I’m trying to flash a new image to my Apalis-imx8 board using toradex-easy installer for that I’ve to short two pads to put my board in recovery mode and load toradex-easy installer. But following this process every time is not an ideal way as there is heat-sink connected on top of the board.
I’ve also worked on Apalis-imx6 and there was an easy way to load toradex-easy installer(stop at u-boot and run command bmode usb).
The documentation I’m following is - Loading Toradex Easy Installer | Toradex Developer Center
There is one more method provided - Load Easy Installer From External Media (SD Card/USB Stick) | Toradex Developer Center
but this one is also not working as I’m getting an error -
Apalis iMX8 # run bootcmd_usb0
Unknown command ‘usb’ - try ‘help’
I know this question has already been answered in this thread - How to access Apalis IMX8 recovery mode
But still if there is some other method available please share, I’ll be very thankful.
Gaurav C.
