Hello All,
We purchased Apalis iMX8 QuadMax 8GB Wi-Fi / Bluetooth IT with Apalis Evaluation Board V1.1Z.
The initial setup was ok and we were able to run applications on the device also. But after 4/5 days of working on it, the system abruptly crashed.
When I view the UART debug terminal, the kernel keep restarting again and again continuously.
We have tried re-installing the Toradex Easy Installer through USB OTG and USB memory as well, as given on the Toradex website, but it does not load the easy installer.
Could anyone please help us?
Hello @sachinkumarbhoi , welcome to the community.
Could you please share with us the UART output that shows these restarts?
Josep
This is the output we are getting with the UART debugger output
U-Boot 2022.04-6.3.0+git.c71ae7141f30 (Jan 01 1970 - 00:00:00 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 35C
DRAM: 8 GiB
Core: 193 devices, 19 uclasses, devicetree: separate
In: serial
Out: serial
Err: serial
Model: Toradex 0067 Apalis iMX8QM 8GB WB IT V1.1A
Serial#: 14903912
BuildInfo:
- SCFW f5623878, SECO-FW c9de51c0, IMX-MKIMAGE 3bfcfccb, ATF 3c1583b
- U-Boot 2022.04-6.3.0+git.c71ae7141f30
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
973 bytes read in 3 ms (316.4 KiB/s)
## Executing script at 9d480000
6633 bytes read in 4 ms (1.6 MiB/s)
169157 bytes read in 7 ms (23 MiB/s)
117 bytes read in 3 ms (38.1 KiB/s)
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2205 bytes read in 4 ms (538.1 KiB/s)
Applying Overlay: apalis-imx8_spi1_spidev_overlay.dtbo
551 bytes read in 4 ms (133.8 KiB/s)
Applying Overlay: apalis-imx8_spi2_spidev_overlay.dtbo
13348013 bytes read in 293 ms (43.4 MiB/s)
11528894 bytes read in 253 ms (43.5 MiB/s)
Uncompressing Kernel Image
## Flattened Device Tree blob at 9d400000
Booting using the fdt blob at 0x9d400000
Loading Device Tree to 00000000fd622000, end 00000000fd66efff ... OK
Starting kernel ...
[ 1.775652] debugfs: Directory 'lvds1' with parent 'pm_genpd' already present!
[ 1.783015] debugfs: Directory 'mipi1-i2c1' with parent 'pm_genpd' already present!
[ 1.790745] debugfs: Directory 'mipi1-i2c0' with parent 'pm_genpd' already present!
[ 1.798464] debugfs: Directory 'mipi1-pwm0' with parent 'pm_genpd' already present!
[ 1.806392] debugfs: Directory 'mipi1' with parent 'pm_genpd' already present!
Starting version 250.5+
[ 7.099462] debugfs: File 'Capture' in directory 'dapm' already present!
[ 7.962559] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 16.103858] Bluetooth: hci0: unexpected event for opcode 0x0000
[ 31.277741] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[ 31.864074] reboot: Restarting system
DRAM: 8 GiB
In: serial
Out: serial
Err: serial
Serial#: 14903912
BuildInfo:
Fastboot: Normal
Normal Boot
Scanning mmc 0:1...
973 bytes read in 2 ms (474.6 KiB/s)
6633 bytes read in 3 ms (2.1 MiB/s)
169157 bytes read in 8 ms (20.2 MiB/s)
117 bytes read in 4 ms (28.3 KiB/s)
551 bytes read in 3 ms (178.7 KiB/s)
13348013 bytes read in 292 ms (43.6 MiB/s)
11528894 bytes read in 254 ms (43.3 MiB/s)
Starting kernel ...
[ 1.875700] debugfs: Directory 'lvds1' with parent 'pm_genpd' already present!
[ 1.883063] debugfs: Directory 'mipi1-i2c1' with parent 'pm_genpd' already present!
[ 1.890940] debugfs: Directory 'mipi1-i2c0' with parent 'pm_genpd' already present!
