: Packet status 0x00010009
ight:pwm-backlight.
[ 11.503754] atmel_mxt_ts 0-004a: mxt_bootloader_read: i2c recv failed (-121)
[ 11.531745] atmel_mxt_ts: probe of 0-004a failed with error -121
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
Starting Network Service...
Starting sshd.socket.
Starting Enable NVIDIA T30 CPU Hot-Plugging...
[ 12.028619] Tegra auto-hotplug enabled
[ OK ] Listening on sshd.socket.
[ OK ] Started Enable NVIDIA T30 CPU Hot-Plugging.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Reached target Containers.
[ OK ] Started Timestamping service.
Starting Avahi mDNS/DNS-SD Stack...
Starting Login Service...
Starting Telephony service...
Starting Save/Restore Sound Card State...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Telephony service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
Starting Connection service...
Starting RPC Bind Service...
[ OK ] Started Network Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started RPC Bind Service.
[ OK ] Started Login Service.
[ OK ] Started Connection service.
[ OK ] Reached target Network.
Starting Load/Configure the kernel …iver providing the RNDIS gadget...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ 13.134180] android_usb: already disabled
[ 13.146334] rndis_function_bind_config MAC: 00:00:00:00:00:00
Starting Permit User Sessions...[ 13.164977] android_usb gadget: using random self ethernet address
[ 13.178440] android_usb gadget: using random host ethernet address
[ 13.216573] rndis0: MAC 4e:70:bb:8a:dd:45
[ 13.225547] rndis0: HOST MAC ca:7b:7f:88:3a:9e
[ OK ] Started Permit User Sessions.
[ 13.309215] ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ OK ] Started LXDE Display Manager.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Load/Configure the kernel driver providing the RNDIS gadget.
[ OK ] Started Update UTMP about System Runlevel Changes.
Starting Hostname Service...
Starting WPA supplicant...
[ OK ] Started WPA supplicant.
[ 15.403452] ADDRCONF(NETDEV_UP): enp1s0: link is not ready
[ 15.408980] 8021q: adding VLAN 0 to HW filter on device enp1s0
[ OK ] Started Hostname Service.
[ OK ] Created slice User Slice of root.
Starting User Manager for UID 0...
[ OK ] Started Session c1 of user root.
[ OK ] Started User Manager for UID 0.
[ 17.251924] igb 0000:01:00.0: enp1s0: igb: enp1s0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
| | | | | |--- || --'| [ 17.281038] ADDRCONF(NETDEV_CHANGE): enp1s0: link becomes ready
The Angstrom Di
Angstrom v2017.12 - Kernel
Apalis-T30_LXDE-Image 2.8b6.184 20190401
apalis-t30 login:
