My apalis is fresh out of the box and after installing embedded linux from TEZI, my system is unable to boot. I can see that we have started loading the kernel and then suddenly my machine goes back to uboot and cycles uboot over and over again. I can also see this error message:
CPU: Freescale i.MX8QM revB A53 at 1200 MHzError: get temperature failed! (error = 10)
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39 (Dec 31 2019 - 23:25:47 +0000)
CPU: Freescale i.MX8QM revB A53 at 1200 MHz at 36C
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.0B, Serial# 06543231
BuildInfo:
- SCFW 494c97f3, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
mmc1 is current device
Scanning mmc 1:1...
MMC: no card present
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1243 bytes read in 7 ms (172.9 KiB/s)
## Executing script at 86000000
102464 bytes read in 8 ms (12.2 MiB/s)
Loading hdp firmware from 0x0000000084000000 offset 0x0000000000002000
Loading hdp firmware Complete
105024 bytes read in 9 ms (11.1 MiB/s)
23448064 bytes read in 402 ms (55.6 MiB/s)
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Device Tree to 00000000fd65d000, end 00000000fd679a3f ... OK
/dma-controller@5a1f0000, 73440
/dma-controller@591F0000, 74320
/dma-controller@599F0000, 75296
Starting kernel ...
[ 0.000000] Linux version 4.14.159-3.0.3+gfff496c2a1bd (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Tue Dec 31 23:26:01 UTC 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Toradex Apalis iMX8QM/QP on Apalis Evaluation Board
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 28 MiB
[ 0.000000] OF: reserved mem: initialized node rpmsg_dma@0x90400000, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080200000-0x00000008ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x8fff59800-0x8fff5b5ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086400000-0x000000008fffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000008ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu s53656 r8192 d32360 u94208
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1003016
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: pci=nomsi root=PARTUUID=0e43f987-02 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] software IO TLB: mapped [mem 0xf965d000-0xfd65d000] (64MB)
[ 0.000000] Memory: 2807224K/4077568K available (13564K kernel code, 1714K rwdata, 6320K rodata, 1280K init, 434K bss, 287304K reserved, 983040K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008dc0000 ( 13568 KB)
[ 0.000000] .rodata : 0xffff000008dc0000 - 0xffff0000093f0000 ( 6336 KB)
[ 0.000000] .init : 0xffff0000093f0000 - 0xffff000009530000 ( 1280 KB)
[ 0.000000] .data : 0xffff000009530000 - 0xffff0000096dca00 ( 1715 KB)
[ 0.000000] .bss : 0xffff0000096dca00 - 0xffff000009749208 ( 435 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000008000 - 0xffff7e0022000000 ( 543 MB actual)
[ 0.000000] memory : 0xffff800000200000 - 0xffff800880000000 ( 34814 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000004] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.003081] Console: colour dummy device 80x25
[ 0.003604] console [tty0] enabled
[ 0.003658] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.003678] pid_max: default: 32768 minimum: 301
[ 0.003750] Security Framework initialized
[ 0.005064] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.005705] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.005751] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.005782] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.019897] ASID allocator initialised with 32768 entries
[ 0.027895] Hierarchical SRCU implementation.
[ 0.036560] *****Initialized MU
[ 0.036593] ***** imx8_init_pm_domains *****
[ 0.036632] dc0_power_domain : no governor for states
[ 0.036651] dc0_pll0 : no governor for states
[ 0.036667] dc0_pll1 : no governor for states
[ 0.036680] mipi0_dsi_power_domain : no governor for states
[ 0.036693] mipi0_dsi_i2c0 : no governor for states
[ 0.036706] mipi0_dsi_i2c1 : no governor for states
[ 0.036719] mipi0_dsi_pwm0 : no governor for states
[ 0.036732] lvds0_power_domain : no governor for states
[ 0.036745] lvds0_i2c0 : no governor for states
[ 0.036758] lvds0_pwm : no governor for states
[ 0.036771] hdmi_power_domain : no governor for states
[ 0.036787] hdmi_pll0 : no governor for states
[ 0.036803] hdmi_pll1 : no governor for states
[ 0.036815] hdmi_i2c : no governor for states
[ 0.036828] PD_HDMI_I2S : no governor for states
[ 0.036844] dc1_power_domain : no governor for states
[ 0.036858] dc1_pll0 : no governor for states
[ 0.036870] dc1_pll1 : no governor for states
[ 0.036883] mipi1_dsi_power_domain : no governor for states
[ 0.036896] mipi1_dsi_i2c0 : no governor for states
[ 0.036909] mipi1_dsi_i2c1 : no governor for states
[ 0.036922] PD_MIPI_1_DSI_PWM : no governor for states
[ 0.036935] lvds1_power_domain : no governor for states
[ 0.036951] lvds1_i2c0 : no governor for states
[ 0.036964] lvds1_pwm : no governor for states
[ 0.036982] lsio_pwm0 : no governor for states
[ 0.036997] lsio_pwm1 : no governor for states
[ 0.037010] lsio_pwm2 : no governor for states
[ 0.037023] lsio_pwm3 : no governor for states
[ 0.037035] lsio_pwm4 : no governor for states
[ 0.037047] lsio_pwm5 : no governor for states
[ 0.037060] lsio_pwm6 : no governor for states
[ 0.037073] lsio_pwm7 : no governor for states
[ 0.037088] lsio_kpp : no governor for states
[ 0.037101] lsio_gpio0 : no governor for states
[ 0.037113] lsio_gpio1 : no governor for states
[ 0.037126] lsio_gpio2 : no governor for states
[ 0.037139] lsio_gpio3 : no governor for states
[ 0.037151] lsio_gpio4 : no governor for states
[ 0.037164] lsio_gpio5 : no governor for states
[ 0.037176] lsio_gpio6 : no governor for states
[ 0.037189] lsio_gpio7 : no governor for states
[ 0.037204] lsio_gpt0 : no governor for states
[ 0.037219] lsio_gpt1 : no governor for states
[ 0.037232] lsio_gpt2 : no governor for states
[ 0.037245] lsio_gpt3 : no governor for states
[ 0.037257] lsio_gpt4 : no governor for states
[ 0.037270] lsio_fspi0 : no governor for states
[ 0.037282] lsio_fspi1 : no governor for states
