Seems like the same issue in the “updated” build. However this time, none of the images have a kernel that will run.
Everything appears normal… Just stops running.
start to finish in u-boot::
Apalis iMX6 #
U-Boot 2015.04+fslc+g46aa70c (Aug 22 2017 - 03:34:56)
CPU: Freescale i.MX6Q rev1.5 at 792 MHz
CPU: Temperature 43 C
Reset cause: POR
I2C: ready
DRAM: 2 GiB
force_idle_bus: sda=0 scl=1 sda.gp=0x9a scl.gp=0x9b
force_idle_bus: failed to clear bus, sda=0 scl=1
PMIC: device id: 0x10, revision id: 0x11
PMIC: programmed
auto-detected panel HDMI
Display: HDMI (1024x768)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1A, Serial# 04875670
Net: using PHY at 7
FEC [PRIME]
Normal Boot
Apalis iMX6 # run setupdate
MMC: no card present
** Bad device mmc 1 **
reading flash_blk.img
710 bytes read in 14 ms (48.8 KiB/s)
## Executing script at 12000000
reading apalis_imx6/flash_blk.img
3978 bytes read in 20 ms (193.4 KiB/s)
enter "run update" or "run update_it" to update the entire module
Apalis iMX6 # run update_it
reading apalis_imx6/u-boot.imx-it
322560 bytes read in 37 ms (8.3 MiB/s)
switch to partitions #1, OK
mmc0(part 1) is current device
MMC write: dev # 0, block # 2, count 630 ... 630 blocks written: OK
Fuse 0, 5: 5072
Fast boot mode already fused, no need to fuse
reading apalis_imx6/mbr.bin
512 bytes read in 17 ms (29.3 KiB/s)
switch to partitions #0, OK
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
reading apalis_imx6/boot.vfat
16777216 bytes read in 784 ms (20.4 MiB/s)
MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK
reading apalis_imx6/uImage
4945368 bytes read in 249 ms (18.9 MiB/s)
writing uImage
4945368 bytes written
reading apalis_imx6/imx6q-apalis-eval.dtb
48453 bytes read in 29 ms (1.6 MiB/s)
writing imx6q-apalis-eval.dtb
48453 bytes written
reading apalis_imx6/root.ext3
67108864 bytes read in 3080 ms (20.8 MiB/s)
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3091 ms (20.7 MiB/s)
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3098 ms (20.7 MiB/s)
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3108 ms (20.6 MiB/s)
MMC write: dev # 0, block # 434176, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3119 ms (20.5 MiB/s)
MMC write: dev # 0, block # 565248, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3126 ms (20.5 MiB/s)
MMC write: dev # 0, block # 696320, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3136 ms (20.4 MiB/s)
MMC write: dev # 0, block # 827392, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3147 ms (20.3 MiB/s)
MMC write: dev # 0, block # 958464, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3153 ms (20.3 MiB/s)
MMC write: dev # 0, block # 1089536, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3163 ms (20.2 MiB/s)
MMC write: dev # 0, block # 1220608, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3174 ms (20.2 MiB/s)
MMC write: dev # 0, block # 1351680, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3180 ms (20.1 MiB/s)
MMC write: dev # 0, block # 1482752, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3191 ms (20.1 MiB/s)
MMC write: dev # 0, block # 1613824, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3202 ms (20 MiB/s)
MMC write: dev # 0, block # 1744896, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3209 ms (19.9 MiB/s)
MMC write: dev # 0, block # 1875968, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3220 ms (19.9 MiB/s)
MMC write: dev # 0, block # 2007040, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3230 ms (19.8 MiB/s)
MMC write: dev # 0, block # 2138112, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3236 ms (19.8 MiB/s)
MMC write: dev # 0, block # 2269184, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3247 ms (19.7 MiB/s)
MMC write: dev # 0, block # 2400256, count 131072 ... 131072 blocks written: OK
67108864 bytes read in 3257 ms (19.6 MiB/s)
MMC write: dev # 0, block # 2531328, count 131072 ... 131072 blocks written: OK
** apalis_imx6/root.ext3 shorter than offset + len **
2097152 bytes read in 309 ms (6.5 MiB/s)
MMC write: dev # 0, block # 2662400, count 4096 ... 4096 blocks written: OK
resetting ...
CPU: Temperature 59 C
Reset cause: WDOG
I2C: ready
DRAM: 2 GiB
PMIC: programmed
In: serial
Out: serial
Err: serial
Net: using PHY at 7
FEC [PRIME]
Normal Boot
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
48453 bytes read in 18 ms (2.6 MiB/s)
reading uImage
4945368 bytes read in 143 ms (33 MiB/s)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-3.14.52-v2.6.1b1+g3894f6d
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 4945304 Bytes = 4.7 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200ed44
Starting kernel ...
