I’m Working on a Virtual Machine with Ubuntu 18.04.2 mounted, the host OS is Windows 10.
I’m following the Getting started guide to setup Eclipse on my Ubuntu VM and I get an error after preparing all the settings and I have to debug.
The steps I have followed to reach this state are the following:
- Change Dash to Bash following this
- Configured the toolchain 2.7 and enviromental variables
- Instaled Java 1.8.0_201
- Installed The latest version of Eclipse Neon 3 c++/c for linux 64
- Configured all the settings for building and debugging found on the guide
After all the preparations, when the program is ready to be debugged I get a problem that appears the first time, as discussed in other queries, the program should be working fine afterwards but instead the process of debugging gets stuck at either 96% or 97% and after a while it responds this error message:
Error in final launch sequence
Failed to execute MI command:
-target-select remote 172.25.160.11:2345
Error message from debugger back end:
172.25.160.11:2345: Connection timed out.
And this is the console text:
gdbserver :2345 /home/root/hello-world-debug;exit
Last login: Tue Apr 9 14:32:05 2019 from 172.25.120.25
root@apalis-imx6:~# gdbserver :2345 /home/root/hello-world-debug;exit
Process /home/root/hello-world-debug created; pid = 955
Listening on port 2345
172.25.160.11 is the IP of Apalis iMX6 ethernet connection and 2345 is the number of the port that was chosen by default.
I have reproduced this error on another computer using an Ubuntu 18.04 build as a host and conected to the same network.
Also, the project that I try to debug gets loaded to the Apalis as Eclipse is trying to debug, and afterwards I can run it succsessfully.
Any idea of what could be causing this?
