Analogue VGA interface is not working in apalis t30
We are planing to use analog VGA in our carrier board with Apalis-T30. So please provide the support to enable the analog VGA.
Unfortunately analogue VGA is not supported by the Tegra 3 SoC and you would need a discrete RAMDAC off parallel RGB on your custom carrier board just like implemented on many a Colibri carrier board.
Hi Marcel,
Thank you for your reply.
We will make the required changes and if required any support we will come back to you.