[ 0.037295] lsio_mu5a : no governor for states
[ 0.037308] lsio_mu6a : no governor for states
[ 0.037330] conn_usb0 : no governor for states
[ 0.037343] conn_usb0_phy : no governor for states
[ 0.037359] conn_usb1 : no governor for states
[ 0.037372] conn_usb2 : no governor for states
[ 0.037386] conn_usb2_phy : no governor for states
[ 0.037398] conn_sdhc0 : no governor for states
[ 0.037413] conn_sdhc1 : no governor for states
[ 0.037426] conn_sdhc2 : no governor for states
[ 0.037439] conn_enet0 : no governor for states
[ 0.037452] conn_enet1 : no governor for states
[ 0.037464] conn_nand : no governor for states
[ 0.037477] conn_mlb0 : no governor for states
[ 0.037489] conn_dma4_ch0 : no governor for states
[ 0.037505] conn_dma4_ch1 : no governor for states
[ 0.037518] conn_dma4_ch2 : no governor for states
[ 0.037531] conn_dma4_ch3 : no governor for states
[ 0.037543] conn_dma4_ch4 : no governor for states
[ 0.037564] hsio_gpio : no governor for states
[ 0.037577] PD_HSIO_SERDES_0 : no governor for states
[ 0.037590] hsio_pcie0 : no governor for states
[ 0.037603] hsio_pcie1 : no governor for states
[ 0.037618] PD_HSIO_SERDES_1 : no governor for states
[ 0.037631] hsio_sata0 : no governor for states
[ 0.037653] audio_audiopll0 : no governor for states
[ 0.037666] audio_audiopll1 : no governor for states
[ 0.037679] audio_audioclk0 : no governor for states
[ 0.037693] audio_audioclk1 : no governor for states
[ 0.037705] PD_ASRC_0_RXA : no governor for states
[ 0.037718] PD_ASRC_0_RXB : no governor for states
[ 0.037731] PD_ASRC_0_RXC : no governor for states
[ 0.037744] PD_ASRC_0_TXA : no governor for states
[ 0.037757] PD_ASRC_0_TXB : no governor for states
[ 0.037770] PD_ASRC_0_TXC : no governor for states
[ 0.037785] audio_asrc0 : no governor for states
[ 0.037799] PD_ASRC_1_RXA : no governor for states
[ 0.037812] PD_ASRC_1_RXB : no governor for states
[ 0.037827] PD_ASRC_1_RXC : no governor for states
[ 0.037840] PD_ASRC_1_TXA : no governor for states
[ 0.037853] PD_ASRC_1_TXB : no governor for states
[ 0.037866] PD_ASRC_1_TXC : no governor for states
[ 0.037879] audio_asrc1 : no governor for states
[ 0.037892] PD_ESAI_0_RX : no governor for states
[ 0.037905] PD_ESAI_0_TX : no governor for states
[ 0.037918] audio_esai0 : no governor for states
[ 0.037934] PD_ESAI_1_RX : no governor for states
[ 0.037947] PD_ESAI_1_TX : no governor for states
[ 0.037959] audio_esai1 : no governor for states
[ 0.037973] PD_SPDIF_0_RX : no governor for states
[ 0.037985] PD_SPDIF_0_TX : no governor for states
[ 0.037998] audio_spdif0 : no governor for states
[ 0.038011] PD_SPDIF_1_RX : no governor for states
[ 0.038024] PD_SPDIF_1_TX : no governor for states
[ 0.038040] audio_spdif1 : no governor for states
[ 0.038053] PD_SAI_0_RX : no governor for states
[ 0.038069] PD_SAI_0_TX : no governor for states
[ 0.038081] audio_sai0 : no governor for states
[ 0.038094] PD_SAI_1_RX : no governor for states
[ 0.038107] PD_SAI_1_TX : no governor for states
[ 0.038120] audio_sai1 : no governor for states
[ 0.038133] PD_SAI_2_RX : no governor for states
[ 0.038145] audio_sai2 : no governor for states
[ 0.038158] PD_SAI_3_RX : no governor for states
[ 0.038171] audio_sai3 : no governor for states
[ 0.038184] PD_SAI_4_RX : no governor for states
[ 0.038197] audio_sai4 : no governor for states
[ 0.038212] PD_SAI_5_RX : no governor for states
[ 0.038225] audio_sai5 : no governor for states
[ 0.038238] PD_SAI_6_RX : no governor for states
[ 0.038254] PD_SAI_6_TX : no governor for states
[ 0.038267] audio_sai6 : no governor for states
[ 0.038280] PD_SAI_7_TX : no governor for states
[ 0.038293] audio_sai7 : no governor for states
[ 0.038305] audio_gpt5 : no governor for states
[ 0.038318] audio_gpt6 : no governor for states
[ 0.038330] audio_gpt7 : no governor for states
[ 0.038343] audio_gpt8 : no governor for states
[ 0.038358] audio_gpt9 : no governor for states
[ 0.038371] audio_gpt10 : no governor for states
[ 0.038384] audio_amix : no governor for states
[ 0.038397] audio_mqs0 : no governor for states
[ 0.038409] audio_mclkout0 : no governor for states
[ 0.038422] audio_mclkout1 : no governor for states
[ 0.038436] PD_DSP_MU_A : no governor for states
[ 0.038449] PD_DSP_MU_A : no governor for states
[ 0.038464] PD_DSP_MU_B : no governor for states
[ 0.038477] audio_ocram : no governor for states
[ 0.038492] audio_dsp : no governor for states
[ 0.038527] dma_flexcan0 : no governor for states
[ 0.038540] dma_flexcan1 : no governor for states
[ 0.038554] dma_flexcan2 : no governor for states
[ 0.038567] dma_ftm0 : no governor for states
[ 0.038579] dma_ftm1 : no governor for states
[ 0.038591] dma_adc0 : no governor for states
[ 0.038604] dma_adc1 : no governor for states
[ 0.038616] dma_lpi2c0 : no governor for states
[ 0.038629] dma_lpi2c1 : no governor for states
[ 0.038644] dma_lpi2c2 : no governor for states
[ 0.038657] dma_lpi2c3 : no governor for states
[ 0.038670] dma_lpi2c4 : no governor for states
[ 0.038686] dma_lpuart0 : no governor for states
[ 0.038700] dma_lpuart1 : no governor for states
[ 0.038713] PD_UART1_RX : no governor for states
[ 0.038725] PD_UART1_TX : no governor for states
[ 0.038739] dma_lpuart2 : no governor for states
[ 0.038752] PD_UART2_RX : no governor for states
[ 0.038765] PD_UART2_TX : no governor for states
[ 0.038778] dma_lpuart3 : no governor for states
[ 0.038799] PD_UART3_RX : no governor for states
[ 0.038812] PD_UART3_TX : no governor for states
[ 0.038825] dma_lpuart4 : no governor for states
[ 0.038838] PD_UART4_RX : no governor for states
[ 0.038851] PD_UART4_TX : no governor for states
[ 0.038864] dma_spi0 : no governor for states
[ 0.038877] PD_LPSPI0_RX : no governor for states
[ 0.038890] PD_LPSPI0_TX : no governor for states
[ 0.038905] dma_spi1 : no governor for states
[ 0.038919] dma_spi2 : no governor for states
[ 0.038931] PD_LPSPI2_RX : no governor for states
[ 0.038947] PD_LPSPI2_TX : no governor for states
[ 0.038960] dma_spi3 : no governor for states
[ 0.038973] PD_LPSPI3_RX : no governor for states
[ 0.038985] PD_LPSPI3_TX : no governor for states
