Apalis iMX8X Ethernet PHY
Greetings,
We were going through the Apalis iMX8X datasheet when we noticed conflicting information on the ethernet transceiver used on this SOM. Section 1.4 specifies that KSZ9131 is the ethernet PHY used for Apalis iMX8X, but the block diagram in Section 2 suggests that the KSZ9031 is used instead. We would like to know which is the correct model of the eth PHY used on the SOM.
Many thanks.
Hello YHChng,
The module uses the KSZ9131.
Thank you for hinting us at the mistake in the Block .
Matthias
