I am testing Apalis i.MX8QM with 4K 60fps video on Weston with GStreamer but it cannot reach 60fps.
My environment is:
Video test: videotestsrc_4k60_h265.mp4
This video is created by command (on another machine):
gst-launch-1.0 videotestsrc num-buffers=600 \
! video/x-raw,width=3840,height=2160,framerate=60/1,format=NV12 \
! vaapih265enc ! h265parse ! qtmux \
! filesink location=videotestsrc_4k60_h265.mp4
Test command:
gst-launch-1.0 -v filesrc location=videotestsrc_4k60_h265.mp4 \
! qtdemux ! h265parse ! v4l2h265dec \
! queue \
! fpsdisplaysink video-sink=waylandsink text-overlay=false
Result is video is played in just 30 FPS.
I also tried scaling video with imxvideoconvert_g2d, and FPS is also under 30.
! imxvideoconvert_g2d ! video/x-raw,width=1920,height=1080 \
! queue \
My questions are:
- Does Apalis i.MX8QM support 4k 60fps video.
- If so, in what cases 4k 60fps can be achieved, like which configuration needs to be changed or need some kind of special video format, or something else.
- In case video is scaled, can 60 fps be achieved.
Thank you very much,
Trung
Hi @dothanhtrung , sorry for the late reply. According to NXP should be possible.
Where do you have the video saved? Could it be a read bottleneck? Can you try and save the video in the RAM (/tmp) and see if that improves the performance? Thanks
Alvaro.
Sorry. I saved video in a micro sdcard. That might affect the FPS.
Thank you for your suggestion. I have tried saving the video in /tmp. Although it doesn’t improved the fps of video play with gst-launch-1.0, it really increases performance in my another use case, which plays video with GStreamer API in a Qt window.
I can see in weston-debug that:
- when play video with
gst-launch-1.0, video window , which is created by waylandsink, is not in correct size: 3783x2128 instead of 3840x2160.View 1 (role wl_subsurface, PID 1593, surface ID 16, sub-surface, ...):
position: (28, 32) -> (3811, 2160) <===== view size 3783x2128
[fully opaque]
outputs: 0 (HDMI-A-1) (primary)
dmabuf buffer
format: 0x3231564e NV12
modifier: 0xf000000000000001
- when play video with gstreamer and Qt, window is created by Qt, video is displayed in correct size: 3840x2160.
Thank you very much for your help. Now I can play the test video above in 60 FPS with 2 conditions:
- Video file is stored in ram, or internal flash memory (mmcblk0).
- Video window is prepared by Qt, not by
waylandsink, and GStreamer displays video in that Qt window.
Thanks for the confirmation!
Very interesting. I would understand that the Qt framework adds some overhead when is the other way around and it un-intentionally helps and while waylandsink is suboptimal. Any scaling will definitely affect performance.
Can you share some sample code of the Qt application you used to reproduce this? I think it would be quite helpful for other users
Thanks,
Alvaro.
Ah yes. Not exactly same as my application but I have submitted a similar example for using waylandsink with Qt at:
Thanks @dothanhtrung ! Did the Qt approach solve your question?
Yes. Thank you. I would like to mark this topic as solved.
