I realise that this question is more general than a Toradex-specific question but I think it applies nevertheless.
Currently bitbaking an Apalis-T30 image based on angstrom-qt5-x11-image
. I’ve added the following into the bblayers.conf
file:
${TOPDIR}/../layers/meta-gstreamer1.0
And in local.conf
I’ve added the following:
IMAGE_INSTALL_append = " gstreamer1.0 gstreamer1.0-plugins-base gstreamer1.0-plugins-bad "
When I bitbake -k angstrom-qt5-x11-image
, everything kicks off smoothly but then I encounter an error with the gstreamer-plugins-base
package, where the error is:
error: 'EGL_PLATFORM_GBM_MESA' undeclared; did you mean 'EGL_PLATFORM_X11_EXT'?
Given that I’m building the x11
image for the Apalis-T30, I might have assumed that the EGL_PLATFORM_X11_EXT
was defined somewhere. Or do I need to add some definition as part of the DISTRO_FEATURES_xxx
or IMAGE_INSTALL_xxx
in the local.conf
file?
