Hi Team,
Problem statement : Rpi camera rev 1.3 is not communicating over MIPI-CSI2 interface.
May I know how can I achieve this?
Meanwhile I tried following thing mentioned in the Toradex documentations;
- Using Apalis imx6q 2GB IT + Ixora carrier board + BSP5 and wanted to interface the Pi-camera over its MIPI-CSI2 interface, so I am using a pitch converter in between.
- Added the OV5647 driver.
- Set the i2c3 status for camera as : okay in imx6qdl-apalis.dtsi
- After flashing on board and by using i2c-tools I could see the hex address for cam : 0x50 to be busy (UU) on i2c3 and is not accessible.
- Attached are the camera specific i2c3 pin details.
So, could you help us with this?
Thank you.
Apurva