[ 0.038999] dma_emvsim0 : no governor for states
[ 0.039011] LDO1_SIM : no governor for states
[ 0.039023] dma_emvsim1 : no governor for states
[ 0.039051] PD_GPU0 : no governor for states
[ 0.039064] PD_GPU1 : no governor for states
[ 0.039078] vpu-power-domain : no governor for states
[ 0.039093] VPU_ENC_MU1 : no governor for states
[ 0.039106] VPU_ENC1 : no governor for states
[ 0.039121] VPU_ENC_MU : no governor for states
[ 0.039134] VPU_ENC : no governor for states
[ 0.039147] VPU_DEC_MU : no governor for states
[ 0.039159] VPU_DEC : no governor for states
[ 0.039173] imaging_power_domain : no governor for states
[ 0.039186] mipi_csi0_power_domain : no governor for states
[ 0.039200] mipi_csi0_i2c0 : no governor for states
[ 0.039213] mipi_csi0_pwm : no governor for states
[ 0.039226] mipi_csi1_power_domain : no governor for states
[ 0.039242] mipi_csi1_i2c0 : no governor for states
[ 0.039255] PD_MIPI_CSI1_PWM : no governor for states
[ 0.039269] hdmi_rx_power_domain : no governor for states
[ 0.039282] hdmi_rx_bypass : no governor for states
[ 0.039295] hdmi_rx_i2c : no governor for states
[ 0.039307] hdmi_rx_pwm : no governor for states
[ 0.039320] imaging_pdma1 : no governor for states
[ 0.039336] imaging_pdma2 : no governor for states
[ 0.039349] imaging_pdma3 : no governor for states
[ 0.039362] imaging_pdma4 : no governor for states
[ 0.039375] imaging_pdma5 : no governor for states
[ 0.039390] imaging_pdma6 : no governor for states
[ 0.039403] imaging_pdma7 : no governor for states
[ 0.039416] PD_JPEG_DEC_MP : no governor for states
[ 0.039429] imaging_jpeg_dec : no governor for states
[ 0.039442] PD_JPEG_ENC_MP : no governor for states
[ 0.039455] imaging_jpeg_enc : no governor for states
[ 0.039476] cm40_i2c : no governor for states
[ 0.039489] cm40_intmux : no governor for states
[ 0.039506] cm41_intmux : no governor for states
[ 0.039521] cm41_i2c : no governor for states
[ 0.039542] caam_job_ring1 : no governor for states
[ 0.039555] caam_job_ring2 : no governor for states
[ 0.039568] caam_job_ring3 : no governor for states
[ 0.039685] CPU identified as i.MX8QM, silicon rev 1.1
[ 0.041388] EFI services will not be available.
[ 0.048040] smp: Bringing up secondary CPUs ...
[ 0.076700] Detected VIPT I-cache on CPU1
[ 0.076728] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.076756] CPU1: Booted secondary processor [410fd034]
[ 0.104712] Detected VIPT I-cache on CPU2
[ 0.104726] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.104741] CPU2: Booted secondary processor [410fd034]
[ 0.132756] Detected VIPT I-cache on CPU3
[ 0.132771] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.132784] CPU3: Booted secondary processor [410fd034]
[ 0.161806] Detected PIPT I-cache on CPU4
[ 0.161824] GICv3: CPU4: found redistributor 100 region 0:0x0000000051b80000
[ 0.161839] CPU4: Booted secondary processor [410fd082]
[ 0.188845] Detected PIPT I-cache on CPU5
[ 0.188856] GICv3: CPU5: found redistributor 101 region 0:0x0000000051ba0000
[ 0.188867] CPU5: Booted secondary processor [410fd082]
[ 0.188921] smp: Brought up 1 node, 6 CPUs
[ 0.189041] SMP: Total of 6 processors activated.
[ 0.189052] CPU features: detected: GIC system register CPU interface
[ 0.189064] CPU features: detected: 32-bit EL0 Support
[ 0.190674] CPU: All CPU(s) started at EL2
[ 0.190710] alternatives: patching kernel code
[ 0.191430] devtmpfs: initialized
[ 0.204636] random: get_random_u32 called from bucket_table_alloc+0x104/0x268 with crng_init=0
[ 0.205022] Registered cp15_barrier emulation handler
[ 0.205038] Registered setend emulation handler
[ 0.205257] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.205326] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.225763] pinctrl core: initialized pinctrl subsystem
[ 0.228105] DMI not present or invalid.
[ 0.228429] NET: Registered protocol family 16
[ 0.230512] cpuidle: using governor menu
[ 0.231781] vdso: 2 pages (1 code @ ffff000008dc6000, 1 data @ ffff000009534000)
[ 0.231807] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.236771] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.237318] Serial: AMBA PL011 UART driver
[ 0.237454] imx rpmsg driver is registered.
[ 0.239945] MU and Power domains initialized
[ 0.239960] ***** imx8qm_clocks_init *****
[ 0.306435] imx8qm-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.309513] ARM CCI_400_r1 PMU driver probed
[ 0.327058] clk: couldn't set hdmi_lis_ipg_clk clk rate to 100000000 (-22), current rate: 84857142
[ 0.361572] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.369442] MU is ready for cross core communication!
[ 0.369638] imx-rpmsg 90000000.rpmsg: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.370036] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.390929] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 0.391883] MU is ready for cross core communication!
[ 0.392046] imx-rpmsg 90100000.rpmsg1: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.392432] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 0.413333] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 0.428697] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.439510] ACPI: Interpreter disabled.
[ 0.446823] VCC USBH2(ABCD) / USBH(3|4): Failed to create debugfs directory
[ 0.448234] vgaarb: loaded
[ 0.448500] SCSI subsystem initialized
[ 0.448947] usbcore: registered new interface driver usbfs
[ 0.449024] usbcore: registered new interface driver hub
[ 0.449094] usbcore: registered new device driver usb
[ 0.449721] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.450058] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[ 0.451911] i2c i2c-2: LPI2C adapter registered
[ 0.452817] i2c i2c-3: LPI2C adapter registered
[ 0.453664] i2c i2c-4: LPI2C adapter registered
[ 0.454407] i2c i2c-5: LPI2C adapter registered
[ 0.456163] media: Linux media interface: v0.10
[ 0.456203] Linux video capture interface: v2.00
[ 0.456324] pps_core: LinuxPPS API ver. 1 registered
[ 0.456336] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.456371] PTP clock support registered
[ 0.456614] EDAC MC: Ver: 3.0.0
[ 0.456909] dmi: Firmware registration failed.
