Hello Jaski,
Here we are.
I used a USB stick to boot on the linux BSP release 2.8b4, just after some minor changes into the live U-boot env vars to deal with ‘zImage’ format of the new kernel (our current BSP 2.7.2 is still using ‘uImage’).
We first decided not to rewrite the internal emmc with the BSP 2.8b4, as we were scared to loose all the precious forensics data …
I let the system boot until the console prompt and check first that it was really the new BSP
.---O---.
| | .-. o o
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution apalis-imx6 ttymxc0
Angstrom v2017.12 - Kernel
Apalis-iMX6_LXDE-Image 2.8b4.129 20181005
apalis-imx6 login: [ 87.196066] mmcblk0: error -110 transferring data, sector 3417648, nr 192, cmd response 0x900, card status 0x200b00
[ 92.630255] mmcblk0: error -110 transferring data, sector 3417648, nr 192, cmd response 0x900, card status 0x0
[ 92.632762] INFO: task jbd2/mmcblk0p2-:678 blocked for more than 10 seconds.
[ 92.632777] Tainted: G O 4.9.87-2.8.4+g3bb6e3284a1b #1
[ 92.632782] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 92.633364] INFO: task mount:961 blocked for more than 10 seconds.
[ 92.633373] Tainted: G O 4.9.87-2.8.4+g3bb6e3284a1b #1
[ 92.633377] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 92.682974] blk_update_request: I/O error, dev mmcblk0, sector 3417648
[ 98.112685] mmcblk0: error -110 transferring data, sector 3417649, nr 191, cmd response 0x900, card status 0x0
[ 98.122813] blk_update_request: I/O error, dev mmcblk0, sector 3417649
[ 102.872766] INFO: task jbd2/mmcblk0p2-:678 blocked for more than 10 seconds.
[ 102.879847] Tainted: G O 4.9.87-2.8.4+g3bb6e3284a1b #1
[ 102.886710] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 102.895276] INFO: task mount:961 blocked for more than 10 seconds.
[ 102.901479] Tainted: G O 4.9.87-2.8.4+g3bb6e3284a1b #1
[ 102.908330] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 103.552561] mmcblk0: error -110 transferring data, sector 3417650, nr 190, cmd response 0x900, card status 0x0
[ 103.562662] blk_update_request: I/O error, dev mmcblk0, sector 3417650
[ 108.992408] mmcblk0: error -110 transferring data, sector 3417651, nr 189, cmd response 0x900, card status 0x0
[ 109.002522] blk_update_request: I/O error, dev mmcblk0, sector 3417651
[ 114.432324] mmcblk0: error -110 transferring data, sector 3417652, nr 188, cmd response 0x900, card status 0x0
[ 114.442430] blk_update_request: I/O error, dev mmcblk0, sector 3417652
.---O---.
| | .-. o o
apalis-imx6 login: root
[ 119.872214] mmcblk0: error -110 transferring data, sector 3417653, nr 187, cmd response 0x900, card status 0x0
[ 119.882316] blk_update_request: I/O error, dev mmcblk0, sector 3417653
root@apalis-imx6:~# uname -a
Linux apalis-imx6 4.9.87-2.8.4+g3bb6e3284a1b #1 SMP Fri Oct 5 16:02:39 UTC 2018 armv7l GNU/Linux
As you see now, I get identical error messages :
[ 34.097366] blk_update_request: I/O error, dev mmcblk0, sector 3417649
[ 39.527145] mmcblk0: error -110 transferring data, sector 3417650, nr 190, cmd response 0x900, card status 0x0
I give you the complete log of the boot process (my commands under Uboot, then the Angstrom boot) and the ‘dmesg’ output you have requested.
link text
Fred
