An error occurred setting up the container
Dear Support,
I want to create a new project, and I have an error that looks like VS code can not connect to docker.
I copied the terminal
When it happens, I guess the development container will start
[242 ms] Dev Containers 0.275.1 in VS Code 1.75.1 (441438abd1ac652551dbe4d408dfcec8a499b8bf).
[241 ms] Start: Resolving Remote
[289 ms] Setting up container for folder or workspace: c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp
[295 ms] Start: Check Docker is running
[296 ms] Start: Run: docker version --format {{.Server.APIVersion}}
[601 ms] Server API version: 1.41
[602 ms] Start: Run: docker volume ls -q
[924 ms] Start: Run: docker ps -q -a --filter label=vsch.local.folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --filter label=vsch.quality=stable
[1180 ms] Start: Run: docker ps -q -a --filter label=devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --filter label=devcontainer.config_file=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json
[1461 ms] Start: Run: docker ps -q -a --filter label=devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp
[1706 ms] Start: Run: docker ps -q -a --filter label=devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp
[1962 ms] Start: Run: C:\Users\Mehrdad \AppData\Local\Programss\Microsoft VS Code\Code.exe --ms-enable-electron-run-as-node c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js up --user-data-folder c:\Users\Mehrdad \AppData\Roaming\Code\User\globalStorage\ms-vscode-remote.remote-containers\data --container-session-data-folder /tmp/devcontainers-13da0211-039e-45ae-9866-4a5540f652ea1676636138462 --workspace-folder c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --workspace-mount-consistency cached --id-label devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --id-label devcontainer.config_file=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json --log-level debug --log-format json --config c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json --default-user-env-probe loginInteractiveShell --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default on --mount-workspace-git-root true
[2710 ms] (node:3568) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
[2710 ms] (Use `Code --trace-deprecation ...` to show where the warning was created)
[2711 ms] @devcontainers/cli 0.29.0. Node.js v16.14.2. win32 10.0.22621 x64.
[2711 ms] Start: Run: docker buildx version
[3106 ms] github.com/docker/buildx v0.10.0 876462897612d36679153c3414f7689626251501
[3106 ms]
[3106 ms] Start: Resolving Remote
[3112 ms] Start: Run: git rev-parse --show-cdup
[3195 ms] Start: Run: docker ps -q -a --filter label=devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --filter label=devcontainer.config_file=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json
[3398 ms] Start: Run: docker inspect --type image control_tp_arm64v8-wayland-base-vivante-no-ssh_bullseye_debug_afa7fc0d-e3ed-484b-9617-ed2e9f9e784d_sdk_image
[3645 ms] local container features stored at: c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\node_modules\vscode-dev-containers\container-features
[3648 ms] Start: Run: tar --no-same-owner -x -f -
[3750 ms] Start: Run: docker buildx build --load --build-arg BUILDKIT_INLINE_CACHE=1 -f C:\Users\MEHRDA~1\AppData\Local\Temp\devcontainercli\container-features\0.29.0-1676636143515\Dockerfile-with-features -t vsc-control_tp-c47f5f2a6b10c601d060efb1db3eb092 --target dev_containers_target_stage --build-arg _DEV_CONTAINERS_BASE_IMAGE=dev_container_auto_added_stage_label c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer
ERROR: docker endpoint for "default" not found
[4276 ms] Error: Command failed: docker buildx build --load --build-arg BUILDKIT_INLINE_CACHE=1 -f C:\Users\MEHRDA~1\AppData\Local\Temp\devcontainercli\container-features\0.29.0-1676636143515\Dockerfile-with-features -t vsc-control_tp-c47f5f2a6b10c601d060efb1db3eb092 --target dev_containers_target_stage --build-arg _DEV_CONTAINERS_BASE_IMAGE=dev_container_auto_added_stage_label c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer
[4277 ms]     at pie (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:1916:1698)
[4277 ms]     at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
[4277 ms]     at async vF (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:1915:1972)
[4278 ms]     at async P7 (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:1915:901)
[4278 ms]     at async Fie (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:1921:2093)
[4278 ms]     at async Vf (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:1921:3241)
[4279 ms]     at async eoe (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:2045:17324)
[4279 ms]     at async Qse (c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js:2045:17065)
[4302 ms] Exit code 1
[4309 ms] Command failed: C:\Users\Mehrdad \AppData\Local\Programss\Microsoft VS Code\Code.exe --ms-enable-electron-run-as-node c:\Users\Mehrdad \.vscode\extensions\ms-vscode-remote.remote-containers-0.275.1\dist\spec-node\devContainersSpecCLI.js up --user-data-folder c:\Users\Mehrdad \AppData\Roaming\Code\User\globalStorage\ms-vscode-remote.remote-containers\data --container-session-data-folder /tmp/devcontainers-13da0211-039e-45ae-9866-4a5540f652ea1676636138462 --workspace-folder c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --workspace-mount-consistency cached --id-label devcontainer.local_folder=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp --id-label devcontainer.config_file=c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json --log-level debug --log-format json --config c:\Users\Mehrdad \tmp\FULL_CODE\Control_tp\.devcontainer\devcontainer.json --default-user-env-probe loginInteractiveShell --mount type=volume,source=vscode,target=/vscode,external=true --skip-post-create --update-remote-user-uid-default on --mount-workspace-git-root true
[4309 ms] Exit code 1
Hi @Mehrdad ,
This may be an error related to a Docker Compose bug ([BUG] docker endpoint for "default" not found · Issue #9956 · docker/compose · GitHub). Searching for the error message:
Lead me to this: https://stackoverflow.com/questions/74804296/docker-endpoint-for-default-not-found
Can you try the solution specified above i.e. delete the .docker directory in C:\Users\your-username\.docker then restart Docker?