[ 0.457834] Advanced Linux Sound Architecture Driver Initialized.
[ 0.458378] Bluetooth: Core ver 2.22
[ 0.458415] NET: Registered protocol family 31
[ 0.458425] Bluetooth: HCI device and connection manager initialized
[ 0.458441] Bluetooth: HCI socket layer initialized
[ 0.458453] Bluetooth: L2CAP socket layer initialized
[ 0.458478] Bluetooth: SCO socket layer initialized
[ 0.459215] clocksource: Switched to clocksource arch_sys_counter
[ 0.459355] VFS: Disk quotas dquot_6.6.0
[ 0.459407] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.459534] pnp: PnP ACPI: disabled
[ 0.464943] NET: Registered protocol family 2
[ 0.465568] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.465854] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.466266] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.466378] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.466465] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.466646] NET: Registered protocol family 1
[ 0.466909] RPC: Registered named UNIX socket transport module.
[ 0.466920] RPC: Registered udp transport module.
[ 0.466929] RPC: Registered tcp transport module.
[ 0.466938] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.468622] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.469296] kvm [1]: 8-bit VMID
[ 0.470635] kvm [1]: vgic-v2@52020000
[ 0.470673] kvm [1]: GIC system register CPU interface enabled
[ 0.470763] kvm [1]: vgic interrupt IRQ1
[ 0.470867] kvm [1]: Hyp mode initialized successfully
[ 0.473313] audit: initializing netlink subsys (disabled)
[ 0.473406] audit: type=2000 audit(0.468:1): state=initialized audit_enabled=0 res=1
[ 0.473796] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.479147] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.479686] NFS: Registering the id_resolver key type
[ 0.479718] Key type id_resolver registered
[ 0.479727] Key type id_legacy registered
[ 0.479742] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.479770] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.480267] 9p: Installing v9fs 9p2000 file system support
[ 0.484561] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.484583] io scheduler noop registered
[ 0.484686] io scheduler cfq registered (default)
[ 0.484697] io scheduler mq-deadline registered
[ 0.484707] io scheduler kyber registered
[ 0.506692] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 0.506822] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 0.509417] imx6q-pcie 5f010000.pcie: 5f010000.pcie supply epdev_on not found, using dummy regulator
[ 0.509532] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 0.511387] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.521575] Bus freq driver module loaded
[ 0.528944] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.532079] SuperH (H)SCI(F) driver initialized
[ 0.533373] msm_serial: driver initialized
[ 0.534969] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 67, base_baud = 5000000) is a FSL_LPUART
[ 0.535422] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[ 0.535438] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[ 0.536233] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 68, base_baud = 5000000) is a FSL_LPUART
[ 0.536262] Serial: Console lpuart rounded baud ratefrom 575539 to 115200
[ 2.748898] console [ttyLP1] enabled
[ 2.753561] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 69, base_baud = 5000000) is a FSL_LPUART
[ 2.764067] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 70, base_baud = 5000000) is a FSL_LPUART
[ 2.776627] arm-smmu 51400000.iommu: probing hardware configuration...
[ 2.783184] arm-smmu 51400000.iommu: SMMUv2 with:
[ 2.787897] arm-smmu 51400000.iommu: stage 1 translation
[ 2.793312] arm-smmu 51400000.iommu: stage 2 translation
[ 2.798720] arm-smmu 51400000.iommu: nested translation
[ 2.804050] arm-smmu 51400000.iommu: stream matching with 32 register groups
[ 2.811211] arm-smmu 51400000.iommu: 32 context banks (0 stage-2 only)
[ 2.817847] Can't support > 32 bit dma.
[ 2.821693] arm-smmu 51400000.iommu: failed to set DMA mask for table walker
[ 2.828755] arm-smmu 51400000.iommu: Supported page sizes: 0x61311000
[ 2.835300] arm-smmu 51400000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.841839] arm-smmu 51400000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.895683] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 2.904020] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[ 2.912077] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 2.920401] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[ 2.930731] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[ 2.938778] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[ 2.949075] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[ 2.957128] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[ 2.967441] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[ 2.975495] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[ 2.985860] imx8-dpr-channel 570d0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 2.994175] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57050000.prg
[ 3.002228] imx8-dpr-channel 570e0000.dpr-channel: Linked as a consumer to 57040000.prg
[ 3.010547] imx8-dpr-channel 570f0000.dpr-channel: Linked as a consumer to 57060000.prg
[ 3.020881] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57070000.prg
[ 3.028934] imx8-dpr-channel 57100000.dpr-channel: Linked as a consumer to 57080000.prg
[ 3.039247] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 57090000.prg
[ 3.047297] imx8-dpr-channel 57110000.dpr-channel: Linked as a consumer to 570a0000.prg
[ 3.057598] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570b0000.prg
[ 3.065652] imx8-dpr-channel 57120000.dpr-channel: Linked as a consumer to 570c0000.prg
[ 3.076974] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[ 3.084367] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[ 3.091736] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[ 3.099126] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[ 3.106486] dpu-core 56180000.dpu: Linked as a consumer to 56020000.pixel-combiner
[ 3.114745] dpu-core 56180000.dpu: driver probed
[ 3.120380] dpu-core 57180000.dpu: Linked as a consumer to 57100000.dpr-channel
[ 3.127781] dpu-core 57180000.dpu: Linked as a consumer to 57110000.dpr-channel
[ 3.135150] dpu-core 57180000.dpu: Linked as a consumer to 570f0000.dpr-channel
[ 3.142556] dpu-core 57180000.dpu: Linked as a consumer to 57120000.dpr-channel
[ 3.149901] dpu-core 57180000.dpu: Linked as a consumer to 57020000.pixel-combiner
[ 3.157942] dpu-core 57180000.dpu: driver probed
[ 3.166551] panel-simple lvds1_panel: lvds1_panel supply power not found, using dummy regulator
[ 3.181299] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.187956] [drm] No driver support for vblank timestamp query.
