I am experiencing an issue with the HDMI resolution, which seems to be related to HDMI I2C. Here are the hardware and software details:
Hardware:
- Model: Toradex 0048 Apalis iMX8QP 2GB WB V1.0B
- Carrier: Ixora Carrier Board V1.1B
I have tested different operating systems:
- Boot2Qt 5.15.14 v5.15.14-lts.xml (self-built)
- Boot2Qt 6.5.2 v6.5.2-lts.xml (self-built)
- TorizonCore with evaluation containers (6.3.0+build.4.modified.container) (from Toradex Easy Installer)
- TorizonCore with evaluation containers (5.7.2+build.20.modified.container) (from Toradex Easy Installer)
The issue I’m facing is that the HDMI display resolution remains fixed at 800x480, regardless of the display I connect (tried 1920x1080, 1280x800). The following error is observed when running dmesg | grep hdmi:
[ 9.950994] [drm:cdns_hdmi_get_edid_block [cdns_mhdp_drmcore]] ERROR get block[0] edid failed: -22
[ 9.962607] [drm:cdns_hdmi_connector_get_modes [cdns_mhdp_drmcore]] ERROR Invalid edid
In the past, with older Boot2Qt builds, I managed to mitigate this issue in Boot2Qt 5.15.14 (our current production build) by setting the fdtfile environment variable in u-boot as follows:
setenv preboot fdtfile imx8qm-apalis-eval.dtb
However, as we are transitioning to Qt6 due to significant changes in our product, I built a Boot2Qt6 image (based on the manifest v6.5.2-lts.xml). Unfortunately, even after attempting to force the device tree through u-boot, the resolution issue persists.
I also attempted to install the TorizonCore demo image (both BSP6 and BSP5) with and without the u-boot change, but the resolution problem remains unresolved.
Any guidance on an official solution for this problem would be greatly appreciated.
Thank you.
P.S. I already know that the Apalis iMX8QP 2GB WB V1.0B is deprecated and that we should go with de V1.1, and that there was some changes to the hdmi and i2c that came with the v1.1. But since we already have a fleet of device deployed with V1.0B we must still support it. So since it worked with Boot2Qt5 there should be some kind of workaround to make it work with Boot2Qt6
