Hi.
Recently I was assigned to a proyect to work with an Apalis iMX6 withthe carrier board. I could not see anythin in the monitor, I tried both DVI and VGA, so I conneted the board to a serial terminal using the USB.
The resul is always the same:
[upload|4wp57zrFSs1MhbIBPkRHFqTYxAA=]
After certain time the process holds and does not continue. I do not know the reason.
I tried to boot from a SD card, but the bootloader tells me that it cannot find the uImage file, and does not support zImage format.
This is the info of the board provided by the console:
[upload|8qMOgYdnIMDUWaWGq6CDoXFioBQ=]
Kind regards.