[ 3.193970] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[ 3.201326] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[ 3.208669] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.216834] dpu-core 57180000.dpu: Linked as a consumer to 570d0000.dpr-channel
[ 3.224190] dpu-core 57180000.dpu: Linked as a consumer to 570e0000.dpr-channel
[ 3.231533] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.5 (ops dpu_bliteng_ops)
[ 3.239908] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.247364] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.254819] imx-drm display-subsystem: bound imx-dpu-crtc.3 (ops dpu_crtc_ops)
[ 3.262261] imx-drm display-subsystem: bound imx-dpu-crtc.4 (ops dpu_crtc_ops)
[ 3.269692] i.mx8-hdp 56268000.hdmi: invalid resource
[ 3.274755] i.mx8-hdp 56268000.hdmi: Failed to get HDP RESET base register
[ 3.281667] i.mx8-hdp 56268000.hdmi: Connector's ddc i2c bus found
[ 3.288877] CDN_API_SetClock completed
[ 3.292638] [drm] Started firmware!
[ 3.296144] [drm] CDN_API_CheckAlive returned ret = 0
[ 3.301248] [drm] CDN_API_MainControl_blocking ret = 0 sts = 1
[ 3.307181] [drm] CDN_API_General_Test_Echo_Ext_blocking - APB(ret = 0 echo_resp = echo test)
[ 3.315730] [drm] CDN_API_General_getCurVersion - ver 26098 verlib 20691
[ 3.322461] [drm] phy_cfg_hdp() num_lanes: 4, mode:1920x1080p60, color depth: 8-bit, encoding: 1
[ 3.331440] [drm] Pixel clock frequency (148500 kHz) is supported in this color depth (8-bit). Settings found in row 2
[ 3.342154] [drm] Character clock frequency: 148500 kHz.
[ 3.347480] [drm] VCO frequency (2970000 kHz) is supported. Settings found in row 25
[ 3.380274] [drm] CDN_API_General_Write_Register_blocking LANES_CONFIG ret = 0
[ 3.387543] [drm] Failed to get HDCP config - using HDCP 2.2 only
[ 3.394771] [drm] hdmi-audio-codec driver bound to HDMI
[ 3.400019] imx-drm display-subsystem: bound 56268000.hdmi (ops imx_hdp_imx_ops)
[ 3.407672] imx-drm display-subsystem: bound ldb@572410e0 (ops imx_ldb_ops)
[ 3.512274] Console: switching to colour frame buffer device 160x50
[ 3.535110] imx-drm display-subsystem: fb0: frame buffer device
[ 3.541643] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 3.557392] brd: module loaded
[ 3.565257] loop: module loaded
[ 3.568828] zram: Added device: zram0
[ 3.575308] iommu: Adding device 5f020000.sata to group 0
[ 3.583170] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 3.590784] ahci-imx 5f020000.sata: external osc is used.
[ 3.599064] ahci-imx 5f020000.sata: no ahb clock.
[ 3.603873] Can't support > 32 bit dma.
[ 3.607778] ahci-imx 5f020000.sata: Enable 32-bit DMA instead of 64-bit.
[ 3.614565] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 3.623558] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sadm sds apst
[ 3.634366] scsi host0: ahci-imx
[ 3.637772] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x100 irq 147
[ 3.648512] slram: not enough parameters.
[ 3.655289] fsl_lpspi 5a000000.lpspi: dma setup error -19, use pio
[ 3.662750] fsl_lpspi 5a020000.lpspi: dma setup error -19, use pio
[ 3.672696] libphy: Fixed MDIO Bus: probed
[ 3.677364] tun: Universal TUN/TAP device driver, 1.6
[ 3.684738] CAN device driver interface
[ 3.691751] flexcan 5a8d0000.can: 5a8d0000.can supply xceiver not found, using dummy regulator
[ 3.703225] flexcan 5a8d0000.can: device registered (reg_base=ffff000011c10000, irq=60)
[ 3.714104] flexcan 5a8e0000.can: 5a8e0000.can supply xceiver not found, using dummy regulator
[ 3.725510] flexcan 5a8e0000.can: device registered (reg_base=ffff000011c40000, irq=61)
[ 3.738737] iommu: Adding device 5b040000.ethernet to group 1
[ 3.747606] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, using dummy regulator
[ 3.770039] pps pps0: new PPS source ptp0
[ 3.778108] libphy: fec_enet_mii_bus: probed
[ 3.785394] fec 5b040000.ethernet eth0: registered PHC device 0
[ 3.794769] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.802845] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.811058] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.820238] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.828066] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.838133] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.846983] sky2: driver version 1.30
[ 3.860195] Can't support > 32 bit dma.
[ 3.866227] xhci-cdns3: xHCI Host Controller
[ 3.872726] xhci-cdns3: new USB bus registered, assigned bus number 1
[ 3.905569] xhci-cdns3: hcc params 0x200073c8 hci version 0x100 quirks 0xffffffffa0010010
[ 3.916581] hub 1-0:1.0: USB hub found
[ 3.922500] hub 1-0:1.0: 1 port detected
[ 3.928778] xhci-cdns3: xHCI Host Controller
[ 3.935215] xhci-cdns3: new USB bus registered, assigned bus number 2
[ 3.943841] xhci-cdns3: Host supports USB 3.0 SuperSpeed
[ 3.951424] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.961977] hub 2-0:1.0: USB hub found
[ 3.967824] hub 2-0:1.0: 1 port detected
[ 3.974288] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.982922] ehci-pci: EHCI PCI platform driver
[ 3.989550] ehci-platform: EHCI generic platform driver
[ 3.997490] ehci-orion: EHCI orion driver
[ 4.003824] ehci-exynos: EHCI EXYNOS driver
[ 4.010318] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 4.018143] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.026439] ohci-pci: OHCI PCI platform driver
[ 4.032992] ohci-platform: OHCI generic platform driver
[ 4.040492] ohci-exynos: OHCI EXYNOS driver
[ 4.047685] usbcore: registered new interface driver usb-storage
[ 4.055746] usbcore: registered new interface driver usbserial
[ 4.063570] usbcore: registered new interface driver usbserial_generic
[ 4.072073] usbserial: USB Serial support registered for generic
[ 4.080093] usbcore: registered new interface driver cp210x
[ 4.087639] usbserial: USB Serial support registered for cp210x
[ 4.095580] usbcore: registered new interface driver ftdi_sio
[ 4.103284] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 4.112635] usbcore: registered new interface driver pl2303
[ 4.119221] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.120164] usbserial: USB Serial support registered for pl2303
[ 4.134880] ata1.00: supports DRM functions and may not be fully accessible
[ 4.134884] usbcore: registered new interface driver usb_ehset_test
[ 4.142467] ata1.00: ATA-9: Samsung SSD 850 EVO mSATA 250GB, EMT41B6Q, max UDMA/133
