Hi all,
I tried to install a custom linux image on an Apalis iMX6q via “Toradex Easy Installer”.
The installation didn’t return any error, but after the required power off it is impossible to communicate with the module.
Neither the serial port nor the Ethernet give me a message.
I tried to connect via USB on port X29 but on my host PC I can see only an USB <> Serial adapter:
[107814.436748] usb 2-2.2: new full-speed USB device number 8 using uhci_hcd
[107814.685209] usb 2-2.2: New USB device found, idVendor=0403, idProduct=6001
[107814.685220] usb 2-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[107814.685223] usb 2-2.2: Product: FT232R USB UART
[107814.685226] usb 2-2.2: Manufacturer: FTDI
[107814.685228] usb 2-2.2: SerialNumber: AI03HOKJ
[107814.696678] ftdi_sio 2-2.2:1.0: FTDI USB Serial Device converter detected
[107814.696734] usb 2-2.2: Detected FT232RL
[107814.705132] usb 2-2.2: FTDI USB Serial Device converter now attached to ttyUSB0
Actually I don’t know how to reset the module.
Thanks in advance,
Regards.
Massimo