[ 1.898632] debugfs: Directory 'mipi1-pwm0' with parent 'pm_genpd' already present!
[ 1.906312] debugfs: Directory 'mipi1' with parent 'pm_genpd' already present!
[ 6.980412] debugfs: File 'Capture' in directory 'dapm' already present!
[ 7.665951] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 15.883555] Bluetooth: hci0: unexpected event for opcode 0x0000
[ 31.398448] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[ 32.163907] reboot: Restarting system
Did this issue happen after trying to downgrade from Torizoncore 6 to TorizonCore5?
Josep
Hello
No, we didn’t try to downgrade.
I was trying to run an application directly through SSH without (VSCode + Host PC method) by myself in the Apalis board, then suddenly I got disconnected and when I tried connecting again, I could not connect via SSH.
Then we checked the UART output, and we saw that the system is restarting continuously.
is that a custom application or one of ours?
Best regrds,
Josep
It is a simple Python code on torizon debian I was trying to run. Also, I was not running any code actively while it happened. It was just connected to SSH.
Since your problem might be difficult to reproduce, let’s focus on the recovery procedure.
Can you explain the steps that you took to put the module in recovery mode and load Toradex Easy Installer?
Please also share the output of the recovery script and the debug UART while performing this procedure.
Josep
We have tried two different procedure, both of which is not fruitful
- Loading Toradex Easy Installer | Toradex Developer Center
We connected the OTG port X49 to the computer using the required cable. Our guess is system can’t find the USB device.
We formatted a USB stick and renamed the boot-tezi.scr to boot.scr, and followed the procedure.
The boot fails, and here is attached UART output
[ 7.137759] debugfs: File 'Capture' in directory 'dapm' already present!
[ 7.886088] imx-audmix imx-audmix.0: failed to find SAI platform device
[ 15.859757] Bluetooth: hci0: unexpected event for opcode 0x0000
[ 31.279861] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[ 31.923894] reboot: Restarting system
CPU: NXP i.MX8QM RevB A53 at 1200 MHz at 59C
DRAM: 8 GiB
In: serial
Out: serial
Err: serial
Serial#: 14903912
BuildInfo:
Fastboot: Normal
Normal Boot
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 # usb info
USB is stopped. Please issue 'usb start' first.
Apalis iMX8 # usb start
starting USB...
Bus usb@5b0d0000: Port not available.
Bus usbh3: XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usbh3 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Apalis iMX8 # usb tree
USB device tree:
1 Hub (5 Gb/s, 0mA)
| U-Boot XHCI Host Controller
+-2 Mass Storage (480 Mb/s, 500mA)
SMI Corporation USB DISK CCYYMMDDHHmmSS8OW4R2
Apalis iMX8 # run bootcmd_usb0
Device 0: Vendor: SMI Rev: 1100 Prod: USB DISK
Type: Removable Hard Disk
Capacity: 15200.0 MB = 14.8 GB (31129600 x 512)
... is now current device
Scanning usb 0:1...
3192 bytes read in 5 ms (623 KiB/s)
43 bytes read in 5 ms (7.8 KiB/s)
** No boot file defined **
Unknown command 'hdp' - try 'help'
SCRIPT FAILED: continuing...
Apalis iMX8 #
Have you ensured that you put the device in recovery mode, as described here?
You have to make sure that you temporarily short the two indicated pads, marked on the picture in order to put the module in recovery mode.
Josep
Hello Joseph
We did the short circuit as it is given on the website. However, the device does not seem to be entering the recovery mode.
Are we missing something?
Sachin
How do you verify that the device is not entering recovery mode? Please ensure that the pads are securely shorted before you apply power, and they should be released 6 seconds after the module powers on. You can determine if the module is in recovery mode by the absence of any output on the debug UART.
@alex.tx
We did follow the correct procedure to enter recovery mode. We have verified using UART output, and the UART output never stops.
Since the module cannot be put in recovery mode, you can start an RMA as explained here:
Josep