[ 4.142470] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 4.190842] usb3503 3-0008: switched to HUB mode
[ 4.197378] usb3503 3-0008: usb3503_probe: probed in hub mode
[ 4.207233] usbmisc_imx 5b0d0200.usbmisc: 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 4.219693] usbmisc_imx 5b0e0200.usbmisc: 5b0e0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 4.233137] imx_usb 5b0d0000.usb: 5b0d0000.usb supply vbus not found, using dummy regulator
[ 4.249994] imx_usb 5b0e0000.usb: 5b0e0000.usb supply pad not found, using dummy regulator
[ 4.263471] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 4.270280] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 3
[ 4.295234] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 4.303122] hub 3-0:1.0: USB hub found
[ 4.308836] hub 3-0:1.0: 1 port detected
[ 4.317868] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[ 4.463351] atmel_mxt_ts 4-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 4.472213] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 4.481057] atmel_mxt_ts 4-004a: Trying alternate bootloader address
[ 4.489472] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 4.498363] atmel_mxt_ts: probe of 4-004a failed with error -5
[ 4.511368] rtc-ds1307 4-0068: registered as rtc0
[ 4.519484] imx_sc_rtc rtc: rtc core: registered rtc as rtc1
[ 4.527736] i2c /dev entries driver
[ 4.536506] IR NEC protocol handler initialized
[ 4.542956] IR RC5(x/sz) protocol handler initialized
[ 4.550213] IR RC6 protocol handler initialized
[ 4.556695] IR JVC protocol handler initialized
[ 4.563098] IR Sony protocol handler initialized
[ 4.569583] IR SANYO protocol handler initialized
[ 4.576184] IR Sharp protocol handler initialized
[ 4.582711] IR MCE Keyboard/mouse protocol handler initialized
[ 4.590395] IR XMP protocol handler initialized
[ 4.604277] mxc-mipi-csi2 58247000.csi: mipi_csi2_probe
[ 4.613823] ata1.00: supports DRM functions and may not be fully accessible
[ 4.624018] ata1.00: configured for UDMA/133
[ 4.630507] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 1B6Q PQ: 0 ANSI: 5
[ 4.632415] ov5640_mipi_v3 5-003c: 5-003c supply DOVDD not found, using dummy regulator
[ 4.641244] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[ 4.650656] ov5640_mipi_v3 5-003c: 5-003c supply DVDD not found, using dummy regulator
[ 4.660059] sd 0:0:0:0: [sda] Write Protect is off
[ 4.669985] ov5640_mipi_v3 5-003c: 5-003c supply AVDD not found, using dummy regulator
[ 4.686712] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.701776] sda: sda1
[ 4.706785] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.719357] ov5640_mipi_v3 5-003c: Read reg error: reg=300a
[ 4.726951] camera ov5640 is not found
[ 4.733949] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 4.742350] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 4.750679] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 4.759007] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 4.767256] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 4.775514] mx8-img-md: Registered mxc_isi.5.capture as /dev/video5
[ 4.783701] mx8-img-md: Registered mxc_isi.6.capture as /dev/video6
[ 4.791869] mx8-img-md: Registered mxc_isi.7.capture as /dev/video7
[ 4.799966] mxc-isi 58170000.isi: register m2m device success
[ 4.807228] usb 3-1: new high-speed USB device number 2 using ci_hdrc
[ 4.807701] mxc-isi 58100000.isi: mxc_md_unregister_all unregister ISI channel[0]
[ 4.824977] mxc-isi 58110000.isi: mxc_md_unregister_all unregister ISI channel[1]
[ 4.834322] mxc-isi 58120000.isi: mxc_md_unregister_all unregister ISI channel[2]
[ 4.843612] mxc-isi 58130000.isi: mxc_md_unregister_all unregister ISI channel[3]
[ 4.852840] mxc-isi 58140000.isi: mxc_md_unregister_all unregister ISI channel[4]
[ 4.862053] mxc-isi 58150000.isi: mxc_md_unregister_all unregister ISI channel[5]
[ 4.871231] mxc-isi 58160000.isi: mxc_md_unregister_all unregister ISI channel[6]
[ 4.880395] mxc-isi 58170000.isi: mxc_md_unregister_all unregister ISI channel[7]
[ 4.890935] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,0)
[ 4.901376] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,1)
[ 4.914215] gpio-fan gpio-fan: GPIO fan initialized
[ 4.924774] imx8-wdt wdog: initialized (timeout=60 sec, nowayout=0)
[ 4.933270] Bluetooth: HCI UART driver ver 2.3
[ 4.939285] Bluetooth: HCI UART protocol H4 registered
[ 4.946004] Bluetooth: HCI UART protocol BCSP registered
[ 4.952901] Bluetooth: HCI UART protocol ATH3K registered
[ 4.959879] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 4.967822] Bluetooth: HCI UART protocol Broadcom registered
[ 4.975066] Bluetooth: HCI UART protocol QCA registered
[ 4.981822] Bluetooth: HCI UART protocol Marvell registered
[ 4.988995] usbcore: registered new interface driver btusb
[ 4.996052] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 5.003341] hub 3-1:1.0: USB hub found
[ 5.004409] sdhci: Secure Digital Host Controller Interface driver
[ 5.016297] sdhci: Copyright(c) Pierre Ossman
[ 5.016301] hub 3-1:1.0: 3 ports detected
[ 5.027960] Synopsys Designware Multimedia Card Interface Driver
[ 5.037279] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.045998] iommu: Adding device 5b010000.usdhc to group 2
[ 5.053716] mmc0: CQHCI version 5.10
[ 5.103259] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[ 5.115691] iommu: Adding device 5b020000.usdhc to group 2
[ 5.123200] mmc1: CQHCI version 5.10
[ 5.128250] sdhci-esdhc-imx 5b020000.usdhc: Got CD GPIO
[ 5.179342] mmc1: SDHCI controller on 5b020000.usdhc [5b020000.usdhc] using ADMA
[ 5.190366] iommu: Adding device 5b030000.usdhc to group 2
[ 5.199746] mmc2: CQHCI version 5.10
[ 5.203847] sdhci-esdhc-imx 5b030000.usdhc: Got CD GPIO
[ 5.214591] mmc0: Command Queue Engine enabled
[ 5.220549] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.228979] mmcblk0: mmc0:0001 HAG4a2 14.7 GiB
[ 5.235367] mmcblk0boot0: mmc0:0001 HAG4a2 partition 1 8.00 MiB
[ 5.242905] random: fast init done
[ 5.248195] mmcblk0boot1: mmc0:0001 HAG4a2 partition 2 8.00 MiB
[ 5.255827] mmc2: SDHCI controller on 5b030000.usdhc [5b030000.usdhc] using ADMA
[ 5.257991] mmcblk0: p1 p2
[ 5.273640] mmc1: host does not support reading read-only switch, assuming write-enable
[ 5.289584] mmc1: new high speed SDHC card at address 59b4
[ 5.296881] ledtrig-cpu: registered to indicate activity on CPUs
[ 5.297530] mmcblk1: mmc1:59b4 uSD 7.36 GiB
[ 5.308980] caam 31400000.caam: ERA source: device tree.
