I just picked up an Apalis iMX8 Quad ax and Ixora Carrier board. I have plugged it into a HDMI desktop monitor ad booted it into the Toradex Easy Installer. I selected the Torizon Image with evaluation containers. The system finished the process, and I clicked “Power Off”. Upon powering the system up, there is no HDMI signal, and its not pingable on the network. Both red and green colors on LED4 and LED5 stay on.. which I thought one of the colors turned off during the Easy Loader… I don’t know what the colors represent yet, so that might be nothing important.
I plugged in the serial console, and I see Uboot Messages, but no kernel boot messages, and no errors.
Any tips would be appreciated. I don’t recall the version number of Torizon it said it would load, but I thought the date stamp was something recent.
Thanks,
-Chris
U-Boot 2020.04-5.1.0-devel+git.5ac61784dd4c (Jan 01 1970 - 00:00:00 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06738478
BuildInfo:
- SCFW 732e719a, SECO-FW 376e3c15, IMX-MKIMAGE 6745ccdc, ATF
- U-Boot 2020.04-5.1.0-devel+git.5ac61784dd4c
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
MMC: no card present
Scanning mmc 0:1...
Found U-Boot script /boot.scr
618 bytes read in 14 ms (43 KiB/s)
## Executing script at 83100000
4179 bytes read in 23 ms (176.8 KiB/s)
162739 bytes read in 33 ms (4.7 MiB/s)
11773144 bytes read in 287 ms (39.1 MiB/s)
Uncompressed size: 29581824 = 0x1C36200
9169034 bytes read in 235 ms (37.2 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 0000000083000000, end 000000008302abb2
Starting kernel ...