Lucas Akira
@lucas_a.tx ;
Thank you so much for your help. I found that page, but deleting the .docker directory from my project didn’t work. However, deleting the .docker file from the user directory worked. :slight_smile:
I know I should open a new question, but if I want to use the port, how can I do that?
Thanks.
Hi @Mehrdad ,
Glad the problem was solved!
You mean if you want to use the same port the extension is using, like 5001? Or do you mean your VSCode project using a specific port when running on the SoM?
If it is the latter option you can change which ports to expose in the container by setting the ports option in the extension settings:
A quick addendum: Given that you’re trying to start a new project, I suggest you try using ApolloX, which is version 2 of our VSCode extension.
At this point the team doesn’t plan on adding new features to V1, only bug fixes, so we’re starting to phase it out in favor of ApolloX.
Although it is still experimental, ApolloX has a new backend which should allow for easier Dockerfile and Docker Compose customization compared to V1. Just remember to disable/remove V1 before installing ApolloX.
Lucas Akira
Thank you for your help.
I was curious if we can use ports or not. and how can I display output on that.
Thanks for introducing the new app. new challenge exist! :slight_smile:
The device has not reached! My SoM is connected and I can check from putty.
also:
The ‘Torizon IDE Extension - ApolloX’ extension is not available in Visual Studio Code for Windows 64 bit.
Hi @Mehrdad ,
OK, I think I know what happened. You’re trying to open the same VSCode project made for version 1 of the Torizon extension on ApolloX, but unfortunately they’re not compatible. Sorry if this wasn’t clear.
If you’re going to use ApolloX I suggest you create a new ApolloX project by following the current documentation found here: GitHub - toradex/torizon-experimental-torizon-ide-v2-docs: VS Code Torizon Integrated Development Environment Documentation.
If you ever plan to use V1 after ApolloX is installed you have to disable ApolloX, and also comment an environment variable that ApolloX changes:
Don’t forget to undo the changes if using ApolloX again.
also:
That’s strange. I’ll check internally with the extension team about this and I’ll update here.
Lucas Akira
Hi Lucas,
I have the same issue saying
“The ‘Torizon IDE Extension - ApolloX’ extension is not available in Visual Studio Code for Windows 64 bit. Learn More
Torizon IDE Extension - ApolloX v0.0.67
VSCODE
Version: 1.76.2 (user setup)
Commit: ee2b180d582a7f601fa6ecfdad8d9fd269ab1884
Date: 2023-03-14T17:55:54.936Z
Electron: 19.1.11
Chromium: 102.0.5005.196
Node.js: 16.14.2
V8: 10.2.154.26-electron.0
OS: Windows_NT x64 10.0.19044
Sandboxed: No
WSL2, Docker and gnupg are installed, working nicely with Toradex Torizon Support (Early Access).
Fabian
Hi @fdortu , @Mehrdad ,
Sorry for the delay in responding this. In order to use ApolloX on Windows, VSCode has to be connected on WSL2, as you can see from the images here: GitHub - toradex/torizon-experimental-torizon-ide-v2-docs: VS Code Torizon Integrated Development Environment Documentation (note the bottom left of the images indicating WSL being connected). Otherwise you will receive the message about the extension not being available.
You can check the Microsoft documentation on how to use VSCode with WSL2: Get started using VS Code with WSL | Microsoft Learn.
Hope this helps you.
Lucas Akira
Ok it works : left-click on the bottom-left icon >< of VSCode then Connect to WSL
Thanks,
Fabian