[ 5.312676] mmcblk1: p1 p2
[ 5.331381] caam algorithms registered in /proc/crypto
[ 5.341069] caam_jr 31430000.jr2: registering rng-caam
[ 5.348427] caam 31400000.caam: caam pkc algorithms registered in /proc/crypto
[ 5.359958] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.367755] usbcore: registered new interface driver usbhid
[ 5.375199] usbhid: USB HID core driver
[ 5.393682] sgtl5000 3-000a: sgtl5000 revision 0x11
[ 5.419947] ***** imx8qm_acm_init *****
[ 5.455082] imx-spdif sound-hdmi-arc: snd-soc-dummy-dai <-> 59030000.spdif mapping ok
[ 5.464970] imx-spdif sound-hdmi-arc: ASoC: no DMI vendor name!
[ 5.477182] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 59020000.spdif mapping ok
[ 5.486826] imx-spdif sound-spdif: ASoC: no DMI vendor name!
[ 5.496848] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59820000
[ 5.505865] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59830000
[ 5.515134] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59820000.sai mapping ok
[ 5.524782] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59830000.sai mapping ok
[ 5.534362] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-0 mapping ok
[ 5.543391] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-1 mapping ok
[ 5.552384] imx-amix sound-amix-sai: ASoC: no DMI vendor name!
[ 5.562344] imx-cdnhdmi sound-hdmi-tx: i2s-hifi <-> 59090000.sai mapping ok
[ 5.571256] imx-cdnhdmi sound-hdmi-tx: ASoC: no DMI vendor name!
[ 5.580221] NET: Registered protocol family 26
[ 5.587001] NET: Registered protocol family 10
[ 5.593906] Segment Routing with IPv6
[ 5.599427] NET: Registered protocol family 17
[ 5.605689] can: controller area network core (rev 20170425 abi 9)
[ 5.613762] NET: Registered protocol family 29
[ 5.620030] can: raw protocol (rev 20170425)
[ 5.626103] can: broadcast manager protocol (rev 20170425 t)
[ 5.633559] can: netlink gateway (rev 20170425) max_hops=1
[ 5.641011] Bluetooth: RFCOMM TTY layer initialized
[ 5.647684] Bluetooth: RFCOMM socket layer initialized
[ 5.654605] Bluetooth: RFCOMM ver 1.11
[ 5.660116] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.667176] Bluetooth: BNEP filters: protocol multicast
[ 5.674151] Bluetooth: BNEP socket layer initialized
[ 5.680831] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.688454] Bluetooth: HIDP socket layer initialized
[ 5.695143] lib80211: common routines for IEEE802.11 drivers
[ 5.702486] 9pnet: Installing 9P2000 support
[ 5.708451] Key type dns_resolver registered
[ 5.714850] registered taskstats version 1
[ 5.739936] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[ 5.750098] imx8_cpufreq_init: cluster 1 running at freq 1596 MHz, suspend freq 1596 MHz
[ 5.761427] imx6q-pcie 5f000000.pcie: 5f000000.pcie supply epdev_on not found, using dummy regulator
[ 5.772530] OF: PCI: host bridge /pcie@0x5f000000 ranges:
[ 5.779633] OF: PCI: IO 0x6ff80000..0x6ff8ffff -> 0x00000000
[ 5.787223] OF: PCI: MEM 0x60000000..0x6fefffff -> 0x60000000
[ 5.905562] imx6q-pcie 5f000000.pcie: pcie phy pll is locked.
[ 6.242639] imx6q-pcie 5f000000.pcie: phy link never came up
[ 6.251534] imx6q-pcie 5f000000.pcie: failed to initialize host
[ 6.260679] imx6q-pcie 5f000000.pcie: unable to add pcie port.
[ 6.270084] imx6q-pcie: probe of 5f000000.pcie failed with error -110
[ 6.281183] imx6q-pcie 5f010000.pcie: 5f010000.pcie supply epdev_on not found, using dummy regulator
[ 6.292343] OF: PCI: host bridge /pcie@0x5f010000 ranges:
[ 6.299515] OF: PCI: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 6.307234] OF: PCI: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 6.317887] imx6q-pcie 5f010000.pcie: pcie phy pll is locked.
[ 6.458356] imx6q-pcie 5f010000.pcie: Link: Gen2 disabled
[ 6.465485] imx6q-pcie 5f010000.pcie: Link up, Gen1
[ 6.473113] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[ 6.481279] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 6.488566] pci_bus 0000:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff])
[ 6.499376] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fefffff]
[ 6.519351] pci 0000:00:00.0: BAR 0: assigned [mem 0x70000000-0x70ffffff 64bit]
[ 6.528370] pci 0000:00:00.0: BAR 6: assigned [mem 0x71000000-0x71ffffff pref]
[ 6.537249] pci 0000:00:00.0: BAR 15: assigned [mem 0x72000000-0x721fffff 64bit pref]
[ 6.546785] pci 0000:01:00.0: BAR 0: assigned [mem 0x72000000-0x720fffff 64bit pref]
[ 6.556275] pci 0000:01:00.0: BAR 2: assigned [mem 0x72100000-0x721fffff 64bit pref]
[ 6.565753] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 6.572634] pci 0000:00:00.0: bridge window [mem 0x72000000-0x721fffff 64bit pref]
[ 6.582907] pcieport 0000:00:00.0: Signaling PME with IRQ 507
[ 6.592849] input: colibri-vf50-ts as /devices/platform/vf50-touchscreen/input/input1
[ 6.612996] asoc-simple-card sound: sgtl5000 <-> 59050000.sai mapping ok
[ 6.621468] asoc-simple-card sound: ASoC: no DMI vendor name!
[ 6.633528] rtc-ds1307 4-0068: setting system clock to 2020-01-08 04:56:16 UTC (1578459376)
[ 6.647383] ALSA device list:
[ 6.652286] #0: imx-hdmi-arc
[ 6.657449] #1: imx-spdif
[ 6.661986] #2: amix-audio-sai
[ 6.666954] #3: imx-audio-hdmi-tx
[ 6.672178] #4: apalis-imx8qm-sgtl5000
[ 6.686303] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 6.695590] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 6.706811] EXT4-fs (mmcblk0p2): recovery complete
[ 6.744537] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.756486] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 6.766599] devtmpfs: mounted
[ 6.771940] Freeing unused kernel memory: 1280K
[ 6.846718] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 6.872854] systemd[1]: Detected architecture arm64.
