Angstrom qt5 x11 image Fail
I am trying to build QT5 Image for T20 Colibri Board
Specs-
Ubuntu 16.04 x64
Running on VM
Colibri T20 Hardware
Error at 95% Build Process
    ERROR: qt3d-5.9.7+gitAUTOINC+de5e7839d6-r0 do_compile: oe_runmake failed
    ERROR: qt3d-5.9.7+gitAUTOINC+de5e7839d6-r0 do_compile: Function failed: do_compile (log file is located at /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/temp/log.do_compile.55349)
    ERROR: Logfile of failure stored in: /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/temp/log.do_compile.55349
Failed at QT3D and QTWEBKITS
HI @t20
Could you provide the version of the hardware and software of your module?
Which Linux branch are you compiling?
Please share any changes you have done local.conf and bblayers.conf?
Ubuntu 16.04 x64 Running on VM Colibri T20 Hardware
How did you install Ubuntu 16.04 on Colibri T20?
I am trying to build Angstrom QT5 x11 image on T20
| compiling .moc/moc_rendercaptureprovider.cpp
| compiling /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/paintedtexture-cpp/scene.cpp
| linking assimp-cpp
| make[3]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/assimp-cpp'
| cd rendercapture-cpp/ && ( test -e Makefile || /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/recipe-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/rendercapture-cpp/rendercapture-cpp.pro ) && make -f Makefile
| make[3]: Entering directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercapture-cpp'
| compiling /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/rendercapture-cpp/main.cpp
| linking animation-keyframe-programmatic
| make[3]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/animation-keyframe-programmatic'
| compiling /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/rendercapture-cpp/orbittransformcontroller.cpp
| linking rendercapture-qml-fbo
| make[3]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercapture-qml-fbo'
| generating .moc/moc_predefs.h
| moc /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/rendercapture-cpp/orbittransformcontroller.h
| moc /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/rendercapture-cpp/mycapture.h
| compiling .moc/moc_orbittransformcontroller.cpp
| moc /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/git/tests/manual/paintedtexture-cpp/scene.h
| compiling .moc/moc_scene.cpp
| compiling .moc/moc_mycapture.cpp
| linking paintedtexture-cpp
| linking rendercapture-cpp
| make[3]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/paintedtexture-cpp'
| make[3]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercapture-cpp'
| make[2]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests/manual'
| make[1]: Leaving directory '/home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/build/tests'
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/gaap/oe-core/build/tmp-glibc/work/armv7at2hf-vfp-angstrom-linux-gnueabi/qt3d/5.9.7+gitAUTOINC+de5e7839d6-r0/temp/log.do_compile.72865)
ERROR: Task (/home/gaap/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qt3d_git.bb:do_compile) failed with exit code Currently  2 running tasks (9502 of 9587)  99% |###############Currently  1 running tasks (9516 of 9587)  99% |############################## |
# BB_GENERATE_MIRROR_TARBALLS = "0"
PREFERRED_PROVIDER_psplash-support = "psplash-angstrom"
# This file does not need to exist, if it does it can be used to influence mach$
# configurations without copying the machine file.
include conf/machine/include/${MACHINE}.inc
IMAGE_INSTALL_append = " qtquickcontrols"
Except this last qtquick everything is stock
I am using 2.8 Version
Hi @t20
Can you please provide us the exact steps you did to get where you are?
Also can you just compile the qt5 x11 image without any modification?
Does it work in this case?
Please start with the build from scratch to make sure there is no leftover from a previous run.
Stefan
I have re run the whole setup from scratch and still getting the same error on qt3d compile error and qtwebkit error So now I used the Following to opt that out so I can get the SDK and Image up and running but I Do have another problem now.QTQuick isnt present in the Build .I have added the Following to the [Local.conf] 1
Rebuild the following with stock procedure given on Dev page
ERROR: Task (/home/gaap/oe-core/build/../layers/meta-qt5/recipes-qt/qt5/qtwebkit_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 9679 tasks of which 7633 didn't need to be rerun and 2 failed.
NOTE: Writing buildhistory
Summary: 2 tasks failed:
Summary: There were 296 WARNING messages shown.
Summary: There were 4 ERROR messages shown, returning a non-zero exit code.
HI @t20
Thanks for the information.
Do you need qt3d and qtwebkit?
If not, then you can remove them in local.conf as described here.
