PS C:\Users\Aditya\Desktop\tora> .\recovery-windows.bat
Downloading Toradex Easy Installer…
uuu (Universal Update Utility) for nxp imx chips – libuuu_1.5.233-0-g79ce7d2
ECHO is off. Failure 0
Downloading Toradex Easy Installer failed…
Press any key to continue . . .
PS C:\Users\Aditya\Desktop\tora> ===100%=================] SDPV: jump
1:1-14839063 7/ 7 [Done ] FB: done
Based on your output, it appears the Toradex Easy Installer actually completed successfully despite the initial error message. The “Failure 0” message followed by the progress indicators showing “SDPV: jump” and “FB: done” suggests the installation process finished correctly(1).
What Happened
The recovery script encountered an initial issue but then proceeded to complete the installation process. The “===100%=================” progress bar and “FB: done” status indicate successful completion(1).
Troubleshooting Steps
If you continue experiencing issues with the recovery process on Windows, here are the recommended solutions:
USB Driver Issues
The most common cause of recovery failures on Windows is incorrect USB drivers(1). When the module appears as a “USB Download Gadget” in Device Manager:
- Open Device Manager
- Right-click on “USB Download Gadget” and choose “Update Driver”
- Select “Browse my computer for drivers” → “Let me pick from a list of available drivers on my computer”
- Uncheck “Show compatible hardware” if present
- Select “Universal Serial Bus Devices”
- Choose “WinUSB Device” → “ADB device” and click “Next”
- Select “yes” to the pop-up window
- Reboot your module and retry(1)
Alternative Driver Installation
If the above steps don’t work, you can download the Android USB driver from the Android documentation and manually install it(1).
General Recommendations
- Avoid USB hubs between the PC and USB OTG port(1)
- Avoid virtual machines for the recovery process(1)
- Use a reliable USB cable and try different USB ports if needed(2)
Next Steps
Since your output shows “FB: done”, the Toradex Easy Installer should now be loaded in your module’s RAM. You can proceed to use the Easy Installer interface to install your desired image(1).
Hi @Adityag!
Which module are you using? Could you please provide more details about the steps you took?
Besides that, how are you going to use the TEZI? With a display or some VNC viewer?
Best regards.