Welcome to TDX Wayland with XWayland 2.6-snapshot-20191231 (thud)!
[ 6.899656] systemd[1]: Set hostname to <apalis-imx8>.
[ 7.071900] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.080958] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.103444] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.114375] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 7.135492] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.146708] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 7.171713] systemd[1]: Starting File System Check on Root Device...
[ 7.196753] systemd[1]: Created slice system-serial\x2dgetty.slice.
s OK ] Created slice system-serial[\ x 2 d 7ge.t20ty9.39sl2i] ces.y
temd[1]: Starting Load Kernel Modules...
1 Starting [L o a d 7K.e2r1n9e9l9 9M]o dsuylsetse.m.d[.
]: Created slice User and Session Slice.
o OK ] Created[ s l i c7e .U2s3e2r 1an5d1 ]S egasslicono rSle:ice .l
ading out-of-tree module taints kernel.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 7.252148] Galcore version 6.2.4.190076
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
Mounting Kernel Debug File System...
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on udev Control Socket.
Mounting Huge Pages File System...
Starting Create list of required st…ce nodes for the current kernel...
5 OK ] Started Hardware RNG Entropy Gatherer[ D a e m7o.n3.7
920] random: crng init done
[ 7.382874] random: 7 urandom warning(s) missed due to ratelimiting
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on Network Service Netlink Socket.
Mounting Temporary Directory (/tmp)...
Starting udev Coldplug all Devices...
Mounting POSIX Message Queue File System...
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Reached target Slices.
[ OK ] Reached target Remote File Systems.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Load Kernel Modules.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Journal Service.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Mounted POSIX Message Queue File System.
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Remount Root and Kernel File Systems...
[ 7.825713] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting Create Static Device Nodes in /dev...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Containers.
Mounting /var/volatile...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Mounted /var/volatile.
[ 8.076358] systemd-journald[2451]: Received request to flush runtime journal from PID 1
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Load/Save Random Seed.
[ 8.153042] [VPU Encoder] enable mu for core[0]
Starting Create Volatile Files and Directories...
[ 8.167376] [VPU Encoder] vpu encoder core[0] firmware version is 1.2.2
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Found device /dev/ttyLP1.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ 8.288356] mwifiex_pcie 0000:01:00.0: enabling device (0000 -> 0002)
[ 8.298026] mwifiex_pcie: try set_consistent_dma_mask(32)
[ 8.307946] mwifiex_pcie: PCI memory map Virt0: ffff00002cb00000 PCI memory map Virt2: ffff00002cd00000
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started Network Time Synchronization.
[ 8.749346] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.804124] EXT4-fs (mmcblk1p2): recovery complete
[ 8.804564] EXT4-fs (sda1): recovery complete
[ 8.811223] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.828358] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.846646] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.947416] switch cluster 0 cpu-freq governor to schedutil
[ 8.987488] switch cluster 1 cpu-freq governor to schedutil
[ OK ] Reached target System Time Synchronized.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started start resize script to incr…ootfs to its partitions full size.
Starting Load default USB gadget schema g1.schema...
[ 9.283779] using random self ethernet address
[ 9.291297] using random host ethernet address
Starting Login Service...
[ OK ] Started Timestamping service.
[ OK ] Started System Logging Service.
Starting Save/Restore Sound Card State...
[ 9.380858] mwifiex_pcie 0000:01:00.0: info: FW download over, size 634228 bytes
Starting Bluetooth service...
Starting Telephony service...
Starting RPC Bind Service...
[ OK ] Started Kernel Logging Service.
[ OK ] Started D-Bus System Message Bus.
Starting Connection service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started RPC Bind Service.
[ OK ] Reached target Sound Card.
Starting WPA supplicant...
Starting Hostname Service...
[ OK ] Started WPA supplicant.
[ OK ] Started Bluetooth service.
[ OK ] Started Connection service.
[ 9.651954] Micrel KSZ9031 Gigabit PHY 5b040000.ethernet-1:07: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=5b040000.ethernet-1:07, irq=POLL)
[ 9.672836] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
u [OK ] S ta9r.te6d8 Lo1gi9n Se6rv2i]ce .
sb0: HOST MAC 00:14:2d:ff:ff:fe
[32m OK 90m.]6 S9t2a0r4te7d ]Telep honuys bs0e:r viMceA.C
00:14:2d:ff:ff:ff
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Load default USB gadget schema g1.schema.
Starting Network Service...
[ OK ] Started Bluetooth Audio ALSA Backend.
[ OK ] Started Network [S ervi c e .9
.876131] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ OK ] Reached target Network.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ OK ] Started Permit User Sessions.
[ OK ] Started Hostname Service.
[ OK ] Started Serial Getty on ttyLP1.
[ OK ] Started Serial Getty on ttyS0.
Starting Weston Wayland Compositor (on tty7)...
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started Weston Wayland Compositor (on tty7).
Starting Start a wayland application...
[ 10.155257] mwifiex_pcie 0000:01:00.0: WLAN FW is active
[ OK ] Created slice system-user\x2druntime\x2ddir.slice.
[ OK ] Started /run/user/0 mount wrapper.
[ 10.208349] mwifiex_pcie 0000:01:00.0: Unknown api_id: 3
[ 10.213839] mwifiex_pcie 0000:01:00.0: Unknown api_id: 4
[ 10.219367] mwifiex_pcie 0000:01:00.0: Unknown GET_HW_SPEC TLV type: 0x217
[ OK ] Created slice User Slice of UID 0.
Starting User Manager for UID 0...
[ 10.250801] audit: type=1006 audit(1578459380.112:2): pid=4403 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 10.263823] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p195)
[ 10.265182] mwifiex_pcie 0000:01:00.0 wlp1s0: renamed from mlan0
[ 10.272066] mwifiex_pcie 0000:01:00.0: driver_version = mwifiex 1.0 (16.68.1.p195)
[ OK ] Started Session c1 of user root.
[ 10.399250] usb 3-1.1: new high-speed USB device number 3 using ci_hdrc
[ OK ] Started User Manager for UID 0.
[ 10.521675] usb 3-1.1: config 1 interface 1 altsetting 0 endpoint 0x85 has wMaxPacketSize 0, skipping
[ 10.531763] usb 3-1.1: config 1 interface 1 altsetting 0 endpoint 0x5 has wMaxPacketSize 0, skipping
[ OK ] Reached target Bluetooth.
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
Any help is greatly appreciated.
