Hello there!
tdx-info output:
Software summary
Bootloader: U-Boot
Kernel version: 6.1.83-6.7.0+git.0a32d33d5fb7 #1-TorizonCore SMP PREEMPT Fri Jun 28 09:20:37 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/4860b7954d80173545a45a89e0765e31bb165e2c97451c60ae9597b7228d2683/0
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=6.7.0-build.18
Distro variant: VARIANT="Docker"
Hostname: verdin-am62-15207106
Hardware info
HW model: Toradex Verdin AM62 WB on prototype mk1
Toradex version: 0075 V1.1A
Serial number: 15207106
Processor arch: aarch64
I am currently trying to get the TI TSC2007 touch screen controller working on our custom carrier board. We’re using a Verdin-AM62, running Torizon OS. The SCL pin of the TSC2007 is connected to SODIMM 55, SDA to SODIMM 53 and PENIRQ to SODIMM 17. It is defined in the device tree as follows:
/* TOUCH: Verdin I2C_2_DSI */
&main_i2c2 {
touch@48 {
compatible = "ti,tsc2007";
reg = <0x48>;
ti,x-plate-ohms = <230>;
interrupt-parent = <&main_gpio1>;
interrupts = <49 IRQ_TYPE_EDGE_FALLING>;
gpios = <&main_gpio1 49 GPIO_ACTIVE_LOW>;
The kernel recognizes the touch controller as is evidence by running dmesg | grep -i tsc2007, which provides the following output:
[ 5.325562] input: TSC2007 Touchscreen as /devices/platform/bus@f0000/20020000.i2c/i2c-2/2-0048/input/input3
Libinput also recognizes the device, as when running libinput list-devices within a debian container with /dev, /tmp and /run/udev/ mounted, outputs the following:
Device: TSC2007 Touchscreen
Kernel: /dev/input/event3
Group: 2
Seat: seat0, default
Capabilities: touch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: identity matrix
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: n/a
However, when running libinput debug-events, not a single event is registered when tapping, dragging, or otherwise interacting with the touch screen of our device.
Any and all help would be much appreciated, thanks!
Sophus
