Apalis imx6 backlight brightness is not changing
Hello Foks, I am trying to control display brightness by doing below changes in DTSI and back-light pwm driver with my Kernel version 4.9.87, but now only i can do on/off display through sys interface.
#echo 0 > /sys/class/backlight/backlight/brightness
//display OFF
# cat /sys/class/backlight/backlight/brightness
0
# echo 1 > /sys/class/backlight/backlight/brightness
//display ON
1  # echo 2 >
//brightness is not changing
2 # echo 3 >
3
My dtsi changes are..
&backlight {
        compatible = "pwm-backlight";
#if 0 /* PWM polarity: if 1 is brightest */
#if 0 /* Fusion 7 needs 10kHz PWM frequency */
        pwms = <&pwm4 0 100000>;
#endif
        brightness-levels = <0 4 8 16 32 64 128 255>;
        default-brightness-level = <6>;
#else /* PWM plarity: if 0 is brightest */
        brightness-levels = <0 127 191 223 239 247 251 255>;
        default-brightness-level = <1>;
#endif
        enable-gpios = <&gpio1 6 0>;
        lcd-pwr-en-gpio = <&gpio1 9 0>;
device tree configurations.
&backlight {
#endif
#endif
Hi @babushilesh
Greetings from Toradex community.
Could you please provide me which display are you using and the carrier board?
also please conform which dtsi file you have changed.
Please provide us the dmesg log.
