Hi community!
I have a video stream setup with Colibri IMX6 and Apalis IMX6.
Colibri subscribes the video;
gst-launch-1.0 *
** imxv4l2videosrc device=/dev/video0 ! *
** imxipuvideotransform ! **
** imxvpuenc_h264 bitrate=2000 ! **
** rtph264pay ! **
** udpsink host=192.168.200.100 port=5004**
and publishing to data packages at UDP.
Apalis subscribes the video packages from UDP
gst-launch-1.0 -v *
** udpsrc port=5004 ! *
** “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96, framerate=30/1” ! **
** rtph264depay ! **
** h264parse ! **
** imxvpudec ! **
** imxg2dvideosink window-width=800 window-height=600 framebuffer=/dev/fb0**
and streaming it from framebuffer output “HDMI”.
At the Apalis side framebuffer output resolution was always 1920x1080@60.
Video source streamed 640x480 but Apalis upscaled that video to 1920x1080@60.
When i tried the “fbset” commands;
“fbset -xres xx -yres xx -geometry xx xx xx xx -timings xx xx xx”
the framebuffer’s output’s video wasn’t stable.
After that tried to change the resolution at U-Boot terminal
"setenv vidargs ‘video=mxcfb1:dev=hdmi,1024x768M@60,if=RGB24’ "
“saveenv”
(resource is “Display Output, Resolution and Timings (Linux) | Toradex Developer Center”)
It worked but the resolutions weren’t customizable, you can use only the supplied resolutions and timings. I tried the read EDID datas and changed them (about 640x480 or 1280x720) but 1920x1080@60 never changed automatically. Is there anyway to use customizable resolutions?
