I am using AM625 with verdin board , and builiding image using yocto Build a Reference Image with Yocto Project/OpenEmbedded | Toradex Developer Center But I cant see the INA260 module in my device tree binding document properties:
compatible:
enum:
- ti,ina209
- ti,ina219
- ti,ina220
- ti,ina226
- ti,ina230
- ti,ina231
- ti,ina238
But when I refer the kernel.org/doc/Documentation/devicetree/bindings/hwmon/ti%2Cina2xx.yaml I see the compatible:
enum:
- ti,ina209
- ti,ina219
- ti,ina220
- ti,ina226
- ti,ina230
- ti,ina231
- ti,ina237
- ti,ina238 - ti,ina260
I understand the version given in yocto recipe is as below -
inherit kernel-yocto kernel toradex-kernel-deploy-config toradex-kernel-localversion ti-secdev
LINUX_VERSION = “6.1.46”
skip, as with use-head-next LINUX_VERSION might be set wrongly
To add support for the INA260 module in your device tree when using a Toradex Verdin board with an AM625 SoC and building an image with Yocto, you will need to manually update the device tree. The discrepancy you’ve noticed between the device tree bindings documented in your Yocto build and those available on kernel.org is likely due to the version of the Linux kernel being used in your Yocto project. The Toradex Linux kernel version you’re working with might not include the latest updates or support for the INA260 as seen in the mainline Linux kernel.
To update your device tree to support the INA260 module, follow these steps:
Update the Device Tree Source (DTS) File: Locate the DTS file for your specific board configuration within your Yocto project’s kernel source directory. This file will be under arch/arm/boot/dts/ in the Linux kernel source tree. You will need to add a node for the INA260 device under the appropriate I2C bus node. For example:
Ensure the I2C address (0x40 in the example) matches the actual hardware configuration.
Rebuild the Device Tree Blob (DTB): After updating the DTS file, you’ll need to rebuild the DTB file as part of your Yocto project build process. This typically involves invoking a bitbake command to rebuild the kernel or the entire image if necessary.
Update the Yocto Recipe: Ensure your Yocto recipe for the kernel includes the updated DTS file. You might need to modify the recipe to ensure it uses the modified version of the DTS file when building the kernel.
Verify Kernel Configuration: Ensure the Linux kernel configuration (CONFIG_SENSORS_INA260) is enabled. This might require modifying the kernel configuration within your Yocto project to ensure the INA260 driver is built into the kernel or available as a module.
Testing: After rebuilding your image and deploying it to your Verdin board, verify the INA260 module is correctly detected and accessible through the sysfs interface at /sys/class/hwmon/hwmonX/, where X is the appropriate instance number.
If the INA
Regarding your question, as suggested by Toradex AI since the kernel version do not have required support for ina260 chip, you will need to modify or include the changes by yourself and test.
Steps really depend on how to want to test. If you are building yocto image then you will need to navigate to driver source code and add the changes and build image.
If you are building kernel outside yocto then you can follow below article, here also you will need to modify the driver as per the changes and test.
