I have an IMX6 board with an LVDS display attached (split-mode).
I configured the mxcfb in this way:
mxcfb1: fb@0 {
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
interface_pix_fmt = "RGB24";
mode_str ="LVDS-WUXGA";
default_bpp = <32>;
int_clk = <0>;
late_init = <0>;
status = "disabled";
And the timing in this way:
lvds-channel@0 {
reg = <0>;
fsl,data-mapping = "spwg"; /* "jeida"; */
fsl,data-width = <24>;
crtc = "ipu2-di1";
primary;
display-timings {
timing_wuxga: LVDS-WUXGA {
clock-frequency = <149992500>;
hactive = <1920>;
hback-porch = <20>;
hfront-porch = <100>;
hsync-len = <18>;
hsync-active = <0>;
vactive = <1200>;
vback-porch = <4>;
vfront-porch = <6>;
vsync-len = <2>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <0>;
Now, if I start the kernel with parameter in uboot like:
video=mxcfb0:dev=ldb,1920x1200M@60,if=RGB24,bpp=32 ..
The image start with an high clock (like ~190MHz), this because it use the VESA CVT formula.
It obviously is out of clock, with bad timing etc…, but with the fbset command:
/usr/sbin/fbset -g 1920 1200 1920 1200 32 -vsync 0 -t 6667 20 100 4 6 18 2
I get a perfect image.
Point: until the device is not started, and the fbset executed I get a bad image, but after executing this command everything is configured correctly.
If i remove the uboot param:
The default parameter is taken from device tree, I get the correct fbset configuration:
mode "1920x1200-60"
# D: 149.993 MHz, H: 72.883 kHz, V: 60.134 Hz
geometry 1920 1200 1920 2400 32
timings 6667 20 100 4 6 18 2
rgba 8/16,8/8,8/0,8/24
endmode
But the image is not good (see attached image).
Executing fbset command in this case doesn’t change anything, the image is bad.
I think that is a clock problem or something like this, the timing correct.
Question: What the VESA CVT formula change other than timing and resolution? How I can set it in devicetree or in uboot? There is some clock change that I can made?
