how did you run your application? From QT creator. Try to run it from command line!
To find where your QtCreator is installed and the script try:
$ sudo updatedb
$ sudo locate qtcreator.sh
/opt/Qt/Tools/QtCreator/bin/qtcreator.sh
Use permissions super-user to edit qtcreator.sh after execute with:
/opt/Qt/Tools/QtCreator/bin/qtcreator.sh &
I try to deploy and run from QT, I cannot run from command line in target because I think the application is not being deployed there.
When I develop simple hello world console application and deply to target I can see the application in target through target file manager and I can run.
But in this case I think, even the deployment is not being done., I cannot see the appliation in file manager of target
Thank you
I think, your build was not successful. Can you do clean build and send the log in a file?
Here is the build log
link text
The build was successful. Can you copy your application to target and check if it runs.
I tried the deploy all method.
Copy to target means How? Through minicom terminal?
can you please give the steps? Which method I should use ?
You can copy using scp command or just copy the the application to sd card and then run on target.
