Hi Toradex Team,
I’m unable to install toradex easy installer and/or deleting torizon core.
I’m following this manual which works for other devices:
Loading Toradex Easy Installer | Toradex Developer Center
Currently installed version:
Linux apalis-imx6-10884914 5.4.193-5.7.0+git.f5d73fd6e9f8 #1-TorizonCore SMP Fri Jun 24 10:15:32 UTC 2022 armv7l armv7l armv7l GNU/Linux
Output running the script from the Easy Installer
Apalis-iMX6_ToradexEasyInstaller_1.8-20181019>recovery-windows.bat
config file <recovery\\imx_usb.conf>
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
→ vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
→ vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
→ vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
→ vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
config file <recovery\\mx6_usb_rom.conf>
parse recovery\\mx6_usb_rom.conf
Trying to open device vid=0x15a2 pid=0x0054
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x13f00000
dcd 0
clear_dcd 0
plug 0
jump_mode 2
jump_addr 0x00000000
== end work itemloading binary file(SPL) to 00907400, skip=0, fsize=bc00 type=aa
<<<48128, 48128 bytes>>>
succeeded (status 0x88888888)
jumping to 0x00907400
config file <recovery\\mx6_usb_sdp_spl.conf>
parse recovery\\mx6_usb_sdp_spl.conf
Trying to open device vid=0x1b67 pid=0x4fff
Interface 0 claimed
== work item
filename u-boot.img
load_size 0 bytes
load_addr 0x03f00001
dcd 0
clear_dcd 0
plug 0
jump_mode 2
== end work itemloading binary file(u-boot.img) to 177fffc0, skip=0, fsize=4d3a8 type=aa
<<<316328, 316416 bytes>>>
jumping to 0x177fffc0
config file <recovery\\mx6_usb_sdp_uboot.conf>
parse recovery\\mx6_usb_sdp_uboot.conf
Trying to open device vid=0x1b67 pid=0x4000
Interface 0 claimed
== work item
filename tezi.itb
load_size 0 bytes
load_addr 0x12100000
dcd 0
clear_dcd 0
plug 0
jump_mode 0
== end work item
load_addr=12100000loading binary file(tezi.itb) to 12100000, skip=0, fsize=14174ec type=0
<<<21066988, 21067776 bytes>>>
== work item
filename boot-sdp.scr
load_size 0 bytes
load_addr 0x12000000
dcd 0
clear_dcd 0
plug 0
jump_mode 1
jump_addr 0x12000000
== end work item
load_addr=12000000loading binary file(boot-sdp.scr) to 12000000, skip=0, fsize=16a type=aa
<<<362, 1024 bytes>>>
jumping to 0x12000000
ECHO is off.
== Successfully downloaded Tezi
Press any key to continue . . .
It still boots into the old torizon version and not into the easy installer screen.
Thanks a lot and best regards
Patrick Rohner
