I am creating a pin out table before creating a custom cable to connect the Analog Camera Module to the Viola Plus Board + Colibri i.MX6.
Most of the pin mapping is pretty straight forward except for:
CIF_D_0
CIF_D_10
CIF_D_11
Should the iMX6 video capture work without those signals?
It appears that CIF_D_2 - CIF_D_9 are brought out to X9 and X10 headers. Can an updated device tree (similar to imx6dl-colibri-cam-eval-v3.dtb) be used to map those into the IMX6 ? That is, create a mapping of CIF_D_0-7 on the analog camera adapter to CIF_D_2-9 of the Viola Plus / iMX6? I believe that since the analog camera is outputting 8-bit BT.656, I don’t need CIF_D_8-11
Alternatively, it looks like I can get CIF_D_0 from X7, pin 5.
CIF_D_10 is at resistor R46
CIF_D_11 is not connected coming out of the SODIMM connector.
So maybe with some very fine soldering, I can make a cable equivalent to the Colibri Evaluation Board…
Please advise on the best way to build this cable.
Thank you!
