Dear Community,
I have and Toradex Apalis iMX8QM V1.1C 4GB WB IT and an Ixora 1.1A. Although my iMX8 is a WB version, I can’t find any wifi interfaces.
iw dev
and
nmcli device wifi list
commands don´t show anything. However, it seems that wifi modules are loaded:
root@localhost:~# lsmod
Module Size Used by
snd_soc_imx_cdnhdmi 16384 0
crct10dif_ce 16384 1
mwifiex_pcie 45056 0
snd_soc_hdmi_codec 20480 1 snd_soc_imx_cdnhdmi
mwifiex 294912 1 mwifiex_pcie
cfg80211 393216 1 mwifiex
rfkill 36864 2 cfg80211
ahci_imx 28672 0
flexcan 32768 0
can_dev 36864 1 flexcan
mxc_jpeg_encdec 36864 0
cdns_mhdp_imx 40960 0
ip_tables 32768 0
x_tables 40960 1 ip_tables
root@localhost:~# uname -a
Linux localhost 5.4.129-37371-gc99d3f9d208b #1 SMP PREEMPT Wed Oct 27 11:07:21 CEST 2021 aarch64 aarch64 aarch64 GNU/Linux
How can I bring up the wifi interface?
Thanks in advance,
Ander.
Hi @Andermutu !
From your command lines, seems like you built your own image using Yocto (root@localhost
). Is that right? The reference images present the module type and serial number at the beginning of command lines.
I took an Apalis IMX8QM v1.1B 4GB WB IT and installed the Reference Minimal Image 5.4.0+build.11 (dunfell). nmcli
is not available, but here is what I got.
Using iw
root@apalis-imx8-06804757:~# iw dev
phy#0
Interface uap0
ifindex 6
wdev 0x2
addr d8:c0:a6:cf:7a:4f
type AP
txpower 0.00 dBm
Interface mlan0
ifindex 5
wdev 0x1
addr d8:c0:a6:cf:78:4f
type managed
txpower 0.00 dBm
Using lsmod
root@apalis-imx8-06804757:~# lsmod
Module Size Used by
rfcomm 61440 2
8021q 36864 0
btusb 53248 0
btrtl 20480 1 btusb
btintel 24576 1 btusb
btbcm 20480 1 btusb
bluetooth 405504 30 btrtl,btintel,btbcm,btusb,rfcomm
ecdh_generic 16384 1 bluetooth
ecc 32768 1 ecdh_generic
snd_soc_hdmi_codec 20480 2 snd_soc_imx_cdnhdmi
rfkill 36864 7 bluetooth,cfg80211
ahci_imx 28672 0
flexcan 32768 0
libcomposite 69632 0
configfs 53248 2 libcomposite
Using connmanctl
root@apalis-imx8-06804757:~# connmanctl
connmanctl> enable wifi
Error wifi: Already enabled
connmanctl> scan wifi
Scan completed for wifi
connmanctl> agent on
Agent registered
connmanctl> services
*AO Wired (network's id)
reptree_back_5G (wifi network's id)
reptree_back (wifi network's id)
connmanctl>
You can see that it is working properly. If you really have built your own image, it is worth checking if maybe you disabled something related to the wifi. Also, take a look at the attached article that can be handy for dealing with wifi
