Apalis heatsink fan disclaimer
There should be a disclaimer on the Apalis Heatsink Fan page (Apalis Heatsink Fan) that it will burn if your Ixora carrier board is powered using other that 12v…
Hello @Romain.Donze ,
We are sorry for the inconvenience. However there is a disclaimer in the Ixora data sheet ( section 3.2.1, Power Supply conectors) that says:
The connectors X2 and X3 are directly connected to the power output connector X4, to the FAN connector X6 and to the LVDS connector X19. For this reason, when the 12V voltage supply is required on these connectors, the input voltage must be 12V +/-10%.
Nevertheless I have submitted your request to the documentation team.
Josep
