My setup is the followging:
Toradex Multimedia Reference Image 6.1.0 (latest from Toradex Easy Installer)
U-Boot 2022.04-6.1.0-devel+git.1c83b1aaad86 (Jan 05 2023 - 08:25:45 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 88C
Carrier: Ixora v1.2
I can not run command “ums 0 mmc 0” to mount MMC on my host, I get the following error:
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 67C
DRAM: 4 GiB
Core: 186 devices, 15 uclasses, devicetree: separate
Loading Environment from MMC… OK
In: serial@5a070000
Out: serial@5a070000
Err: serial@5a070000
Model: Toradex 0037 Apalis iMX8QM 4GB WB IT V1.1C
Serial#: 06852374
BuildInfo:
- SCFW f5623878, SECO-FW c9de51c0, IMX-MKIMAGE 37648c8b, ATF 9202efc
- U-Boot 2022.04-6.1.0-devel+git.1c83b1aaad86
Net: eth0: ethernet@5b040000
Normal Boot
Apalis iMX8 # ums 0 mmc 0
Unknown command ‘ums’ - try ‘help’
Apalis iMX8 #
It is any other way to mount the emmc on a USB host.
Kind regards,
Saúl Trapiello
